Question about Garden
LGT2654 with Kohler engine. need oil filter 25 50 40 ... having some challenges finding in on line.
  • 373 Answers
SOURCE: oil filter locatin tdci engine
Did you try auot zone
Posted on Feb 08, 2009
rockitman187
  • 2559 Answers
SOURCE: need drive belt diagram for LGT2654 Huskee
Here is a link to the manual on pages 7, 8, and 40,
Please take time to rate this a fixya
Posted on May 10, 2009
  • 7 Answers
SOURCE: oil leak around the oil filter
the oil filter is either cross theaded or the filter is not tite enough
Posted on Jun 27, 2010
ginko
  • 19396 Answers
SOURCE: Husqvarna riding mower w/20 hp
Hi.
There is gas smell in the carburetor because the engine is not starting and carburetor is flooding.
As first thing ensure that there is spark, pull the spark plug wire and put the end near to engine block while cranking. You will see the spark. If there is no spark, check distribution coil and wires.
If there is spark, check if there is fuel pressure, if there is smell from carb, then the fuel pressure should be Ok.
Once you are sure that the pump is doing its job, and that there is pressure, check the carburetor settings. The mixture is probably too rich or too lean, and for that reason it is not igniting.
If it is not a matter of carburetor settings, then the carb must be taken apart to check carburetor filter.
To get parts and diagrams see: Outdoor Distributors - Lawn Mower Parts
Posted on Sep 26, 2010
  • 6468 Answers
SOURCE: I have a troybilt lawn tractor with a Kohler SV590-0016 engine and is just stopped will cutting the lawn. I have replaced the spark plug, coil, oil filter, oil, replaced gas and still does not start,
are you getting spark?is the fuel getting into the engine
Posted on Apr 21, 2012
Kohler Command 14 OHV, Simplicity, riding lawnmower. oil is mixing with gas and blowing out valve cover breather tube and into air filter chamber. What's wrong?
The needle and seat in the carburetor are not sealing. If you don't want to have the carburetor rebuilt what you need to do is change the oil and install an inline fuel shut off valve in the fuel line so you can turn the gas off when the mower is not running or in use.
Apr 17, 2016 | Garden
Leaks oil out left side of engine,can not figure where it is leaking from
check valve cover gasket, first clean all oil off engine with brake clean or similar then start it up and look closely around the valve cover on that side
Aug 09, 2015 | Husqvarna LGT2654 54 inch 26 HP Kohler...
Trying to find oil filter that can be found locally from car part supply store.
take the old filter along to the spares shop and see if they can match it up
I suspect that the same filter will fit both engines
if you want to get technical, use a verniers to measure the thread hole diameter, a thread gauge to get the thread pitch, and the outside diameter of the oil seal
by going to oil filters manufacturers on line and researching their catalogues you will find pages of filters with dimensions that will match you filter
I would rather just go and buy a genuine filter from a mower shop or kohler dealer as there may be a generic filter already listed.
May 05, 2015 | Generac Electrical Supplies
Oil is pumping into the carb adn air filter of my kohler 2 cylinder workman engine
Make sure you have good compression. Sounds like you have blow-by. Crankcase vents into the air box.
Aug 21, 2014 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Will stp s3512 oil filter work for rz5426 husqvarna?
Husqvarna always recommends using the factory approved oil filter. These have the correct micron for filtration, they also have check valves if needed. The filter may attach but may not filter correctly.
Aug 08, 2014 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Replcement oil filter husqvarna model ltg2654
their are a few different filters for your rider --these are for the kohler 26 hp motor stores like home depot- lowes- sears- or small engine repair shops carry filters K&N PS-1002 http://www.sears.com/ayp-genuine-ayp-part-578416804-oil-filter-kohler-cou/p-SPM8242278631?redirectType=SKIP_LEVEL http://www.knfilters.com/oil_filter/all/kohler/sv735/26hp
Jul 10, 2014 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Can the overhead valves on a 16hp sears craftsman with a kohler engine be the reason why it won't start and if so, can I adjust them
Valve clearances will also effect the decompression valve in the engine, if they are too wide the valve lifter will not work and the battary will not have enough energy to crack the engine.
Jun 27, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Lost owners manuel and need to know what type of engine oil to use for a Husqvarna 25-HP V-Twin Hydrostatic 54" Garden tractor
if engine is briggs use briggs sae 30 oil also change out filter use briggs black std oil filter or yellow filter if els version
if engine is kohler use kohler 10w/ 30 oil and use kohler oil filter
if its honda use 20w/50 oil and use honda oil filter
if its kawasaki use 20w/50 and use kawasaki oil filter
cheers pauly 46
Mar 26, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Can some one tell me what oil and air filter to buy for a Kohler 12res LPG generator?
Lowes sells air filters for Kohler engines . As far as the oil a SEA 30 or 10w 30 would be fine.
Dec 01, 2010 | Kohler 12 kW Emergency Power System -...
Husqvarna LGT2654 with Briggs & Stratton Intek Engine won't start
If the fuel line is dry after the fuel pump its usally the diaphram thats stuffed does it have a fuel tap in place? is it off? also i know with nem mowers just been come over from freight the fuel filter is full of oil for the first start up as the valves need lubrication first startup... take the fuel line off from the carb just have it hanging down for a start, then crank the mower over, you should then have fuel coming out of fuel line by then... see if that helps jay QLD AUS
Feb 24, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
