Question about Ovens
I need a new door or just replace glass. I have a coonara fire heater any suggestions
    Top Expert:
  • Ovens Master
  • 47,705 Answers
The glass will be heat resistant pyrex glass so unless you can get the glass heat treated , get a new door
Posted on May 06, 2017
Hi have taken screws out of oven door to clean on my Omega Oven & the whole front glass panel came off, can you please advise what glue is to be used to put it back on again please?
In my experience there is new glue used on oven doors. The glass has either a neoprene, woven glass matting or asbestos sealing gasket on the edges or both surfaces of the glass. The glass is put in place between clips/guides and then the door halves are tightened and it pinches the glass in place. The only glue-like substance you could use is Fire clay cement.
Jan 20, 2018 | Ovens
The glass shattered on my Favorit BOA 099 oven door but apparently it`s discontinued ? Where do I source a new glass / door from ?
Only a suggestion. but a good glass company could make one for you jst take the door off the stove and take it to them. tempered safety glass can be cut to fit .
Jan 20, 2015 | Ovens
Hi, The inner glass on the door of my Belling 295 SS built in single oven has completely shattered after just preheating it (quite hot although!). I bought it in 2007 so it would be out of warranty. Can...
Hi.
You should not need to replace the complete door, just the door glass.
If you have not already done so, then I would suggest you contact the maker direct, they should be able to help you.
Try the web site.
WWW.BELLING.CO.UK.
Jan 11, 2011 | Ovens
Oven glass door shattered on the inside during self clean mode
The glass is replaceable. You need to get the exact glass replacement kit from the manufacturer. I had to have mine replaced about a year ago due to condensation between the 2 glass panels and was able to get the replacement for $0.00.
Suggest to Siemens that the glass on yours should not have shattered and therefore was probably defective and you may luck out and get the glass for free. It's worth a try.
Mar 18, 2010 | Siemens Ovens
Oven will not heat. Inner glass was broken. Have a replacement on the way but why would the oven not heat? There does not appear to be an electrical connection from the door glass to the heater elements....
Replacing the door glass will not fix the heating problem.
More likely to be faulty heater element, this is located at the rear of the oven compartment, behind a removeable cover.
Hope this helps.
Dec 16, 2009 | Whirlpool Ovens
How do I remove the glass on the inside of the oven door to clean between the two pieces of glass
We just replaced the inner glass last night. The door needs to be removed, then take the screws out that holds the inside panel on. I suggest writing notes of the steps that you take when you remove the panel and glass. Our model had three pieces of glass. Be careful replacing the door, we knocked the lock loose which in turn knocked the sensor for the light to come on. We had to take that part of the oven apart also to fix it. Hope this helps. I may not have done this if it wasn't for the broken glass.
Dec 30, 2008 | Whirlpool RBS305PDS Electric Single Oven
I need to replace the outer glass on my Advantium oven
contact GE; they should have replacement glass in stock.
Apr 28, 2008 | GE ZSC2001FSS Advantium Electric Single...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
