Question about Canon Office Equipment & Supplies
Clean canon mg3620 ink absorber pads - Canon Office Equipment & Supplies
SOURCE: Waste ink absorber on canon iP 1600
For Canon ip1000 and ip1600, maybe others
1. remove cartridges
2. unplug AC power
3. hold power button and plug AC power (keep holding power button.
4. press resume 4 times
The waste ink counter should be reset by now
Posted on Nov 30, 2007
SOURCE: How to open Canon iP3000 and remove absorber pads?
my computer see the printer as ip3100 & ican`t load my driver
Posted on Mar 12, 2008
  • 20 Answers
SOURCE: waste ink absorber
This is the ink counter reset instructions:
1. Service mode: Menu->Scan->Copy->Scan( one at a time in sequence)
2.Select "test mode"
3.Select "(8) ETC
4.Select "(4) EEPROM CLEAR
5.Select "(1) INK COUNT
6. press the OK button
7. Press the STOP/RESET button(returns you to the TEST MODE sub-menu
8. Press the ON/OFF button (which resets the printer).
There you go.
Posted on May 27, 2008
  • 49 Answers
SOURCE: Ink Absorber Replacement for Canon i70 Printer
Not easy for most people to replace or clean ink pads, but this will reset
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button.
(Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button.
(Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
Posted on Jul 06, 2008
  • 421 Answers
SOURCE: canon ip4300 ink absorber is full
You need to reset the waste ink counter. The printer doesn't know that you have replaced or cleaned the pads you need to tell it.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Hope that helps, if it does please rate my solution.
Posted on Nov 14, 2008
Canon Pixma MX300 ink absorber cleaning video ; how can I clean the ink absorber?
When the ink absorber pads are full, you can easily remove and clean them on most Canon printers. Fill a large bowl with warm, soapy water and set it aside. Put on the rubber gloves. Open the ink cartridge compartment.
How to Clean a Canon Ink Absorber '
Nov 26, 2016 | Canon Office Equipment & Supplies
Canon IP90 ink pad is full
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Feb 11, 2013 | Canon PIXMA iP90 Mobile Printer
How to replace ink absorber canon mx310
Unfortunately this is not an end user item. The ink absorber is basically a big felt pad. When the printer cleans the print heads at the beginning of the print cycle it spray ink on the pad o clean the printhead nozzles. The printer is programmed to count these cleaning cycles and when the number is up it gives the ink absorber error on the display. The printers use the ink absorber to prevent the used ink from dripping out of the printer onto you table or desk. By the time the absorber registers that it is full it really is soaking wet with ink, you don't want to deal with that mess. It really is like an end of life for the printer notification. You would have to open the printer, remove and wash the absorber and clean the holder then reset the counter in the printer just to get t going again. The manufacturers don't even sell the absorbers because they treat this as a non-repairable printer. Sorry for the news but I have been a printer tech for 15 years and that's really the best thing to do, get a replacement printer.
Jul 19, 2012 | Canon PIXMA MX310 All-In-One Printer
Ink absorber is full
Canon printers have an ink absorber that soaks up any excess ink. When this is full it can cause problems with your printer. You can send it in to be serviced but a much cheaper option is to replace the pads yourself or to try cleaning them.
See this link for detailed instructions how to change the pads:
Jul 15, 2012 | Canon Office Equipment & Supplies
The ink absorbers are a set of rubbery pads that absorb the ink during the printer cleaning cycle. They can also absorb ink from borderless prints (where the ink goes out to the edges of the paper). Some of these pads are below where the print head goes when in standby mode. Additional pads are further down inside the printer.
To get at them, you need to disassemble the printer and it's a messy job to replace or clean them. The counter for the waste ink pad full is set to a value that usually should be reached near the expected end of life of the printer.
If the printer is still under warranty, contact Canon to have them deal with the problem and reset the printer.
I hope this helps.
(You may be able to find the reset command by Googling waste ink full and your model number.)
Jan 09, 2012 | Canon PIXMA MP170 All-In-One InkJet...
My Canon MP210 printer [ USB001 ] said the Ink absorber is Full contact the service center. Guess what, the service center just gave information. I need to know if will be able to fix or will...
There are two possible ways to remove the error from your printer. First is to actually clean the absorber pads that are full of waste ink. The second is to reset the printer to clear the error and let the printer print again.
Clean the two absorber pads. There are actually two absorber pads located on the right side of the printer, under the
ink cartridges when the carrier is in the home position.
Accessing the pads and remove them for cleaning?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezers and extra cloth for some ink spillage. Using the tweezers, lift up the pads sitting on the rubber retainer. The pads can be easily clean by placing them under running water. Use warm water to remove the ink from the pads. Dry the pads and reinstall them. Same procedure if you are installing new pads.
However, the problem will not be solve especially if you are currently facing the waste ink absorber full error or E-27.
Reset Waste Ink Counter Canon Pixma MP210 and Canon Pixma MP220
1. Start with printer off
2. Press and hold resume Button (triangle in the circle) and click "Power" button. green led should be on
3. hold the Power button, release Resume Button.
4. Without releasing the Power Button, double click "Resume" button and then release Both Buttons.
5. Click "Resume" for four times then click "Power" button, to confirm the selected action (reset counter absorber).
6. Turn off the printer and turn on again
Please rate this solution. Let me know if you have any more questions. Thanks.
May 30, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Locate waste ink absorber pad
canon pixma ip1000 printer, how do you access and clean waste ink absorber pad
Apr 13, 2010 | Office Equipment & Supplies
Waste ink full?
Jan 28, 2010 | Canon PIXMA MP170 All-In-One InkJet...
If ink absorber is already full what should i do next?
it is not possible for you it is the problem mantainence wast tank full it mean when we print then chack cartridge is automacily clean then some ink fall under pad this pad is full ink then machine say ink absorber tank is full
you go to aservice centre only support printer canon. Thy clean wast tank and reset your printer
Jul 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
220 people viewed this question
old marine
old marine
