Question about Lands Phones
My teadmill only displays red stripes in stead of distance, time ext.
Show telephone's own ext. number
To find out what the extension is in the board room,on the board room phone press feature *0 then press one of the intercom keys. You could also call another extension from the board room phone and see what extension number is on the display of the phone being called.
May 26, 2010 | NorStar T7316 Corded Phone
TH-50PX60U Panasonic Plasma - Flashing red light (now, reset, apparently) - and, missed what code was. Now, left half of screen blank. Right half normal. I managed to get it back, briefly, and while it...
This is either a logic problem or a connection problem within the display controls. I have sen this with a power suppy problem as well. Since the picture was fine before the outage, it is unlikely to be the panel. Anything else should be covered under the extended warranty.
Dan
Sep 03, 2008 | Panasonic Televison & Video
Light red translucent stripe at top of screen
On your Remote
>menu
>parental controls,favs & setup
>system setup
>display
>centering
You can use this screen to move your picture up a bit and get rid of the line. If it doesnt work the first time, move it a little more. Good Luck!
Aug 03, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Check engine light came on while drive home from vacationon I-75N at 70 MPH. Did not come on again next day while doing errands. It's a stead light - no clashing. Is it safe to drive short distances...
HI
when no fault in engine or transmission detected currently ??
"Is it safe to drive short distances until next paycheck?"
after check it ask us for more information !
WITH MY BEST WISHES
Jul 17, 2008 | Hyundai Sonata Cars & Trucks
Display anomaly on HP iPAQ
I have seen the same thing, but if you tip the unit to the side slightly, it goes away or gets more red. I assumed it was just the display and did not report it.
Sep 14, 2005 | HP iPAQ RX3715 Pocket PC
Ripples appear in the image when photographing an object with fine plaids or stripes. How can I fix that?
When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. An example of this can be seen in the pictures below. The photo on the left shows the fine plaids pattern on the shirt. The photo on the right is a distance shot of the same shirt. In this photo, you can see a ripple that is not visible in the photo on the left. This effect is called the Moire effect. Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Look at the image above. This image shows red cross-stripes and black cross-stripes overlapped slightly misaligned. When you look at the entire image, you find a ripple that differs from either of the patterns. This is the same principle that causes the Moire effect. Preventing the Moire effect You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly. Reference You may find another Moire effect displayed on the LCD of the camera. As this is caused by the aligned pixels on the LCD, this effect does not necessarily appear in pictures you have taken.
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
