Question about Uniden Lands Phones
I have 3 uniden phones. Can't hear incoming calls they can't hear us but we can ringout and speak to people
SOURCE: Mic not working.
It worked well for me too! Thanks Fixya.com!! I was told I had to buy a new phone because the microphone went back. Took the receiver apart (4 screws in back of handset and 2 that held the board in place), cleaned mic with alcohol and a q-tip, and removed the rubber piece that kept the mic clean (inside of the housing), and presto, it worked just fine. The ribbon cable came loose upon opening up inside of phone, but I stuck it back inside the top of base and I was ready to go.
Posted on Mar 09, 2009
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
  • 37 Answers
SOURCE: Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Posted on Apr 29, 2009
SOURCE: our incoming calls are not ringing?
wen i receive incoming calls there is no ring or message alert
Posted on Dec 30, 2009
  • 6 Answers
SOURCE: INNOVAGE 1604007
Press SET. Press UP to select Set 8 Speech. Press Set again to confirm. Screen will show default setting SPEECH ON. press Up or DOWN to select ON/OFF. Press SET to confirm newetting
Have a uniden 5.8... The problem is incoming calls do not ring. Outgoing calls work perfectly. The caller hears one ring and then their phone goes silent.
You have probably accidentally activated a blocking function on your phone! Take the portable handset, and remove the battery. Wait five minutes, then reconnect the battery. That should reset the phone to "initial conditions," which are the settings it had when it was new.
Apr 17, 2017 | Uniden Lands Phones
How do I get rid of the static on my phone, I have replaced the batteries and no luck!
Please provide me with your model number so that I can help you.
Jun 22, 2015 | Uniden Lands Phones
Ringer is set at max but is hard to hear
If the ringout volume is very low, then try not to select a soft, silent or low ringing tone. Try to choose a ringing tone that is loud so that you can hear your phone ringout.
Hope that was helpful?
Mar 18, 2011 | One Touch Jitterbug One-Touch Cellular...
I get no sound for incoming calls. All other
the ear piece speaker which other speak into and you hear from is damaged inside the phone and it needs to be replaced to get clear listening of calls coming in.
When you replace it, you will start hearing clearly again.
Take care.
May 19, 2010 | LG Dare VX9700 Cell Phone
Our incoming calls are not ringing?
Dec 10, 2009 | Uniden Cordless Phone
Uniden phone constantly ringing
Hello, it sounds to me like you have a dying battery which may cause the phone to ring constantly.
ryan44z
www.cobaltsys.net
Nov 09, 2009 | Uniden Cordless Phone
I need help with my cordless handset
Replace the condenser mic on the handset.
May 23, 2009 | Uniden Cordless Phone
Calling party cannot here receiving party
This can be one of a couple of things. First of all, if this is a multi-handset phone, go off hook on two handsets at the same time and see if you can hear yourself in both phones (Speak into one while listening to the other) If it is only a single handset phone, do the same thing only with another phone. If you cannot hear anything coming from the uniden phone, it may have a bad mic in the handset and would need to be replaced. (the handset not the mic) If you bought it less then a year ago and still have the receipt, call uniden at 18002971023 and they will help you get it replaced.
Mar 22, 2009 | Uniden Cordless Phone
Lands Phones Logo
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
