Question about Bosch Washing Machines
Bosch 20165ME Maxx Vario machine. Only spin lights flash - unable to start / pause. How do you rest.
  • 130 Answers
SOURCE: BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Posted on Feb 16, 2009
venexcsd
  • 1185 Answers
SOURCE: Missing instructions Bosch MAXX 4 Comfort
Click on the link below ,fill in the details re the model number and it will be available as a .pdf
http://www.boschappliances.com.au/content.asp?document_id=192
If you have not got Adobe Reader go to www.filehippo.com and get a copy there
Posted on Jul 28, 2009
  • 250 Answers
SOURCE: Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Posted on Sep 20, 2009
beltronic205
  • 1474 Answers
SOURCE: Bosch Maxx - softener not dispensing into machine
It blocks very often , give it a good clean..remove soap dispenser to do so
Posted on Sep 28, 2009
SOURCE: Bosch Maxx 5 Washing machine will not wash, drum does not spin.
maxx5, error F63
Posted on Dec 14, 2010
Bosch Nexxt 100 series washer wfmc1001uc
According to the manual, you have to:
1. Turn program selector to "off"
2. Turn selector to Drain or Spin
3. Press the start / pause
Wait until program ends.
Open door.
or
Press "start / pause" until the start / pause light flashes.
Jan 10, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch 100 series wont start... lights stay on for wash rinse spin, but door lock doesnt light
Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
OR
First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Pl click if helped
Mar 26, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
My Bosch front end washing machine will not start a cycle. Door is closed tightly and when I push start/pause red light comes on & immediately goes off-this happens every time I push the start/pause...
My Bosch washer turns "on" and water runs but it does not spin or complete wash. I hear the machine "clicking" as if it is attempting to to function but no spin or full wash cycle.
Oct 17, 2010 | Bosch Axxis WFL 2060 Front Load Washer
What does error code E2 mean? I have a Bosch Maxx Classic.
The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
to fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing.
Nov 03, 2009 | Bosch Washing Machines
Maxx 1000 wo;nt spin
check brushes in motor 6 years quite good.
Sep 14, 2009 | Bosch Washing Machines
Washing Machines Logo
21 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
