Question about John Deere Garden
I had a new short block installled in a john deere 650 g bulldozer. When we started it, the oil pressure maxed the gage and blew the rubber seal on the oil filter. What would cause this problem?
  • Mauric James
    Mauric James May 06, 2017
    too much oil in crankcase
    Master:
  • 604 Answers
First start up
Posted on May 06, 2017
My John Deere rinding lawn mower won't go forword or backwards
John Deere mowers, for the most part, use hydrostatic transmissions. These use an oil of some type (they vary by model) in the transaxle to provide hydraulic pressure to move the tractor. Older tractors will eventually experience some oil leakage over time due to seal wear. If the level gets too low, then you fail to move. Check the oil level in the transaxle. The location of the reservoir varies from model to model. If it is low, after determining the correct oil to use, fill to proper level. Then, start the tractor and work the hydrostatic drive lever forward and backward slowly and continuously until you get full speed operations in both forward and reverse. This can take a few minutes until all the air has been purged from the system.
Oct 03, 2016 | John Deere Garden
What is the oil filter part number for Generator engine serial number CD4045C037188?
your number 4045tf258 should be a industrial generator that number is the model number
John Deere 85 KVA 4045TF258 for sale Price 7 359 Year 2005 Used John Deere... notify john deere and use the model and serial number [i have 2 different numbers and are as follows RE506178 Oil Filter 1 RE5 9754;the first should be the new number and the other was the old ] just to make sure of the correct parts number for your unit
Aug 19, 2016 | John Deere 225 325 375 500 650 Alternator...
Battery shorted out. now tractor will not start with new battery installed
it probably blew a fuse check them and check the positive wires some have a fuseable link looks like a rubber joiner in the line check with test light on both sides of link good luck
Mar 22, 2015 | John Deere Garden
John Deere 2005 Trail Buck 650 ext fuel pump
john deere trail buck 2005 650 when accelerating before it gets to top starts cutting out pretty bad. In the high altitude it was doing that and not it does it here in MO. What causes this a weak fuel pump? Thank
Mar 10, 2014 | John Deere 2005 Trail Buck 650 EX
We fixed an engine of john deere 3020 diesel model 1966. All things it's ok. We took a watch which pressure the oil engine instead of the short lamp. When the engine is working and is cold, the pressure is...
I have been working on the my John Deere 3020 and can not get it to start. I had the starter rebuilt and have gone through everything I can think of! Any help would be great
Feb 18, 2011 | John Deere 3020 Gas & Diesel Tractor...
Suzuki sv 650 oil filter seal blew out loosing oil. fitted new filter and new oil seal blew again after a few minutes???
there should be a oil pressure sending unit close to the filter, install a manual guage to check the actual pressure, and chack the filter mouting seal surface with a flat edge it may be warped
Nov 10, 2010 | 2002 Suzuki SV 650
Oil pressure gage keeps dropping to zero
just finish doing a freinds truck same problem
engine high idle oil pressure ok engine at low idle hot
o oil pressure also hard start start after sitting a few minutes hot
or in am cold
found 1- wrong oil filter--not depresing dain out valve to crank case
2- oil cooler by pass valve rubber seal ruptured (fairly expensife oil filter base kit )
(only way to get this rubber)
3- found oil gallery plug pop out of oil injection pump(cant buy)
located small frost plug kit installed and peen area
reassemble and test all work out properly
4-could also be the oil gallery in the block at front or rear
they are also block of with frost plug cap
very pore desine should be treaded plug and locktite
Nov 02, 2010 | 2004 Ford F350
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
