Audio
Hi Joan,
Unfortunately there is no built-in jack for either a stereo or mono headset for an LG 32LX2D.
There are possible ways of doing these, they are:
1. Connect by RCA cable the Aux In of an external amplifier that has provision for headsets to the Composite Audio L/R Out of your TV;
2. hardwire a jack to the internal speaker wires of the TV. If the internal speakers will be cutoff, you need to also install internally a loading resistor. This would require that you be familiar with electronic components and circuitry, use of a DVM and a soldering iron.
If your concern has not been addressed after completion of the above procedures or you are not comfortable on a DIY (do-it-yourself), you may need to seek the services of a qualified professional or your friendly neighborhood electronics shop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
