Question about The Office Equipment & Supplies
An equation is shown. x2=12181 Select all of the expressions that represent the value of x .
2 Suggested Answers
  • 623 Answers
SOURCE: For what value of a, (a+2)x^2 - (a-2)x - 1 = 0
x= -2
Posted on May 22, 2010
X and y intercepts
First of all you equation is not one : it has nothing on the right side of the = sign. But to answer the general question let us write the equation as 50+25x-5y=0
X-intercept (also know as roots) There may be several
Definition: X-intercepts are those values of the independent variable x for which y=0. For a straight line there con be at most 1 x-intercept.
To find the intercept, set y=0 in the equation of the line and solve for x
50+25x-5(0)=0 or 50+25x=0. The solution is x=-(50/25)=-2
Y-intercept (also know as the initial value. There can only be 1 y-intercept, otherwise the expression does not represent a function.
Definition: It is the value of the dependent variable y when x=0 (where the function crosses the y-axis
To find it, set the x-value to 0 in the equation of the line.
50+25(0)-5y=0, or 50-5y=0. The solution is y=50/5=10
The straight line cuts the x-axis at the point (-2, 0) and the y-axis at the point (0,10)
Jan 28, 2014 | Computers & Internet
How do i input quadratics on a casio fx1500?
  • You have several memory locations you can use to store values in them. The memory locations are A,B,C,D, M, X, and Y. You use [SHIFT][RCL] and one of the variable names above. Example store 78 in C location: 78 [SHIFT] [RCL] [HYP]. To recall that value press [RCL] [HYP]
  • If you want to use the EQN (equation solving mode, press [MODE][5:EQN] then select the equation type . For example [3:aX^2+bX+c=0] will display a template wher you input the three coefficients.
  • You can also enter any type of equation and solve it with the SOLVE command. In that case you use the keyboard to enter the expression (see above how to enter variable name X). To type in the equal sign (=) use [ALPHA][ CALC]. Once the whole equation is typed in, press [SHIFT[ [SOLVE], and the calculator will prompt SOLVE for X? Confirm and press the main = sign. Press = again to get a second, a third root (if any)
Jun 06, 2012 | Casio FX-115ES Scientific Calculator
Convert -525 degrees into radain pi form
Here is some help
180deg is equivalent to Pi radians
Take some angle. Its measure in degrees is say x_deg, Its measure expressed in radians is x_rad.
The fraction of 180 deg that the angle represents is equal to the fraction of PI that this angle represents.
Conclusion: the ratio x_deg/ 180 deg must be equal to the ratio of x_rad/PI
x_deg/180 deg=x_rad/PI
Isolate X-rad in the above equation. Some will tell you to cross multiply.
Application: x_deg=-525 in radians?
x_rad= (PI/180)*(-525)=-(525/180)*PI
Keep the value (525/180) as a fraction reduced to its simplest form. The result is 35/12
Sep 26, 2011 | Casio FX-115ES Scientific Calculator
How can I compute quadratic equations using fx-300ES?
You cannot solve the quadratic equation with this calculator. It does not have a solve program.
However if you wnat to create a table of values for a function (any type of function that uses the basic scientific function keys ) you use the TABLE Computational Mode.
You press MODE
You select TABLE
You enter a mathematical expression 3X^2-.33X+ 15
You generate the table of values.
Aug 28, 2011 | Casio fx-300ES Calculator
How do I enter a polynomal into the calculator. I need to be able to do factors with letters in it
Well, the short story is that this calculator cannot do symbolic algebra: it does not have a CAS (Computer Algebra System). However you can enter symbolic expressions using the variables A,B,C,E, X and Y. Use the sequence [ALPHA] [A] to enter the letter A, etc. To type in the symbolic = sign, use the [ALPHA] followed by the key at the top left corner of the keypad that has an = next to it.
When you enter an equation (two expressions linked by an =), press [ALPHA][SOLVE] to solve the equation for tha unknown X. You will be prompted to enter the values of all other letter symbols : A,B,C, D, Y, etc. When all symbols (except X) have been given a value the calculator will find the value of X that satifsfies the equation.
Jul 12, 2011 | Casio fx-300ES Calculator
What is the meaning of the mathimatical expression
n mathematics, an expression is a finite combination of symbols that are well-formed according to the rules applicable in the context at hand. Symbols can designate values (constants), variables, operations, relations, or can constitute punctuation or other syntactic entities.
Any "expression" that represents a numeric value. Example: 2+2=4 or x+7=10. Actually the examples above are equations, not expressions. Expressions do not have = signs. 7a and 4x are examples.
it is a mathematical statement e.g 7=6+1 THE WHOLE THING IS AN EQUATION but the 6+1 is a expression.You can only have expression is there is an = sign
Yes the 6 + 1 part is an expression. Once you have an = sign or any of the other inequality symbols (,...) it is no longer an expression but a full math sentence
Jun 22, 2011 | TOPICS Entertainment Elementary School...
I am trying to solve a quadratic function using the calculator but i dont seem to be able to do so. For example if i had a question like 5x^2 + 15x +3, how would i use the sharp el-w535 to find the x...
This expression 5x^2+15x+3 is not an equation, therefore it can have any value depending on the value of x. You have to make it an equation before looking for the particular value of x that satisfy your equation 5x^2+15x+3 =0
This calculator cannot solve equations because it does not have an equation solver.
Dec 15, 2010 | Sharp ELW535 Calculator
How do you do algebraic equations and inequalities on this calculator? The keys and the instructions are too small to read.
You can use symbols (X,Y,A,B,C,D, and M, =) to create expressions to use in the SOLV program or to generate a table of values.
To type them you use [ALPHA] followed by the symbol you want. The symbols on the body of the calculator are of the same color as the ALPHA key. The [=] in expressions is different from the general = sign at the bottom of the keypad.
There are also some typical equations already in the calculator: simultaneous linear equation in 2 or 3 unknowns, and polynomial equations of 2nd and 3rd degree. They are accessed under the EQUATion Mode.
Jun 21, 2010 | Casio FX-115ES Scientific Calculator
Casio fx-7400G PLUS cubic solver?
First let us repair the terminology.
  1. You can evaluate any expression (find the value of any expression for a particular value of its variable).Store a value in the variable, say X. Key in the expression and press [EXE].
  2. You can consider your expression(should not contain a relational operator such as =, greater than, less than, greater than or equal to, less than or equal to) to be a function Y1(x) = expression and graph it, or generate a table for it. You will have several values of the function calculated at various points.
  3. You can set your expression equal to 0 and find the particular value(s) of the variable (the unknown) that make the equality TRUE. That is called solving an equation.
I am not sure that it has a solver (solving an equation or an inequation) but you can always draw your expression as a function and explore the graph (SKTCH) to locate the roots (or zeros) of the functions (the values of the variable where the function equals zero.) That is called solving graphically.
Hope it helps.
Thank you for using FixYa and for rating this solution.
Nov 05, 2009 | Casio FX-7400G Plus Calculator
37 people viewed this question
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
