How do i get the remote off auto - Televison & Video
How do I tune the new channels, also I have lost a main channel. Where is the auto tune button on remote
there is no auto tune on a remote
you press the menu on the remote and takes you to an on screen menu
navigate until you get auto tune and wait until all channels are found
some go straight back to viewing and other require that you press the ok button then the exit button on the remote
Mar 03, 2016 | JVC Televison & Video
Micplaced my original remote control. got now a universal remote control iDIGITAL 4in1 remote control. Cant get the right code for this urc tried manual and auto search. Can you please help me?
Take the batteries out of the new remote. Leave them out for a few minutes and then re-insert. Get the remote to do an auto find with your TV manually turned on. It should find it.
Jul 01, 2015 | Universal Remote Control Televison & Video
How do i channel scan on a phillips tv without remote control
change your remote control so that you can auto scan
Jun 30, 2015 | Televison & Video
All channels permanently deleted accidently, can I restore them
Auto tune the channels as found in the manual
  1. On your remote, press Menu.
  2. select Channel and press OK on your remote.
  3. select Auto Tuning and press OK on your remote.
  4. select Yes and press OK on your remote.
Nov 10, 2013 | LG 32LD350 32 in. LCD TV
I can not get the invoca remote to sync to my tv
If you can't find the code for your particular model, you can perform an auto search with your remote.
If you don't have the codes for an item you are trying to use your remote with, you can perform an auto search.
Manually Turn on the device you wish to program.
On the remote, press the device key for which you are searching.
Press "Prog" button once. (two flashes)
Make sure the remote is aimed directly at the device you want to control.
Press "Auto" button (one flash)
InVoca will now search through the library for the target device code in three second intervals. Every 3 seconds the remote will prompt you by flashing the light, and the remote will test the new code by attempting to turn the device power off.
The top line of the LCD display will show the device type and the second line will show the device code number as it searches.
When the targeted device turns off, immediately press "Prog" to save the device code in memory.
After you have pressed "Prog", check the other buttons, such as CH and VOL to be sure they work. If not, repeat the above steps. When the auto search is re-started, the search for the target device will begin where it stopped.
To stop the "Auto Search" press any key except "Auto"
Hope this works for you.
Jul 13, 2011 | Invoca 326348 Remote Control
Lost the remote control and i need the code for use a universal control
All universal remotes have an "Auto Programming" option. Consult the user manual and it will tell you how to auto program. You don't need the codes this way. Put the remote into auto program and it will find the code for you. Hope this helps.
Jan 03, 2011 | Televison & Video
I can't get channels bwyond 13 and remote is gone so I can't reprogram for other channels. Can this be done withour the remote?
hopefully you have a menu button on your TV, if so you should be able to access auto program (you might have to search to find the auto search)but before you auto program make sure you set your TV to a cable setting then auto program. If you do not have a menu button on the TV, you could also try buying a universal remote. If you don't want to do that you could always use a VCR, just set your TV on channel 3 and do a auto program on the VCR ,using the VCR remote you should be able to tune in the channels your missing through the VCR.
Jul 07, 2009 | Televison & Video
Hitachi 50sv810 Remote
Hi, sorry I confused things on my first post, I understood now that you need a remote to operate the HR 20 , as TV has his own remote.
If you have original remotes for TV and HR20, you should be able to do the job, and that would be best solution.
If instead you want to use an universal remote, the only way out is using auto programming on universal remote, as HR20 codes are not available.
Auto find or auto programming mode is a feature of all universal remotes, you need to check universal remote manual, and follow the procedure, untill this operates your hr20.
Jan 02, 2009 | Hitachi 50VS810 50" Rear Projection HDTV
Fuses and auto remote starter
The fuse box is on the dirvers side of the car - open the door and it is right there on the side of the dash near the front of the panel. Very accessable. I'm not sure where the auto remote starter is.
Oct 25, 2008 | 2004 Pontiac Grand Am
Auto start
did you install yourself and what module did you use for the doorlocks or did you have it installed at a shop
Sep 26, 2007 | Scytek 2000RS Remote Control
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
