Question about Radio Shack Radio Communications
How to adjust radio shack digital usb desktop micrkophone.. I have it connected but does not seem to transmit my voice from a distance
  • 27 Answers
SOURCE: One radio doesn't transmit voice
I think there defective. I'd return them.
Posted on Nov 15, 2007
SOURCE: Garmin 530 Radio problem
Did this start happening after the latest download? If so re load the current version of the software and do not turn off the radio until the download is complete. Please answer back and let me know.
Posted on Jan 21, 2008
  • 8637 Answers
SOURCE: Wireless Gigaware 26-990 unable to connect
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Posted on Jan 20, 2009
SOURCE: magnum 257 it will not transmit on lsb or usb it will on am and f
With SSB you have to put audio on the carrier you cant just key the microphone and expect it to output a signal unless you talk into the microphone at the same time this is how SSB works.
So if you talk and the meter starts to move then its ok, if you talk or whistle and nothing moves then the circuit on the SSB side of the unit is faulty.
Posted on Feb 07, 2009
  • 1218 Answers
SOURCE: I'm trying to transfer voice
The 2100Pc is NOT compatible with Mac O/S...this can be verified by going to
Posted on Feb 13, 2011
How do I get my computer to recognize Radio Shack FMS 43-127 voice recorder?
HAd the same problem. In the file manager software click "USB" from the top menu bar and then "connect to recorder." It found it after that. Good luck!
Jun 26, 2013 | Radio Shack TRC300 Voice Recorder
Can you please fix my driver on my 43-127 radio shack digital voice telephone recorder? Installation is complete otherwise.
Use the driver for Vista (either 32 o4r 64 bit depending on your Vista version) - it is provided in the 43-127 software.
Jun 24, 2011 | Radio Shack TRC300 Voice Recorder
People I cam calling complain of very low voice level from my handheld. I am definitely directing my voice into the microphone .
Check to see if you trying to transmit on INTor Can insted of USA then check to see if yor're trying to trans mit on 1 watt for long distances insted of 5 watt. Good luck.
Feb 07, 2011 | Standard Horizon HX850S VHF Handheld...
Not able to finish transmiting.
1 check and clean mic switch
2 check and repair wires in mic plug
3 if preamp mic replace battery
Jul 03, 2009 | Radio Shack TRC-503 CB Radio
Connex 3300 hp
U mean on sideband? Frequency counter only useful on other than sideband operation. This does not mean the carrier insertion osc. is on frequency. If it needs adjustment, your voice will sound high/ low on transmit. Incoming signals will sound right after adjusting the osc.
May 14, 2008 | Connex 3300 240-Channels Base CB Radio
Recorder came without USB cable and Manual
DS-30 manual you can find it here
You can use any standard USB cable for the DS-30 any radio shack store carry it,
Oct 20, 2007 | Olympus DS-30 Digital Voice Recorder
Pro-95 dual trunktracking handheld scanner
the beep are known as "over beeps", they are generated at the end of a transmission by the transmitting raido to signal that the user has taken his or her finger off the transmit button and has ended transmission, like how they used to say "over". as for the hissing, have you tried adjusting the squelch?
Aug 01, 2007 | Radio Shack Pro-95 Handheld Scanner
Staying keyed up after button release
I have never seen this problem before, check if the VOX is activated, this could cause to transmit the radio, but the voice must be transmited. check if the Accesory connector is not dirty, clogged or damaged
Feb 08, 2007 | Motorola Talkabout T5720 (7 Channels)...
Radio Communications Logo
Top Radio Shack Radio Communications Experts
Greg Cann
Greg Cann
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
