Question about Westinghouse Televison & Video
What are the codes for a westinghouse using the ge model 10838 cl3 1346?
I need to pair my Westinghouse TV with Comcast Remote XR 11. what code should I used ?
You failed to mention your W.H. Model(!) so you make my work harder...please try these codes:
10000 (0000 from the Westinghouse site). Also try 10463 or 10623 (from a White Westinghouse manual)...
THEN try:
10885, 10889, 10890, 11282, 11577, 11100, 10080, 10111, 11548
Anthony
Dec 24, 2017 | Westinghouse Televison & Video
Remote codes for RC2418-D GE Universal Remote. Have a Westinghouse SK-26H520S TV
Use code search to find something that works. if a search through all codes stored in the remote control fails you may have to try a different one. All universal remote controls do not contain all possible codes.
Aug 12, 2017 | Westinghouse Televison & Video
I have a G.E remote.I need codes for my 32in LCD Westinghouse flat screen TV
GET remote control codes typed online will give you a list to program
Mar 04, 2015 | Westinghouse Televison & Video
Westinghouse acces code for model. Dw39f1y1
The code is stored in the remote. If you are using a Westinghouse remote, it should work automatically with your TV. If you are trying to use a programmable remote, you can use its code search feature to seek a suitable code. If a thorough search through all available codes stored in the remote fails, you may have to try another programmable remote.
Dec 04, 2014 | Westinghouse Televison & Video
Westinghouse 32H540S Remote Program
You have this backwards. The codes are in the remote. If you are using a Westinghouse remote, there should be no programming necessary. If you are using a universal remote, you can use the code search function to find a code that will control your TV.
Dec 03, 2013 | Westinghouse SK-32H540S 32 in. LCD TV
The conyrol of my tv, westinghouse model sk:19H2105 IS BROKEN AND I NEED A CODE TO USE A UNIVERSAL CONTROL PLEASE HELP ME, THANK, YOU.
Hello
WHITE WESTINGHOUSE Codes: 097/ 100
Four digit codes for white westinghouse are : 0100 0130 0138 0136 0227 0279 0080
four digit codes for wetinghouse are: 0143 0114
OK
Jul 25, 2011 | Televison & Video
Need code Westinghouse TV I have brookstone big digit remote
Hello zmprice, I need a bit more information so I can better assist you, what is the model # and serial # of the TV? Depending on the model # if it is an older model # they normally use Sony codes, whereas if it is a newer Westinghouse TV it probably uses Samsung codes.
Feb 15, 2011 | Brookstone Big Digit Remote Control Remote...
I have a holiday living 6 outlet yard timer and i lost my directions....Model # lx28006
Woods brands sells timers that are packaged and sold under various names and numbers.
For example GE sells same yard stake under their brand.
Woods 6-outlet yard stake manual:
Add a comment and say if this is your timer manual.
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
Dec 05, 2010 | Hardware & Accessories
Televison & Video Logo
42 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
