Question about Refrigerators
We don't know how to hold down our vitrifrigo fridge in our motorhome. There were no instructions with the fridge.Its a C130 I.
    Top Expert:
  • Refrigerators Master
  • 45,552 Answers
Talk with a caravan service center but you can remove the rubber feet and front adjuster bolts and use those points to bolt the fridge to the floor of the motor home
advice from people who install fridges to vans and motor homes would be a good place to start
Posted on May 06, 2017
My Vitrifrigo DP2600 fridge now gets very hot along the front divide between the fridge and freezer. What could cause this? How can it be fixed?
Seems like your self defrost mechanism is fubar. Check the defrost element and make sure that it is not open and that the timer is working. I parts needed go here Search Over 2 1 Million Appliance Parts
Sep 11, 2017 | Frost Refrigerators
Rm2193 dometic fridge Works with gas but not on 120 how do i fix this?
Anon, Check the attached links,instruction and guides to diagnose fridge, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RV Refrigerator Repair 101 How To Diagnose Problems With RV Refrigerators...
The RV Forum Community
RV motorhome and bus conversion mechanic resource
Aug 03, 2016 | Dometic Refrigerators
My motorhome generator keeps sputtering and dying.
Check the fuel system e.g.the filter the hose and tap, also the on of elec. switch.
Sep 16, 2014 | Rv Motorhome Dual Co & Lp Gas Alarm...
Fridge troubleshooting
The motor should not be running continuously. If it is, then it is because the internal temps are not going down low enough for the thermostat to shut the compressor down. If the temp is not low enough, the temperature of the coolant returning to the compressor is higher than what it should be and that the cool refrigerant returning to the compressor cools that motor down. If it does not, the motor will over heat and often shut down for cooling.
Ice buildup on the evaporator coils will cause a warmer running fridge. If the unit has a self defroster then it is not working and responsible for the anomaly.
Nov 27, 2013 | Refrigerators
Instruction manual for linear series ls 3700 stereo
Stereo off
Hold down mem button.
tune up is hour
tune down is minutes
Jul 21, 2012 | Audio Players & Recorders
I have a Dometic fridg in my 2005 motorhome and when I start my f
You need to unpush the gas button on the front control. If the gas button is pushed in, then it is trying to run on gas and with the tank empty, it is unable to light. That is why the check light is coming on. If you turn the gas side off and have it on auto, it should switch to the AC side and work fine.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic RM2652 Refrigerator
Refer Norcold DE 0051 not getting cold
Your cooling unit is shot, I suggest. Most likely, you've lost the R341 refrigerant. Norcold, so they can sell you another cooling unit at $500+, does not make these little fridges with a service port so you can recharge the system. Same with Dometic. Solution is to spend, again, $500+ for a new sealed unit that will fail in relatively short order (I'm on my second in five years) or buy a better refrigerator. I'm opting for a new fridge this go around (Vitrifrigo). Vitrifrigo has the needed service port.
Dec 28, 2007 | Thetford Norcold DE0051 Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
