Prosser stopped working used 6/8times only new it shouldnt do that so How do i get help
How could i fix my computer which get heated up fast and then blackout
make sure all your fans are running as they should,clean them if needed.or it could be your prosser getting hot,if it is you will need to clean the top of it and replace with new paste,
and make sure the fan over the prosser is clean and running.
Jun 19, 2014 | HP Computers & Internet
When i press power on power supply turn on but power led is orange should be green , prosser fan works but prosser not work correctly , i put this prosser in another computer works very good rams and...
This is a problem coming from your signal cable(cable from system unit to monitor).
All you have to do is to change it.
If it still doesn't work, you have to change your monitor
Jan 26, 2011 | Dell Motherboard Socket 775 For OptiPlex...
in the back is the micro prosser located benind a metal plate and it is common for it fail . very pricey .. mm hope this helps
Dec 11, 2010 | LG Refrigerators
Emachine W5243 keeps cutting off (stays on from 5 mins to 20) just cuts off, thats it.
chack your prosser cooling fan is not working that y your cuts off
open your case then star your CPU and keep waching your Prosser FAN you will see after some time it will stop or it wont start at all
May 04, 2010 | E-Machines eMachines Desktop PC
New build PC wont post,MSI G31M3 SERIES MOBO, 2 Working processors tried, ddr2 800mhz ram Tied, still it will not post, pocessor checked to ensure its seated correctly yet still wont post, Any ideas?
when we are stating asmblinging same bord and same other thing .we facing same many problem by ram and smps. so chang two thing one bye one to check. and also check powercable. we can use in this bord only celon/penteam douelcore prosser.not supporting prosser can do this . think about this.
Oct 30, 2009 | MSI G31M3-L V2 Motherboard
Motherboad processor getting hot,new fan change,powersupply change & ram change but its still too hot plz what that problem u can tel me
install orinal fan of intel or cpucoolar .............and check your prosser is cool ...ok and all problem in mother board in prosser panal .................
Mar 19, 2009 | Gigabyte GA-K8NXP-SLI Motherboard
Mother bord not a display
check different working ram, also take out the cpu fan then place it again, then check
Oct 19, 2008 | Intel D845GVSR Motherboard
Computer is freezing
hi friend
if u have insatll ur new hard drive then is not ur hard drive problem ur pc prosser over hiting rpoblem so chk the ur porsser fan its not working proper or the prosser fan is not conneted or its not working proper or dust in ur fan so clen ur porsser fan by the the dust if u have proper knowlage of how to open ur laptop then will u open if u not have a proper knowge how to open ur laptop
if not have a proper knowlage of open ur laptop then u have go good tacnision he will clen ur prosser fan ur laptop is working proper again
Mar 31, 2008 | Toshiba Satellite P105-S6024 Notebook
Problem my asrock
check ur memory card memory card migh be faulty that is the first step also check the display card if u find i all this ok u have problem with the mother board
Oct 23, 2007 | Mercury Electronics KT266A Motherboard
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
