Question about Locks & Locksmithing
How can I open a yescom wall safe in which the key is locked inside and no code has been programed in yet
    New Friend:
Hi, One of my friends working in the hotel had told me about how to program Hotel Room Safes code. As you locked the key inside. Try to program the code. Press the red button on the back of the door near the hinge, release it and you will hear two beeps. After that, enter a code that you wish to use as a combination, and confirm by pressing the button.
Now try to open the safe, enter your combination code and confirm by pressing the button. You will hear a beep and the green light will light up. Within 5 seconds, open the door using the knob.
Posted on May 10, 2017
How to change code N15115
Input the new code (1-8 digits then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again Emergency Key - store in secure place NOT inside the safe. To ensure the batteries have been installed correctly test before closing the door. 2 bolt locking mechanism, opens with a digital code or emergency key. Floor or wall mountable, immediately locks out after 3 invalid code attempts. Durable steel construction, model Name 24/7 Digital Safe, material, galvanised steel. Opening the safe a. Pre-set factory code 159 b. Input 159 (the yellow light will flash and the buzzer will beep then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened Closing the safe: close the door, input the code (the green light.
Feb 01, 2015 | Home Security
Change code on Futura wall safe
Refer this problem to Futura
May 24, 2013 | Locks & Locksmithing
Can't open safe, locking mechanisim broken
wont hurt to ring the safe maker or a locksmith
for a second opinion
Mar 29, 2017 | Home Security
I MISTAKENLY LOCKED UP MY SAFE KEY INSIDE THE LOCK AND THE BATTERY IS TOTALLY DEAD ,PLEASE I NEED HELP
you would need to hot wire the batteries for the code to work but if the batteries have gone flat then it needs to be re-programmed again ,only one soloution here and thats to open it with a radial cutter
Nov 20, 2011 | Locks & Locksmithing
Just put new batterys in safe . but safe will not stop bleeping what is the problem
Please follow these steps
Programming a user code
There are two ways to program a user code.
A 1. Press the Program key.
2. Enter the Factory Code. The green LED remains ON
while you enter the 5-digit user code of your choice.
After 5 digits are entered the green LED turns OFF.
(To enter a new User Code, repeat these steps.)
B 1. Press the red button inside the safe. The lock will
beep and the green LED will come on.
2. Enter a 5-digit user code.
Keep your new user code secure.
For your records, please copy it here:
____ ____ ____ ____ ____
Programming a password
2. Press it a second time.
3. Enter your 5-digit User Code. The green LED remains ON.
4. Enter the 5-digit Password of your choice (any combination
except 00000.) After 5 digits are entered, the green LED
turns OFF.
(To enter a new Password, repeat these steps. To erase the
Password, press Program twice, enter your User Code and then
enter 00000.)
Battery replacement
Below When old batteries are removed for replacement, your Password will be voided; only Factory and User Codes will work. To
reestablish your Password, follow the directions above under
Programming a Password.
Key override
If your electronic lock fails or you do not have any codes
available, you may use a key override to access this unit.
1. Remove the battery cover, disconnect and remove the
battery holder.
2. Insert the skeleton key (second set of keys provided)
into the key hole inside the opening for the battery.
3. Turn the key to the right.
4. Turn the four bit key to the right.
5. Open the door.
Signals
Your electronic-lock safe communicates by means of several
audio/visual signals.
Red (Error) LED + three beeps indicates
one of the following:
1. You have pressed Program key out of sequence
2. You have entered an invalid code or password.
3. You have let 5 seconds or more elapse between key entries.
Green (Proceed) LED + single beep occurs
1. After entering each digit of Factory or User Code, or
Password
2. After pressing Clear key
3. After pressing Program key
Green LED only
1. Comes on after you enter a valid code/password and
remains lit during the 4-second period in which the safe
can be opened.
2. Comes ON in the Program User Code mode after you enter
the Factory Code and remains lit until you have finished
entering a 5-digit User Code.
3. Comes ON in the Program Password mode after you have
entered your User Code and remains ON until you have
entered a 5-digit password.
Yellow LED
Indicates low battery and will typically not turn ON until
battery has been in use approximately two years or longer.
Your electronic lock automatically performs a low battery test
during each lock use.
If a �low battery� condition is detected the Yellow LED will
come ON and remain ON during each subsequent lock
operation. (The lock will continue to function in a Low Battery
state, until battery failure.) The Yellow LED will turn OFF only
after three consecutive Good Battery readings or after the low
batteries are replaced. (Note: If the new batteries are installed
in less than 60 seconds the Yellow LED may come ON and stay
ON during the first lock operation before it returns to OFF.)
NOTE: It is recommended you replace the batteries after two
years, or when the yellow LED remains on.
Jan 09, 2011 | Safe International Electronic Digital Safe...
I purchased a new Sentry Safe, Model CSW 4747 yesterday. When I unboxed the safe, the safe was open, the lock handle was down, cyclinders were a little pertruding, and the lock cyclinder was popped out. ...
(1) sounds like the interior lock activation screw is still installed. it's the long screw on the inside of the door with the yellow tag; (2) when entering the code, make sure the key is turned to the right; (3) after entering the code, make sure you next press the program button. enter the code wrong three times and it locks up for two minutes.
Sep 11, 2010 | Office Equipment & Supplies
How to set up th ebatteries in my sentry safe DSW5781?
Locksmiths agree
1. Remove and discard the screw (if
equipped) at the base of the lock case.
2. Turn the electronic lock case to the
right (clockwise), from 12 o’clock to
2 o’clock, and remove.
• Insert 4 new AA batteries (not included) to power
this lock.
• Replace the electronic lock case and turn to the
left (to 12 o’clock) to reassemble.
NOTE: The yellow LED will light when the batteries
need to be replaced.
3. Turn the key (if your safe is equipped with a key
lock) to the right so the lock cylinder pops out.
4. Enter the factory code. When the green light appears, you
have four seconds to turn the handle down to
open. Try this several times before proceeding to
the next step.
To unlock safe:
Enter the 5-digit factory code, a pre-programmed
user code, or a pre-programmed user pin
programming instructions. When the
green LED lights you have 4 seconds to turn the
handle and open the safe.
To lock safe:
Close the door and return the handle to the
horizontal position. For greatest security, depress
the key lock (if equipped) with your finger.
Aug 15, 2010 | Sentry Fireproof Safe
Detroit electronic digital safe lost code and keys
Help, just boughta Detroit digital safe, code number to open my instructions are locked inside.
Feb 19, 2010 | Sentry Fireproof Safe
I forgot the safewell electronic code and didnt have the key
NOTE: The safe needs to be upright and right side up or the locking mechanism
won’t work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad –159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter “B” on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell sales@safewellsafe.com
Good luck
Sep 14, 2009 | Locks & Locksmithing
I cannot open safe with the usual code.Safeguard electronic digit
To open a Safe International Digital Electronic Safe
User override key to open safe
Then:
a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
c. To change code repeat step a.
Test your new code before closing safe.
Apr 27, 2009 | Safe International Digital Electronic Safe...
Locks & Locksmithing Logo
371 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
