Question about John Deere Garden
My john deere 525 clutch will not disengage - John Deere Garden
SOURCE: JOHN DEERE TRACTOR - MODEL A - SERIAL 642202 CLUTCH REPAIR
Try the John Deere web site, I think they will be able to help. donnyb60
Posted on Mar 21, 2009
  • 641 Answers
SOURCE: john deere model 14sb lawn mower repair
Check for bad bearing in clutch immediately, Remove belt, try and turn the clutch pulley if it is hard to turn or feels rough, replace the bearing in the clutch. If you do not replace bearing immediately you will be buying a $300.00 clutch very soon. I know from experience. You possibly have been hearing a loud unusual roar from engine area for awhile and wondered where it was coming from. As these bearing will usually squall a cry for awhile before they die.
Posted on Mar 28, 2009
  • 153 Answers
SOURCE: Dies when clutch disengaged
It sounds like the seat switch is disconnected or failed. Check it out. If it thinks there is no **** on the seat it will cause your symptoms.
Posted on May 26, 2009
  • 10865 Answers
SOURCE: John Deere LA110 mower blades got disengaged
yes. your mower has a blade engagement cable attached to the drive sheve. i am providing a link to the manual which shows this.
http://manuals.deere.com/cceomview/OMGX22464_C8/Output/Index.html?tM=HO
Posted on Jun 25, 2009
mowerman1857
  • 389 Answers
SOURCE: my john deere riding mover the clutch will not
With the engine OFF, reach underneath and locate the plug for the blade clutch and unplug it. Start up the mower and see if the blades are turning. If they are still turning with the clutch unplugged, REPLACE THE CLUTCH
Posted on Oct 04, 2009
REPLACE THROTTLE CABLE ON F-525 JOHN DEERE
John Deere Throttle Cable Repair
The above is probably not for your model of John Deer. You can get an exploded view of the section for your model on http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
There, Enter the Model Number and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. You can Drag the View Windows for Better Viewing.
Jun 11, 2017 | John Deere Garden
Is there any adjustments to the electric clutch on a 2007 John Deere X340? I have a slight noise issue when the clutch is not engaged.
There is no adjustment but the clutch does have a bearing in it that rotates only when it is disengaged. This may be what you are hearing.
Jan 09, 2017 | John Deere Garden
Why does one blade spin after mower is stopped on my John Deere LA135?
check your blade brake for that blade,supposed to rub against top blade pulley when blades are disengaged,if its a manual engage vs electric clutch
Jul 30, 2014 | John Deere Garden
How do i adjust the clutch on a 1966 john deere 3020
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Sep 18, 2012 | John Deere Garden
My 870 john deere clutch will not disengage. The
This is common for the 70 series.Clutch dics are stuck together,just short of splitting tractor you have to hit a pile of dirt with loader bucket to see if you can break it loose.
Sep 25, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Pto spis all the time on my 1989 john deere 420
Are the blades turning? If they are not, this is normal. The PTO is an electro magnetic clutch that engages when you apply electricity via the PTO switch. When it is disengaged, the bearings and top portion of the clutch will turn because it is coupled to the engine. If the blades ARE turning then you have a bad clutch and will need to repair or replace it
Sep 18, 2009 | Garden
Jun 25, 2009 | John Deere 420,1020,2010,2020,2510,2520...
May 25, 2009 | John Deere Garden
John deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Mar 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
29 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
