Question about Filter Heating & Cooling
I have a ritetemp thermostat model 8085 cannot turn set temp down, it just goes up so I put the switch on cool and place the other to on. What is wrong? I also replaced filter about a week ago?
  • 109 Answers
SOURCE: ritetemp propane log
your pilot assy is clogged, disassemble the pilot assy completely and inspect the orifice. there should be a tiny pinhole in the end of the orifice, clean well with small wire brush and reassemble, don't forget to clean the thermocouple while you have the assy out.
Posted on Mar 30, 2008
  • 110 Answers
SOURCE: 96 honda civic lxi overheating.
The car is not overheating if the temp gauge goes up and down by turning the lights on and off.  The gauge is giving you bad information.   You can confirm this by starting the car from cold, sitting in the driveway, let the temp go to somewhere BEFORE normal operating temp, then turn on headlights and fan blower on high, watch the gauge, then turn them off.   If the gauge moves significantly from the electrical load, you probably have a short or a bad ground connection.
You have a short circuit or bad wiring somewhere in the front half of the car.  I don't know what thermostat switch you have replaced ... but it's not the problem .. stop buying them.
If you are the original owner, was there an accident that may have damaged some wiring?  If you bought the car second hand,  get a carfax and find out where the thing was hit ... concentrate your wiring trouble shooting in that area.
I think it is something OTHER than the temperature sending unit or the gauge
Posted on Oct 29, 2008
farfield
  • 462 Answers
SOURCE: No cool air. Thermostat AUX light turned on
I suggest you call a qualified service repair man. There are as many ways to connect a heat pump as there are people doing them. Nothing is standard industry wide that has anything to do directly with color codes, so it would be meaningless to go into them here. The terminals may be adapted to standard but but the thermostat manufacturer may not follow any terminal designations.
However you may just have an extra wire touching one of the terminals inside the thermostat. You can check this by removing the cover. Look where the wires attach to the terminal screws on the thermostat. Sometimes a new service person cuts the insulation back too far here or in the outdoor or indoor units and a "whisker" from one wire can touch the other terminals. A whisker is not the normal case try and move it away from another terminal if its is touching there. However, you may have jumpers in place especially if you have W, W1, W2... at any of the 3 sections, meaning the outdoor, indoor and thermostat.
If you can tell me the terminal designations R,Y, W1, W2, E, G, O, (B)... at the thermostat and the color thereon each, then at the indoor unit terminals or wire designations and the color there, then at the outdoor unit and the color thereon each terminal or wire designation there. I might be able to help if the above whisker check you don't find anything.:
Posted on Mar 25, 2009
longbranch1
  • 16 Answers
SOURCE: We have an older model (58SG100251) installed in the attic. With the thermostat set & turned on nothing happens. A new blower motor was installed last year.The t/stat is a ritetemp digital. I,ve c
Possible fan relay is defective, does outside unit come on ?
Posted on May 21, 2009
  • 16 Answers
SOURCE: 1996 Grand Prix SE, cooling fans inop
try the fuse,if not that the wiring is bad from the fan to the switch.
Posted on Jul 13, 2009
I have a ritetemp 8082C, how do I open it to replace the batteries?
To replace the batteries in the Ritetemp 8082C thermostat, first switch the Mode switch to Off and the Fan switch to Auto (if they aren't currently in that state). Press up on the catch on the bottom of the thermostat and swing the body of the thermostat away from the back plate on the wall. The lift up to remove the body of the thermostat from the base. Turn the body of the thermostat over to see the battery compartment at the top of the back of the thermostat.
This is shown in the installation manual in different sections. Removing the body is shown on page 3 (page 4 of the PDF). Changing the batteries is shown on page 6 (page 7 of the PDF). Ritetemp has the manual here: http://www.ritetemp-thermostats.com/80XX/images/8082C_installation_guide.pdf .
I hope this helps.
Oct 28, 2017 | Heating & Cooling
Ritetemp model 8050c if i set temp. To 74 it goes up to 82 and beyond in minutes or hours. How can i set it to stay where i want it
While in heating or cooling press the temp hold button behind the door. Hold will be displayed rather than p1, p2 p3 or p4.
Jun 14, 2017 | Heating & Cooling
Ritetemp model 8050c i have to reset it 8-10 times per day if it is set on 74 the setting will always go up to 82 and beyond.sometimes it will go up in minutes How can it be set to stay where i want
Are you using the "Temp Hold" to hold your temp at that temp or changing it without opening the panel?
(To change and hold the temperature until you return. .Open the door and push the TEMP HOLD button. The HOLD icon comes on. Push the UP or DOWN arrow buttons to set the hold temperature. .HOLD is canceled if MODE switch is moved, or by pressing TEMP HOLD again.)
~Eddy
Air Conditioning Repair Tamarac FL
My Ritetemp thermostat keeps going into override and blowing cool air when the heat is supposed to be on. Anyone know what im doing wrong?
Rite Temp thermostats don't usually work buy a Honeywell thermostat and wire correctly or call a tech. Be sure and mark original wiring or you will need to call a tech
Nov 13, 2014 | Heating & Cooling
Overheating
do a full system flush on the radiator and engine and the lines to the heater. flush them out. also change the thermostat and the temp switch, the temp switch sensor is the one with only one wire on it with either a 11mm or 13mm head on it depending what one was fitted. after it is flushed reconnect the pipes add the water and antifreeze, when all clean in the system the water should come out clean. 50/50 water antifreeze should be used. leave the top off the header tank and run the engine with the heater on number one. keep squashing the pipes as the engine warms up to help get the air out and keep the header tank full to the top. when the fan kicks in to cool the rad turn off the engine and leave to cool down when cool top up to the line and put the cap back on. wile you are doing the bleeding you should see the temp go up. if the heat goes to or above a 100 and the fan does not come on then the fan switch or motor may need changing, thermostats last for around 5 years, temp switches can last up to 5 years temp switch for the fan can be around 3 to 8 years.
Mar 07, 2014 | 1992 Subaru Legacy
Housesitting. RTH111B model. I cannot keep the
That is a NONprogramable T-stat. There is no program to overide, therefore there is no need for a "hold" option. To set the temp, place the switch on the side marked
COOL
OFF
HEAT
to the desired setting, and push the up down arrows on the front until the display shows 80.
The DISPLAY will revert back to the current room temperature within a few seconds, and will keep the unit on until it reaches the desired temp.
The set temperature remains at 80, it just shows the current room temp.
Aug 31, 2009 | Heating & Cooling
Rheem furnaace blower stays on
On a furnace the fan is controlled by a computer and a sensor ot a oldstyle fan thermostat. Basically it waits till the furnace heats up a little and then turns it on and after it shuts off it will run till the thermostat cools back down may take a few mins. In cool mode the thermostat controls the fan so it shuts down immediatly. This is why the thermostat asks you if its electric or gas heat. Should have a switch somewhere for this.
Nov 19, 2007 | Heating & Cooling
Heating & Cooling Logo
43 people viewed this question
Top Filter Heating & Cooling Experts
MightyMikeJr
Vernon Taylor
Are you a Filter Heating and Cooling Expert? Answer questions, earn points and help others
