Question about AMP Car Audio & Video
Little black 3pronged components are are blown in the amp
I get a fuzzy sound out of the right speaker. New speakers and wires so that is not the problem
it sounds like a blown channel in the amp.open the amp and see if there are any fuses that might be blown.it might be a blown capacitor which a tech should be able to easily fix
Nov 03, 2015 | Marantz Audio Players & Recorders
Amp turn on
No remote.. wire possibly not hooked up?? The little blue wire usually.. ground is bad..brown wire? Black wire??. Inline fuse might have blown really big red wire?
Apr 12, 2014 | Pioneer DEH-1800 CD Player
Well i think i freid my amp i had a friend take a look at it and thats wat he said might of happened cuz as soon as i try to put a fuse in it blows it so idk wat to do now i want to get it fixed but in...
  • Open the Amp up. Look for any black spots on the board. If it "blew" you should see a burnt electrical component, perhaps a RCA jack where the cords go. That's the first step in looking at a suspected "blown amp"... is to try and see if you can see what blew.
  • Let me know what you find. If the fuse is blowing just as quick as the power feed is connected there is a burnt part of the board and/or a component. I suspect a diode. They allow current one way and are what one may say a fuse on the board itself in the form of a component.
  • Let me know.
Tony
May 30, 2011 | AudioBahn A2300HCT Car Audio Amplifier
My python 7701 is making a clicking noise and the lights are blinking. How do I get that to shut off? Tried turning ignition on and then off and then pressed black button did not work?
either a speaker is blown, a speaker wire has shorted to ground, or the amp has a blown or blowing component...check the impedance (resistance( of the speaker outputs on the amp. if almost shorted, disconnect the speaker wires and check the impedance at the amp and then the speaker wires to determine where the fault lies.
Mar 08, 2011 | Car Audio & Video
I have Goodknight 420E cpap machine wont start no display dead
If you take the unit out of its case you will see a little white rectangular component right near the power jack. That is the fuse. It is a 3 amp fuse.
Jun 20, 2009 | Kitchen Appliances - Others
MY 96 Nissan Maxima has rough idle and is blowning
blown head gasket. black smoke means that oil is getting into the cylinder.
Jun 11, 2009 | 2005 Nissan Pathfinder
Samsung HCM 4215W when on, no picture timer blinks & chirp sounds
Sounds like a shorted component in the power supply or the high voltage circuit.
Time to call a professional.
Apr 10, 2009 | Samsung HCM4215W 42" Rear Projection...
Quick question, amp problem
make sure you ground wires arent shared, meaning run each ground wire from each amp to its own grounding point
Sep 08, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Crown Amp Possibly Blown??
Hi, probably worth fixing, Crown gear is generally reliable, but this one has failed for some reason. Puffs of smoke are not generally good... If it has blown an output array, expect a costly repair.
regards
Graeme
Apr 03, 2008 | Crown CE2000 2-Channel Amplifier
P4004 - Blown Components
if burned components are on output stage or amplifier section on board..Then look at the oposite side of amp..Both amplifier section should be a mirror image oof componentc from other..that way you can know the values of parts.If they are on power supply section ..Then you might need manual if available..
Dec 23, 2007 | Rockford Fosgate Punch P4004 Car Audio...
Car Audio & Video Logo
24 people viewed this question
Top AMP Car Audio & Video Experts
Billy McCain
Billy McCain
Level 1 Expert
Len Jeffrey
Are you an AMP Car Audio and Video Expert? Answer questions, earn points and help others
