Question about Deadbolt Locks & Locksmithing
00107_REVA deadbolt instructions how to get them
Where do i find the english instructions for installing Garrison keyless entry deadbolt lock? 046-2667-4. Got only french in box
Is this model sold in the USA or Canada? If not then you may have a problem getting the booklet in English. You could post the instructions and then use google to translate them.
Aug 12, 2016 | Deadbolt Locks & Locksmithing
Key will not come out in unlocked position
I presume you figured it out by now, but if the tailpiece is installed wrong in many deadbolts, the key won't come out in one position or the other. It's called a "timing" problem and the way to fix it is to take it off the door, turn the tailpiece a half circle and put it back on the door. Usually Kwikset locks are designed so you can't put it in the wrong way, but it can happen. (If it's not the timing problem, then the deadbolt unit is defective or broken. They are designed to fail in a way that keeps them locked, so this could be a sign that someone tried to break in, or that someone used the extended bolt as a way to stop the door from closing and it hit the door frame too hard.)
The best way to install a deadbolt lock without the instructions handy is to look at the "lazy" cam and see if there is a way to install it wrong and don't install it that way. Example: If there are 2 ways for the tailpiece to fit in the deadbolt unit when the deadbolt is retracted and only one way for the tailpiece to fit in when the deadbolt is extended, then install the lock with the deadbolt extended and you can't install it wrong.
Jan 05, 2014 | Kwikset Locks & Locksmithing
My Kwikset Electronic Deadbolt is working in reverse. When I push the lock button it retracts the deadbolt. When I put in the access code it extends the deadbolt. What is wrong?
My lock did not have jumpers, but adjusts itself automatically... You have to hold the lock button in (on the exterior side) while you insert the battery pack - the deadbolt will cycle in and out, then beep a couple times. You'll be holding button for maybe 10 seconds.
I have to say while this step is included in the instructions in a big red box, it says nothing about why or what its doing, so I imagine many people miss this...
Mar 05, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
How to change the battery on my BE365-CAM-716 Schlage Keypad Deadbolt
Problem fixed by having my wife look it up on the Schlage website. The deadbolt has a flash memory so your combinations and codes will not be lost when the batteries are changed.
Sep 21, 2008 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
Locks & Locksmithing Logo
88 people viewed this question
Top Deadbolt Locks & Locksmithing Experts
jdthefixer
Mark Wolfe
David Belitz
David Belitz
Are you a Deadbolt Lock and Locksmithing Expert? Answer questions, earn points and help others
