Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
My computer is not recognizing passport exthd500gb as passport
I had to move the harddrive to another usb port inorder to instal another HD and then i got a message need to format.then i saw the computer no longer recognized the drive as passport but instead as drive (G) and with no files how can i fix it i have valuable information and my kids pictures on it!"
  • 245 Answers
If you formatted it you removed all the files.
Posted on Jul 25, 2009
PC will not recognize the external harddrive passport. PC has been rebooted and passport has been unplugged and replugged to get PC to try and recognize passport. Light on the passport comes on, and the...
3 beeps its searching for a connected device
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps you
Sep 13, 2011 | Western Digital 1TB My Passport Essential...
My computer doesn't recognize my Acomdata 250 Gb Hard drive (HD). The computer pops a balloon saying that it could run faster with a hi-speed 2.0 port. I own a dell Xps m1210, the installation cd that...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Nov 27, 2010 | Acomdata 250GB External Firewire HD 250 GB...
Compaq presario M2202AP doesnt recognize WD 3200 external usb drive. I cant find the download site for the corresponding usb hard drive. ...
Hi You can download driver from below link. Click here Install driver then check. Also follow below if still not recognize. First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Oct 13, 2010 | Western Digital Passport 320GB External...
Wd drive windows not recognized
then check.
Jul 23, 2010 | Western Digital WD Passport 250GB Portable...
Do I need a disc to install
This is a external hard drive and no need for you to install any software to a computer in order for it to work , this is a plug and play device you just need to wait for the computer to recognize it after you plug it to a USB port and once its recognize its ready to use.
Jun 11, 2010 | Western Digital WD Passport 250GB Portable...
External hard drive is not being recognized by any computer
then check.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Thanks for using FixYa.
Apr 27, 2010 | Western Digital Passport 320GB External...
Can't figure out how to copy info from Passport to my hard drive
the question here is how did you manage to get the info saved into your passport portable hd in the first place? I don't mean to sound like a smartass but if you did save the files onto your portable hard drive before you wiped your pc's hard drive it should work the same way backwards if you want to access and restore the files back on to your pc from your portable hard drive.
now to answer your question you should simply...
1. plug your portable hard drive (I mean power and usb cable both).
2. turn on your passpost portable hard drive (if needed).
3. your computer should see your portable hard drive now being connected to the usb ports, wait a few seconds for the computer to recognize it and give you access to it.
4. if you don't a pop up asking you what to do with the new device you just connected (passport port. hd) simply go to start>my computer and under removable devices category you should see your portable hard.
5. double click your portable hard drive and you should be staring at the contents of your passport hd.
6. you can copy some or all the folders you find in your portable hd on to a folder that resides in "my documents" folder which is a folder that resides in your pc's hard drive. (if you are not accoustumed to move folder around from one device to another, please ask the help of someone that is familiar with this task or simply select a folder, right click on it, select "copy", then go to the target location, right click on an empty space and select "paste")
if you are not able to do this 1-6, you may have not completed setting your system, and it's possible that you may still need to install drivers for you usb hub (for instance) to have your system being able to work with usb devices.
post back with your findings and any details of any problems encountered along the way.
hope this helps!
Apr 22, 2010 | Western Digital Passport 320GB External...
WE harddrive not working
Connect it directly to a USB port on the PC. Not a USB hub. Be sure to connect power adapter if necessary. The hub does not supply enough power.
Jan 20, 2010 | Western Digital WD Passport 250GB Portable...
I have a Western Digital Passport that works fine
Western Digital Passports work perfectly on USB ports 2.0 that supplies 5v of electricity with a max of 500mA. If your computer was manufactured more than 5 years ago, it may be using the USB 1.1 which is slower than the current.
Jun 14, 2009 | IBM ThinkPad R32 2658 Notebook
My MAC won't recognize my WD 80 GIg External HD
Some computers (especially Mac laptops) don't send enough power through the USB port to power a passport, so you need to get an extra power cord, one that combines 2 USB ports into one to get a little extra juice. Wish I could give you a website where you can buy that extra cord but I am currently looking for one myself at this moment in time.
Nov 16, 2008 | Western Digital Passport WDXML800UE...
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
463 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
