Question about Philips Cameras
How to delete internal memory on spf3419/ G7 Philips digital photo frame
4 Suggested Answers
pauman
  • 248 Answers
SOURCE: Philips digital photo frame 7FFI series
Here`s a tip i found for you...
1. Connect the frame to your PC using the supplied USB connector. Navigate to the \DCIM\100Frame directory and delete all the Phillips advertising pictures there.
2. Create a directory on your PC and put copies of all the pictures you want to display there.
3. Download the free picture resizer utility from Microsoft at:
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
(Look for Image Resizer in the right column). After installing it, "Select All" pictures in the directory you created, then right click and select "Resize Pictures" from the context menu. Choose the 640x400 radio button. Sort by size and copy all the small ones into the "\DCIM\100Frame" directory on the frame drive (Called Removable Disk on my PC).
Posted on Jun 20, 2008
SOURCE: Saving photos to internal memory on ultech digital photo frame
go to http://camera.manualsonline.com/ex/thread/view/idthread/1339017
lots of good instructions, I got mine working already
Posted on Feb 01, 2009
SOURCE: I have a SPF3410/G7 Digital Photo Frame and have
Format with fat32. Problems with filenames and block sizes. fat16 is 20 something years old.
Posted on Dec 31, 2010
Philips Photo Frame SPF3407D/G7
It could be why. I do not see where the manual says it is compatible with MAC, only pictures form an industry standards photo, etc..
I would at try ensuring they are saved in jpg format from a pc then.
Better yet, move the pictures that work to a folder called work so only the other pictures that do not are on the memory device then see if they work or not, if not reconvert them.
you ca even email phillips and see what they say:
Visit the support page for your Philips PhotoFrame SPF3407D G7
Mar 26, 2017 | Cameras
Can't delete photo from frame's internal memory
Select play photo files on the camera. then hit the trash can logo, delete them from there.
Jun 22, 2017 | Cameras
SPF3400C/G7 Philips photo frame not working
Had same problem. This is what I did to fix it:
1. Replace internal 3v Battery (requires soldering)
2. Re-flash photo frame with "SPF3400C upgrade" software available at Phillips support website.
3. Power cycle.
BLUXtech
Dec 31, 2011 | Philips Cameras
I want to add pictures to my philips digital frame model number spf3407d/g7 I have misplaced my manual I can get to to show up on frame but it wont save them
This works when using memory cards or USB flash drives. Turn on the frame. Insert card/flash drive. Screen should come up asking if you want to add photos to internal memory. You will have 15 seconds to respond. "No" will be highlighted. Press "left" (<) arrow button to highlight "yes". Press "OK" button. Frame will begin importing all photos on the card/flash drive.
Sep 04, 2011 | Philips Cameras
I have a Philips PhotoFrame - SPF3408/G7 (SPF3408T/G7). When plugged in no picture comes on screen. Screen does not light up. I viewed pictures yesterday - but - I don't get anything today. I know...
Keep in mind that Digital Photo Frame can display the same photo continuously for 1000 hours without any damage to the LCD screen.
If you can enter to the settitgn menu, first make sure the system is properly powered. Then use a pin to trigger the reset button located on the side of the power button on the back to restore the system...
If this isnt work try...
  1. Load all the photos you want to upload to the Photo Frame in the root directory of your memory card.
  2. Power off your Photo Frame by pressing the Power button.
  3. Insert the memory card into the slot in the frame.
    A For a Compact Flash card, firmly slide card in the larger slot end first and face down.
    B For an xD, SD, MMC, or Memory Stick card slide card in the smaller slot end first and face up until it locks into place.
  1. Restart Photo Frame by pressing the Power button.
  2. After a few seconds, all photos in the root directory of the memory card will be automatically added to Photo Frame. The root directory on memory card will not be emptied after this operation.
    Please do not remove the memory card just after inserting it in Photo Frame or when Photo Frame is counting the Photo.
    Wait until the screen is stable.
    NOTE: This operation does not apply to photos in sub-directories.
If anyone of this procedures work fine, I suggest contact your local service (check if even is underwarranty).
Good luck.
Jul 05, 2011 | Video Game Consoles & Games
I just bought a digital photo frame for my husband for christmas and i get so many pictures downloaded...then it just stops and says insufficient memory card.....i thought there was something wrong with...
I'm pretty sure this means that you have filled up the internal memory on the picture frame.
I just bought my sister a photoframe for Christmas (made by Phillips) and we got the same message. Not the most precise wording on the error message, but we tried deleting a few photos and the error went away. Then I checked the internal memory of the frame, and it is only 128M, which is not alot of photos.
I think the solution will be to buy a USB memory stick to leave in the frame. For about $10 you can get a 4G USB memory stick, which is about 32 times the space of the internal memory, at least if you have a similar model as we do.
See here: http://www.amazon.com/USB-Flash-Drives-Storage-Add-Ons/b?ie=UTF8&node=3151491
Dec 23, 2010 | Philips Cameras
I have a SPF3410/G7 Digital Photo Frame and have 210 pictures on a 4 GB memory card in it and it keeps stopping on picture # 80. Why is this? We have deleted all pictures on the internal memory.
I have one of these. Got it for Christmas. It worked all the way to February. Nothing but the Philips logo now. Wont boot. JUNK. Never buy that brand again!
Jan 14, 2010 | Philips PhotoFrame -10 Digital Picture...
I have bought the philips 10.4 inch digital photo frame and im trying to put pictures on it and store them in the internal memory. When i put my card in it starts to install them but then says not enough...
Tough the picture frame states 1000 photos, it really depends on the size of the picture. To resolve this purchase a 2 or 4 gb memory card and download your pictures onto the card. You can insert the card in the slot of the picture frame and then connect to your computer and download your pics from your computer directly onto the memory card.
Dec 14, 2009 | Philips PhotoFrame -10 Digital Picture...
Was given digital picture frame . have no cd manual. haS 22 PICTURES ON IT .CAN I PUT MORE? MODEL NO. 7FF1
It depends on how big the existing pictures are. It has a 14MB internal memory, but it says about 12MB for storage. You can buy memory card to insert into the frame but it will not display internal memory once you insert a new memory card. If you bought a 512MB card, you could put hundreds to thousands of pictures in JPG format. You can hook the frame to your computer or directly to a digital camera. From the computer it takes a few seconds to convert the pictures. The frame will show up on your PC as a mass storage device and you will be able to delete photos as well.
I hope this helps
Dec 05, 2008 | Philips Televison & Video
Cameras Logo
83 people viewed this question
Top Philips Cameras Experts
Are you a Philips Camera Expert? Answer questions, earn points and help others
