Question about Kodak Cameras
My kodak mini will not turn on after I left it unused for a few months. I connected it to my pc for charging and it will not the battery symbol came on white, like fully charged
  • 5 Answers
SOURCE: Kodak Z700 not firing up
Guest is right. Clean the contacts, bend the contacts with a small flat head screw driver upwards "GENTLY". This should work. Might have to repeat every couple of months. Forget regular batteries. Use the rechargeable ones. MUST be fully recharged.
Posted on Sep 24, 2008
SOURCE: kodak easyshare md41 will not charge battery while
Can the kodak md41 be charged by a laptop through a USB cable?
Posted on Apr 19, 2010
SOURCE: My Kodak EasyShare M340 turns on, but then shuts off immediately.
omg! thank you so much Stephan you are th best i just bought the camera for Christmas. Went to the beach yesterday and it sttopped working the method with holding the lens and moving it around i saw some sand come out now it works!!!!!! :-D
Posted on Jun 06, 2010
Yogger
  • 117 Answers
SOURCE: my symbol mc50 scanner wont
it is possible that if you changed the battery you forfot to move the slide button next to the battery to the correct position. It often happens to me :-) Please check it, its on the right top corner of the battery, you should not see the red marking, if there is the correct position.
Posted on Dec 02, 2010
lock123
  • 6831 Answers
SOURCE: kodak easyshare ls743. lens wont retract. camera error #E45 shows on screen. battery is fully charged.
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Dec 14, 2010
Kodak Z980 battery wont last.
I always buy an extra battery or two for my cameras. Sometimes if batteries are over charged [left in the charger for days] or charged too often [charge again after just a few minutes of use each time] they won't hold a charge. Or it could have been a bad battery to begin with. Get a new one and be happier for just a few dollars. Hope that helps, it's what I do.
Oct 16, 2014 | Kodak EasyShare Z980 Digital Camera
Tip
Notebook Battery Tips
<span> <p><b>Instructions:</b><br /> <p><br /> <ul> <li>New battery pack must be fully charged before use.</li> <li>New battery pack needs to be fully charged and discharged (cycled) a few times before it can condition to full capacity.</li> <li>Rechargeable batteries undergo self-discharging when left unused. Always store a battery pack in a fully charged stage for storage.</li> <li>Fully drain and fully recharge your battery pack every few month.</li> <li>Turn down the LCD brightness of your portable device.</li> <li>Use built-in power management on your portable device.</li> <li>Turn off LCD or other unnecessary accessories when not in use.</li> <li>Set screen saver blank to 1 to 2 minutes of your notebook</li> <li>Add more RAM if you have extra RAM expansion slot, it will reduce the usage of hard drive and it is power exhaustive.</li> <li>Close unused software in your notebook.</li> <li>Remove unused PC Cards or USB devices from your notebook.</li> <li>Don't watch DVD or play graphics intensive video games.</li> <li>Don't short circuit terminal or store your battery pack with metal parts.</li> <li>Don't drop or mutilate the battery pack.</li> <li>Don't expose to moisture or water.</li> <li>It is normal to get warm when charging or normal use. If it is getting too hot, there may be a problem with the device and qualified personnel should check it.</li></ul></span>
on Nov 03, 2010 | Computers & Internet
My sony ericsson xperia mini pro wont turn on
First, check if the charging port is properly and snugly connected. Then, check your batteries. Maybe your batteries aren't charging properly. If the battery is self-replacable, try cleaning the golden battery connectors inside first. Or, your battery may need to be replaced
Feb 02, 2014 | Sony Ericsson Xperia mini pro (SK17/SK17i)...
I have a kodak z650, this is "new" machine in the original box but we never used in the past six years. When then i turn on in the LCD showed "Kodak easyshare logo" then turn off by itself... The le
If you really left the batteries alone for 6 years without regularly charging them, they won't work anymore. I still have two KLIC 500 batteries from Kodak, which I bought in 2005, Both are in very good condition, because the both get a charge every 3 months, even in periods I did not use my camera.
You could try. charging the batteries several times, but don't have to high expectations.
Jan 03, 2014 | Kodak Cameras
My Kodak Easyshare M575 digital camera will not turn on. It turns on okay without the battery while plugged to an electrical outlet. I've tried charging the battery and that doesn't work. The...
If unused for any length of time, rechargeable batteries lose their ability to retain a charge. Try it with a brand new, fully-charged battery. FWIW, I recharge all my camera and flashgun batteries monthly.
Nov 07, 2017 | Kodak EasyShare M575 Digital Camera
It won't turn on at all. It won't even charge. It's only 4 months old. Wasn't dropped or exposed to water or elements. Was working fine yesterday morning, then about 4:30, it was dead. ...
How long did you let it charge, when the device is completely drained of power it may not turn on at first when you connect it. Let it charge for a little while and come back to see if it fixes it. Failing that, your probably going to have to contact apple for warranty help.
Jun 15, 2011 | Apple iPod touch
Kodak m863 battery is not charging. It has lain unused in a desk drawer for a few years. Have managed to take a couple of photos but now battery will not charge and cannot use on/off button unless...
First of all cheak your charger,it is working or not Then put your camera bettery under the sun light for some time and clean your camera pin where the battery attached,then chaek it
Jun 01, 2011 | Kodak EasyShare M863 Digital Camera
My kodak Easy share digital camera will not turn on
clean the connectors internally to which the battery connects.if they r dirty this can happen.or if that connectors get loose or little bit bent they cannot connect the battery properly and this happens.
Jan 07, 2009 | Kodak EasyShare C743 Digital Camera
Battery symbol blinking when put on charging.
It does sound like the battery needs to be replaced, but it also could be an internal charging problem with the camcorder. I would try a new battery first, since it's the easiest and cheapest option
Oct 19, 2008 | Sony Handycam DCR-TRV38 Mini DV Digital...
Kodak digital camera
Camera will not charge through USB interface, only DC input jack or camera dock.
Jun 13, 2008 | Kodak EasyShare M853 Digital Camera
Cameras Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
