Question about The Audio Players & Recorders
I have 24zone irritrol total control and only half of the zones are receiving 24vac? They where all working earlier in spring!
3 Suggested Answers
SOURCE: aube CT280-2H1C exit pin for humidifiers dont give 24vac
My carrier humidifier does not show any runoff of water in the over flow. it does not appear to be getting water
Posted on Feb 17, 2009
  • 299 Answers
SOURCE: I have an Irritrol Irrigation system (RainDial PLUS)
With the water turned on you may be able to hear or feel the water running through the bad valve. If not, you can turn each one on and off by hand by either turning the solenoid or the bleeder valve figure out which one it's not. Once you find the culprit you can see if it needs a new solenoid or open it up to clear out any sediment or debris that's keeping it from closing.
Posted on Apr 20, 2010
I'm using 2 zones, zone 1 runs fine, zone 2 runs for 5 min, loses pressure for a few seconds, then comes back on for 5 min. etc., etc.etc. Is this a valve or controller problem?
May have air in that valve. Check bleed air screw on side of vale and bleed until you get a steady stream of water then tighten back up.
Aug 01, 2015 | Irritrol Kwik Dial 4 Zone In
Irritrol rd 900 lcd flashes 5en and system will not water.it fails in manual,semi,and programmed
There was a bad batch of capacitors that came out of China a few years back. All of them eventually blew and caused many different electronic devices to fail. The capacitor is a round can on the electronic board. If the dome is rounded, it is bad. If they are all perfectly flat, they are OK. Check all the capacitors. Since the power pack is 24vac, the RD900 will certainly have at least one capacitor on the board. If bad, it can be unsoldered and replaced.
Jun 02, 2014 | Computers & Internet
How can I set the timer for a seven sector Dewbee by Irritrol?
The same manual for Irritrol's early MC Series may be used. I no longer have any Dewbee or MC Manuals but I do have written instructions available that should help. Let me know if still needed.
May 14, 2014 | Kitchen Appliances - Others
Display message meaning
Is zone 6 only in program C? If so, it's simply telling you that the current draw is beyond the controller's capacity which I believe is either 1 or 1-1/4 Amp. In which case the Valve solenoid may be shorted. If Zone 6 is also set to run in any other Programs and does not indicate a short, then the Controller likely is at fault.
Apr 05, 2014 | Kitchen Appliances - Others
Our 2nd zone won't work, we get the error saying check SP wires. The wires seem connected correctly. We also can't change the volume on zone 2. The Yamaha unit is working otherwise.
U cant get an amplified out put form ur av receiver for zone 2. speaker a A and B is the same out put of frond left and right. it is not ZONE 2 output. U can get only a pre output for zone to from this receiver. U nee a separate stereo amplifier for using zone 2 .put an amplifier in the other room, connect the zone 2 pre out to it. And do the following setup in ur av receiver .
The receiver shows check speaker cable because its amplifier minimum impedance is 8 ohms . when u connect other speaker in speaker the total impedance will come under 4 ohms. Speaker b is not ZONE 2 in this amplifier
1. press the input selector button A or B to select the source component you want to setup.
2. press and hold LEARN (on remote) button about 3 seconds by using a boll pen or similar object ( SETUP and the selected component name appear alternately in the display window.)
3. press up or down arrow to select "zone2"
4. press LEARN to complete the Zone 2 setup.
5. press source select up arrow to display Zone2 in the window.
6. press an input selector button to select input source u want to listen to in the second room
7. u can control the component by using the component control area button
ok
Dec 26, 2010 | Yamaha RX-V2200 Receiver
Apr 07, 2010 | Plumbing
Yamaha RX-V657 Zone 2
Suggestion by clarkent22
I called and spoke with Yamaha support staff (Chuck) who was very helpful. I was able to get my issue resolved hopefully this works for you too.
Couple of solutions:
1) Go into the Menu setting (Manual SetUp/Speaker Set) and make sure that you do not have Presence Speakers or Suround Back Speakers
2) Also in the Menu settings (Manual SetUp/Options/Multi Zone Settings) make sure that your Zone 2 Amplifier is set to "Int" (assuming you are not using external amp
3) Zone 2 can only accept an analog signal (not digital)... so there are two steps to this one. First, make sure that you either run only analog, or if you run digital and analog then you need to select "Analog Input" on the front of the unit. If yours was working earlier, my guess is that your input settings got switched to digital (or auto) You need to have analog set up for each specific external source (DVD, Cable/DTS, etc)....
4) This model receiver will only let you control Zone 2 with the remote control. You can power it on the receiver unit. But to select your source you have to press the Amp button, then the ** button. Then you control Zone 2 and you can toggle sources and adjust volume. (Check your owners manual for programing remote for zone 2.. think I pressed the "code" button and then 2999.)
Hope this helps... it worked for me If not call Yamaha they were very helpful.
Oct 13, 2007 | Yamaha RX-V657 Receiver
26 people viewed this question
Top The Audio Players & Recorders Experts
ctlimey
Level 1 Expert
D. E. Hev
JOHN TOPLISS
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
