Question about Maytag Dryers
My maytag centennial dryer takes almost two hours to dry a load, it is electric I was wondering if I can convert it to gas? Model # MEDC400VW0
  • Maytag Master
  • 2,252 Answers
No. Among many issues is that the control board is different. But why not fix the unit so it dries as is normal in under an hour. Half of your 240 volts is out? Your heating element is bad. Your fan is loose.
Posted on May 06, 2017
ranger25
  • 72 Answers
SOURCE: SLOW DRYING WITH MAYTAG DRYER
Have you checked to see if there is an obstruction in the gas valve itself or if the solenoid is worn? If there is, it will not allow as much gas through, therefor making a smaller flame and less heat. If not, check for pinched gas flex lines either before or after the gas valve or leaks in the combustion chamber. Also take out the lint trap, seal it up with cardboard cutout with a hole in it, take an air compressor with a blowout valve on it set at about 200psi, cover your face and blow out the trash out of the internal ventilation system on the dryer. Should work better after all this. Hope this helps.
Posted on Jan 28, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag dryer doesn't dry properly
heating element is fine. it either works or it doesnt, cant work halfway, your problem sounds like you hav a clogged vent a kinked exhaust leaving the home. try looking at the exit point form the home can you see any lint around the housing, VENT VENT VENT
Posted on Mar 11, 2008
dinomb
  • 16 Answers
SOURCE: Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Posted on Mar 30, 2008
  • 97 Answers
SOURCE: Maytag Neptune Dryer taking hours to dry a load
Hello Friend, Your solution is simple. It sounds like your dryer is working properly, and your actual problem is a blockage somewhere in your 4 inch exhaust tubing. Check it and make sure it is not clogged up with excessive lint. Also if your tubing is clear you need to check your connection where it travels thru the wall etc. It would be a good idea to find the actual location where it exits to the ouside and check for good airflow. Your dryer is equiped with a safety thermistat and if you are not getting the proper exhaust flow the burner will cut off and restart in the manner that your's is doing. I Hope I have helped you, Tim. And please don't forget to give me your rating for my help.
Posted on Jul 11, 2009
SOURCE: The gas maytag neptune intellidry gas dryer does
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Posted on Jul 11, 2010
Our Maytag Centennial Electric dryer is not cycling in auto dry mode but will in timer mode. Any thoughts?
There is a sensor that the clothes have to touch when the drum spins. This sensor measures how wet the clothes are. If you don't have enough of a load in the dryer then the sensor wont detect the dryness. Or it could be a bad sensor or connection or main board.
Nov 02, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
Maytag model MEDC400VW0 continues to run after drying cycle is completed
Sometimes these machines have a cool down cycle which for most people is too long
Dec 15, 2014 | Maytag Centennial 7.0 Cu. Ft. Super...
The dryer takes about 3 hours to dry whereas it
make sure the vent hose and outside door flapper is clear. Try drying one load with the hose off to see if its better.
Sep 08, 2009 | Dryers
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
