Question about Water Garden
I have B & D pressure washer 1570TD. when I start the gun water comes out but after offing the gun water doesn't stops & motor also doesn't stops.What could be the problem..
    Master:
  • 604 Answers
Bad spray handle
Posted on May 06, 2017
Motor starts and cuts out when using gun now wont start
About 622,000 results (0.78 seconds) Search Results
    Troubleshooting Your Pressure Washer - Jacks Small Engines
    www.jackssmallengines.com/diy/troubleshooting-your-pressure-washer/
    Mar 18, 2015 - Or, you are in position to start washing, you pull the spray-gun ...Inspect hose for any twist, cuts, bends or dents. ... Your Engine Won't Start or is Lacking Power ... carb got motor running now hoses leaking and little water coming outof a ... I have a troybilt with a Briggs & Stratton engine 3000 max pressure.
    How to Fix Washer That Won't Start ' Washing Machine Repair
    www.partselect.com/Repair/Washer/Will-Not-Start/
    Find out how to repair a washer that won't start by troubleshooting and testing common parts like the ... Read on to learn how easy it is to fix the washing machine yourself. ...ApplianceHelp.com is now PartSelect.com .... If the motor starts, then the problem iswith the transmission or the pump and can be further diagnosed by ...Missing: gun
    Washing Machine Won't Start ' ThriftyFun
    www.thriftyfun.com/Washing-Machine-Wont-Start-1.html
    This is a guide about washing machine won't start. You have ... Is the motor burnedout? My wife was ... My Maytag Neptune was running; then the power went out andnow it won't restart. By Larry L. ... Question: Washing Machine Starts to Fill and Then Stops. When I try to ... It has something to do with the door lid. I usually ...Missing: gun
Jan 28, 2016 | Washing Machines
Honda 160 homelite pressure washer 2700 psi no pressure
Water comes out the nozzle, but low pressure? ( more than when the motor is not running)
I would check the check valves and the unloader.
If the amount of water coming out the nozzle is the same when the motor is running or not running.
Either the key that connects the motor shaft to the pump shaft is sheared, or the pump is trash.
No water comes out the nozzle would indicate a clogged inlet filter or blockage at the gun valve or nozzle.
May 05, 2014 | Homelite Pressure Washer. Honda 2700 psi...
Gcv160
High likelyhood of your intake screen/filter being stopped up with debris that was in the water hose.
Other than that, more information would be needed. Like, does no pressure mean it doesn't seem to spray at all (or nothing more than the water hose is pushing water through the system with the engine off)? Or does the pressure come up a little and there is a pulse you can feel in the hose/trigger gun? Any other little details you notice can provide clues as to the root of the problem.
If it was just a stopped up intake, and this fixes your problem -- please take a sec to rate me. Thanks!
Don
Mar 24, 2012 | Honda Black Max 2600 PSI Pressure Washer
K3.86 The motor will not start. It starts for a few secons than stops. Does not products any power Thanks Jim
Dear Sir,
Normally when one closes the gun the machine stops. So you may have a blockage problem that is shutting the machine off. You may try to diusconnect the gun so that you run the machine without load. But..ALWAYS...with water being fed. Never run a power washer without water being fed. Without gun and water fed normally....your machine should continue working. If so you can attach the gun without the lance. If it works, you have a blocked nozzle in the lance. If so try with a very thin needle to clear the nozzel. Do not make the nozzel's hole bigger with cleaning, because then you lose power. Now these machines stop automatically by means of a control valve (Spill Valve). The spill valve when the gun is closed, pressure is created and the spill valve in turn will move to close the electricity by means of a micro switch. Spill valves give a lot of trouble if machine is left with soap in it, or if the machine is stored with pressure in it. NEVER STORE A POWER WASHER WITH PRESSURE IN IT.....always when finished working disconnect electricity, disconnect water and finally press the gun to release pressure. Well as I already said start by putting on machine without load. Then add the gun without lance so that you see that when you close the gun the machine stops....and when you open the gun machine starts again. All this without lance attached. Also in cases like these the Spill Valve sometimes gets jammed in the cutting off electricity position. Spill valves only need to be serviced with good silicon grease....but in doubt change the spill valve. If you open the machine the spill valve is located where you see 2 wires coming out. You should have special tools to remove and service/change the spill valve. Well hope you have a small idea from where to start.
