Question about Furniture
Chair stopped working, husband in reclining position and it was hard to get him up he has Parkinson's and not fun.I was on the phone and they never got back to me.
I need help! The chair stopped in the reclining.My husband has Parkinson's. I put batteries in, not.
SOURCE: The recline on my power seat stopped working
I just bought a 2005 Nissan Altima that had the same problem. The motor was fine. I opened the switch and found that a trace on the small circuit board was cut/missing. I soldered it on the spot and it solved the problem. You can access the switch by carefully prying off the switch buttons, then the plate. There are two screws that must be removed so that you can pull the switch assembly out of the seat.
Posted on Aug 02, 2009
  • 232 Answers
SOURCE: Battery fully charged chair levers engaged to
Has your scooter been sitting idle for several weeks, or has it been connected to the charger 24 hours a days for a long time? If so, the batteries may have become damaged and will give you enough power to turn the controller on but not enough to make the motors run.
If the lights come on and are steady, the manual brake levers are in the drive position and the chair still will not move, I recommend replacing the batteries. If anything else were wrong, either the lights would flash or not come on at all.
I hope this information is helpful to you, good luck!
Posted on Dec 27, 2010
  • 31 Answers
SOURCE: Invacare power chair model #1089384;
Hope you have had this fixed by now. But in case not and you are not able to use the chair.
If the chair still drives it's not batteries. The toggle switch box should be ok if there is no visable damage to it. Bad connections of the wiring from the toggle switch box to power or the recline or tilt motor should be inspected. A electronic tech is needed for most electronic failures.
Posted on Apr 07, 2011
  • 1622 Answers
The best thing to do in this situation is to call the vendor and have them repair it under warranty. There should be no charge for this service since the chair is brand new.
There are some checks you can make to avoid a service call. You have checked the batteries and hopefully the chair is plugged into the wall outlet. It is possible that something got disconnected under the chair. To check this you need to flip the chair over on its side or on its back since the leg rest scissor mechanism is extended. Look for any plugs that have come apart at their connections. Check for a pinched or binding scissor mechanism or tilt frame parts.
You should not attempt this at all if you cannot safely move a large piece of furniture. Perhaps a friend or relative may be able to help.
Insist that the vendor honor their warranty commitment ASAP. If you paid with a credit card, you should contact your credit card company to put the amount in dispute if the vendor is unresponsive. Hope this helps.
And you can troubleshoot with the below instructions if it with also help
things you'll need:
* Pride chair Owner's Manual
* Screwdriver
* Wrench
* Pliers
Look at the chair's electrical plug, as the chair most likely became unplugged or the plug is not fully connected to the outlet. If this is the case, securely reconnect the plug.
Check the chair's connections. The electrical connections under the chair could be loose or connection cables could be pinched or bent. Tighten loose electrical connections with a small screwdriver and straighten bent or pinched cables.
Check the chair's transformer, motor and relay box under the chair as a malfunction in any of these could cause the chair to stop working completely. The hand control used by the operator to change the chair's position may also be malfunctioning.
Test the chair's wood frame, bolts and lift frame. Loose wood frames or bolts, overly tight bolts or the lift frame rubbing against the wood frame will all cause the chair to squeal.
Lay the chair on its side and check the wood frame and t-bracket. If the wood frame is rubbing against the lift frame or the t-bracket is cracking, you could hear popping noise. The t-bracket is the metal frame on the underside of the lift chair.
Check the dual motor timing if the chair will not recline all the way. The motors' timing could be off which would stop the chair from completely reclining. Put the chair on its side and remove the motor and plug it in. Use the hand control to turn the motor on and let it run until it stops on its own. Screw the push tube, located to the right of the drive tube where you just removed the motor, until you feel it bottoming out. Turn the push tube back two turns and grab the push tube. Turn the unit on with the hand control and allow the push tube to move away from the metal casing. Push the pin at the back of the push tube and reinstall the motor. This should re-time the motor.
Look at the wood frame, seat foam, leveling legs, motors and bolts if the chair is crooked. The wood frame could be twisted, the seat foam may be broken or misshapen, the leveling leg may need adjustment, the motor could be timed incorrectly or the bolts could be loose. If all looks in order, make sure the ground under the chair is level.
Unplug the chair before you begin fixing the chair.
Restore power to an inoperable lift chair. Ensure the circuit breaker box is connected to the electrical outlet. Make sure the external transformer is plugged directly into an electrical outlet.
Fix a Pride lift chair that only operates in one direction. Use a cotton swab to remove dust and debris from the toggle switch on the hand control. Flip the toggle switch back and forth to loosen any remaining debris which may be causing an obstruction.
Fix inoperable heat and massage features. Check the LED lights on the hand controls; the LED display is not lit, hand-tighten the connection between the hand control and the lift chair. Make sure the the heat and massage units are properly connected to the back of the lift chair.
Posted on May 02, 2011
  • 3 Answers
SOURCE: I have a quantum 600
I'm having the same problem with the red light on my Q6000Z PC not going out, no matter what position that the seat is in. Yesterday I lifted the seat to change my furnice filter and when I lower the seat light wouldn't go out and the chait would not move. and yes I did try going up and down several times. I do have a Quantum joystick controler, but I don't know how to use it. Can anybody help me? Or at least give me a website name where I can go to fond out.
Posted on Dec 16, 2012
Re cliner foot rest wont open need digram to fix
How to Fix a Reclining Lounge Chair - DIY Recliner Repair ...
? 2:28
May 29, 2012 - Uploaded by How to... Science, Craft Plus Other DIY Fixes
Is your footstool not working / not rising up? ... How to Fix aReclining Lounge Chair - DIY Recliner Repair - Fix a Broken Plastic Foot Stool Lever ... Hi there any ideas on how to fix the back of the recliner its stuck in open position? I have removed it and the steal bars that the back attaches to wont align ...
Recliner Mechanism - YouTube
Dec 19, 2015 | Health & Beauty
Why doesn't power button work?
You will have to turn that bulky recliner on its side or even upside down to get access underneath. Inspection may reveal that the real problem is damaged or disconnected wiring but it may turn out that the switch is defective and will have to be replaced.
Sep 06, 2015 | Furniture
My wheelchair's green light doesn't come on after I return from my reclining position
Contact Pride for a manual, you'll need one. Or a Wheelchair/ medical equipment outfit.
Aug 02, 2014 | Pride Health & Beauty
The spring snapped on lafer recliner chair
I bought replacement spring at Lowes
This was Hillman brand replacement spring
Five eight x three and a quarter x 072 inch type
2 springs per pkg works great
Apr 06, 2013 | Lafer Kiri Recliner Chair Cherry Red,...
How do i recline the Peg perego Prima Papa high chair?
Lift up on the handle in the middle on the seat back. There are usually 4 stops along the way from upright to recline.
Feb 22, 2013 | Peg Perego Prima Pappa High Chair
We live in a small apartment but would love to have a recliner to sit back and relax on when we come home from work. Is there such a thing as a smaller sized recliner that will not be as bulky and can fit...
Yes, you can a wide variety of small sized designer recliner in one of the best reputed place which is Loveseat Recliner.
Some of the attractive recliner available here are:
e. ZERO WALL RECLINER CHAIR, and much more.
Aug 09, 2012 | Furniture
What are the different types of leather office chairs?
Here are some of the most recommended recliners that would allow you to have a comfortable seat in office.
These reclining chairs are made up of best quality materials and are available at the cheapest price on Rise and recline chairs.
Some of the best available recliners available here are:
Jul 30, 2012 | Furniture
Furniture Logo
143 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
