How come my temp arrows on touch screen will only go up?
Ritetemp 8085 thermostat
3 Suggested Answers
SOURCE: ritetemp 6022 programmation manuel Where can i
when the furance turns on it never shut off. how can I fix this.
Posted on Dec 18, 2009
  • 43501 Answers
SOURCE: TH8320U1008 Honeywell touch screen thermostat temp
Whoa, that stinks..... I think that is the first problem I have seen with those t-stats... they are very dependable....
I would take out the batteries and let it die for about a day....I think it takes that long for the capacitors to fully discharge... Don't know what you will do for heat while your doing that, unless you know how to jumper the furnace... R-W on the circuit board will get you heat....
Then reinstall the batteries and the t-stat and see if it comes back....
Oh and make sure you also leave it off of the wall so it don't get power from the furnace either... you want it to completely die... then you will have to reprogram it... so I hope you still have the manual...
Posted on Nov 26, 2010
I have a ritetemp 8082C, how do I open it to replace the batteries?
To replace the batteries in the Ritetemp 8082C thermostat, first switch the Mode switch to Off and the Fan switch to Auto (if they aren't currently in that state). Press up on the catch on the bottom of the thermostat and swing the body of the thermostat away from the back plate on the wall. The lift up to remove the body of the thermostat from the base. Turn the body of the thermostat over to see the battery compartment at the top of the back of the thermostat.
This is shown in the installation manual in different sections. Removing the body is shown on page 3 (page 4 of the PDF). Changing the batteries is shown on page 6 (page 7 of the PDF). Ritetemp has the manual here: .
I hope this helps.
Oct 28, 2017 | Heating & Cooling
Hello, If my batterys go dead on my ritetemp thermostat model 8050c will I lose my program?
I believe it has a limited memory back up but yes you likely will. Does your tstat require batteries or are they there as a backup?
Aug 14, 2017 | Heating & Cooling
Ritetemp model 8050c i have to reset it 8-10 times per day if it is set on 74 the setting will always go up to 82 and beyond.sometimes it will go up in minutes How can it be set to stay where i want
Are you using the "Temp Hold" to hold your temp at that temp or changing it without opening the panel?
(To change and hold the temperature until you return. .Open the door and push the TEMP HOLD button. The HOLD icon comes on. Push the UP or DOWN arrow buttons to set the hold temperature. .HOLD is canceled if MODE switch is moved, or by pressing TEMP HOLD again.)
Air Conditioning Repair Tamarac FL
Jun 14, 2017 | Heating & Cooling
My Ritetemp thermostat keeps going into override and blowing cool air when the heat is supposed to be on. Anyone know what im doing wrong?
Rite Temp thermostats don't usually work buy a Honeywell thermostat and wire correctly or call a tech. Be sure and mark original wiring or you will need to call a tech
Nov 13, 2014 | Heating & Cooling
My Honeywell thermostat won't set the heat above 75 degrees
ok fist thing is to press and hold the middle lower button and the arrow up at the same time and hold until the screen changes to a number. keep hitting next until you see 75 appear then arrow up to the temp you want and press done. That easy!
Oct 24, 2013 | Honeywell Programmable Thermostat Heater
42 people viewed this question