Apr 19, 2011 | Karcher Garden
I bought a honda pressure washer power boss 3000. I load the gasoline, start the machine, but pressure water is not coming out from the trigger. i tried so many things , but can t get started.
If you are using a water tank for water supply, remove the water supply line from the pressure washer and connect a water hose from a faucet. Turn the water on, then crank the engine. Pull the trigger of the spray gun until water comes out. When then water starts to spray properly the release the trigger, shut engine down with pressure on the line then reconnect the water supply from the tank to the pressure washer. If this fixes the problem then the problem was "air-locked"! Happens alot with new pressure washers that have never been run. If you need any other help, please email me @ davidandlisacampbell@yahoo.com
Feb 18, 2011 | Honda Pressure Washer PSI 3000
Engine runs , not getting any water flow when trigger pressed.
Disconnect hoses.
Look for kink in water hose.
Check incoming water connection for filter washer
Replace filter washer
If you don't have a filter washer, put one in.
Hook up water, and turn on
Water should come out other side of pump.
Turn on machine.
Do you get pressured water out of pump.
If no pressure, then pump is suspect
Hook up washer hose without gun
Does pressure come out of washer hose
Finally, the gun trigger may be bad.
We had to buy guns now and then.
Search for pressure washer guns
Following link shows guns we used:
http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
Oct 25, 2010 | Karcher G2650HHR Gas Pressure Washer
Water goes thru. have hydrulic oil to level. gun semas to stick on. NOT GETTING ANY PRESSURE AT NOSSEL.
Hydraulic oil?
Is this a pressure washer?
Pump should be half full of SAE20 or SAE30 non-detergent motor oil.
Engine should have 10W30 motor oil.
If you have a pressure washer ... and not water is coming out end of gun:
Take all hoses off machine.
Look at incoming water hose connection.
The should be a filter washer.
Clean or replace filter washer.
Hook up water and turn on water.
Turn on power washer and see if water coming out of pump is pressurized.
Now hook up pressure hose without gun.
Turn on pressure washer and see if water comes out of hose and is pressurized.
Finally, the gun may be bad.
We used to replace guns when they went bad.
Oct 24, 2010 | Dewalt 3800 PSI Pressure Washer
Hello there.My Karcher pressure washer motor constantly runs with no pressure coming out of trigger gun.I have tried another gun with the same result.The motor should stop/start when you press gun.The...
The valve that admits more water to be compressed is stuck. It is likely the O-Rings on it need replacing. No water to the pump, no pressure!
The motor will stop when pressure is up to the designed pressure.
Oct 03, 2009 | Karcher Garden
Do not know how to work power washer
Dear Carrie688,
I cannot for sure understand your problem. You say, you do not know how to WORK power washer. Does WORK mean FIX...or USE???? I will assume that you wish to know how to use it.
First without water connected and without gun connected...switch on the machine. If it turns, then this means the electric motor is OK. Now connect the hose and gun. Connect water supply. Now always start the machine with gun open. This will help to remove air from system. When pressure builts up, close gun, and machine must stop instantly. If machine does not stop, open the gun again and switch off the machine. If the machine continues working when the the gun is closed, this will result in a lot of damage. I do not know what model you have, because also there are old models that when gun is closed, the machine keeps running. I assume your model is recent. So the machine will stop when gun is closed. Now when finished, switch off machine and electricity. And most important release pressure from gun. Do not store machine with pressure still in it. This will damage machine and it is not safe.
Now if you have detergent, this can only work on low pressure. There are bigger machines that detergent works on high pressure. But the normal system is that detergent works on low pressure. Also before storing, pass fresh water to remove all detergent from pump of machine. Never store a machine with detergent in its system.
Regards,
Fulltech.
May 13, 2009 | Karcher K2.26 Electric Power Washer
Water on swich power on push down trigger no water then motor stops go's completely dead
the problem was in the gun, the nipple had broken off the plastic gromit,in the brass part of the trigger mechanism, stopping the water comeing out the wand and stopping the motor.
Apr 08, 2009 | Garden
Garden Logo
Top Water Garden Experts
andrewdwhite
ray gallant
Joseph Coppeto
Joseph Coppeto
Are you a Water Garden Expert? Answer questions, earn points and help others
