Distance between Llbilbie & Edens Landing - Computers & Internet
    Sergeant:
  • 197 Answers
10 h 3 min (917.0 km) via Bruce Hwy/A1
Posted on May 06, 2017
Where do you land if there is an emergency during a trans-atlantic flight?
You're stuck with a water landing (ditching). Hopefully at altitude the pilot can see a ship and make the landing in the vicinity of the ship for quick rescue. It so rare for a plane to lose power to all engines though that you should never hear of such an incident. Depending on the route, however, Bermuda may be within gliding distance.
Jan 04, 2017 | Aircrafts
How is a pilot supposed to find out their distance in miles from an airport they're landing at?
Using the old (pre GPS) method you would use the sectional and plotter (aviation ruler) and measure the distance. Using a GPS you can usually turn on distance rings on the screen or if you have the airport selected as destination you can read it right off the screen. If it's your home base you should learn the landmarks and their distances from the airport. In the Miami area, there are so many airports and landmarks, if you're flying there, during your preflight preps you should measure out distances to some landmarks that you plan to pass over and mark them on the chart or flight log.
Airplane question?
That would be the ground prox system on the aircraft it lets the flight crew know how far they are above the ground during an approach to the landing runway.
What is the best footing location on an element skateboard to land a noliepopshuvit easier and faster??
Well, speed and landing condition depends on upon your body height and weight. I am a skater and sometimes play skateboard which was ordered from stores like "Betterscooter". When I am about to landing my body and foot automatically balanced with the skateboard surface. Also, your landing position will be not same always as landing surface will be different.
May 06, 2015 | Sport & Outdoor - Others
The entire evaporator coil is frozen and heaters will not come on. Mark Edens
The common failures is the heater itself goes bad, or the defrost timer fails if you have an older model. Check the heater and defrost thermostat with an ohmmeter to see if it has opened up or burned out. If you have an older refrigerator, check the defrost timer operation. Often the timer motor does not advance and it will stay in compressor operation and never turn on the defrost heater. Turning the cam until it clicks should turn the heater on and run the heater for about 30-45 minutes. If it does not turn on the compressor after an hour, then you should have the timer replaced.
Sep 27, 2010 | Refrigerators
Tire pressure in manual is 21psi, front and 22psi for rear. Do I need to increase this for on road riding? Pressure seems low for on road riding?
Here's my take on tire pressures and when they need adjusted, I wrote this a while back for someone with a Honda African Twin, so this should help:
Manufacturer's recommendation – Short distance city riding below 100kph. Light off-road use ie. Small rocks, gravel. If the weather/road conditions vary a lot.
30% above recommended pressure – High speed road use. Long distances in warm weather on good quality roads. Go 40% if the conditions are the same but the bike is fully loaded with carriers.
15% below recommended pressure – Short distance riding in cold winter temps. Short distance on wet roads. Off-road, average gravel/rocks and some wet mud.
40% below recommended – Slow off-road riding in very loose dirt, sand, with lots of rocks. Tires will heat up quickly if the pace is picked up which will loose grip and cause accelerated wear.
60% below recommended – Very slow, loose dirt, deep sand (dunes). If tires slip on the rims you need to increase pressure.
My mantra is all about keeping a close eye on tire pressures and adjusting them to suit the conditions rather than keeping strictly at the manufacturer's settings. Starting out my riding career on a BMX, tire pressures can be the difference from landing a perfect jump and falling on your face. Therefore, with a motor attached, it is even more important to get it right – personally I think the 'feel and grip' is more important than the pressure number – regardless if that causes tire wear.
Hope this helps and you vote for me :)
Jul 01, 2010 | 1995 kawasaki KLE 500
I need a free manual which did not come with the purchased product
Just go to http://www.garmin.com and click on the support tab. You will be led to a page where you can download a manual in PDF format for your system.
Thanks for using Fixya.
Apr 21, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
