TV can only be turned on & off by plugging in. It then continues to cycle on & off until unplugged. While on, green static lines are only visual.
SOURCE: RCA 27V412T TV Problem
sometimes its not the connections... but its the toggle switches at fault
Posted on Jul 30, 2007
  • 4402 Answers
SOURCE: Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Posted on Dec 15, 2007
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Posted on Sep 14, 2008
SOURCE: Insignia TV
Ok, I had the exact same problem last summer, and Kevellen told me of a problem that Insignia tv's have: the circuit that controls whether the tv is off or on is messed up, and it can be fixed, but its not cheap.
Anyway, if the t.v. is still under warranty, I would say return it to the store and see if you cant get a new one, and from what I researched online after this incident, I will not buy an Insignia aver again.
hope this helps,
Posted on Jan 04, 2009
SOURCE: New 40 in Dynex having issue
Just got off the phone with Dynex, sounds like a common problem with a recent batch.
Tech support suggested returning the tv to futureshop/bestbuy since I'm within 30 days of purchasing.
Posted on Dec 30, 2009
On my e-motion tv when I switch it on and go onto did it says no please
Why does my TV say no signal? If your HDTV or Standard TV displays a "No Signal" error message, it may be due to one of the following issues:
  1. Determine how many TV's are affected.
    • If it is one TV, continue to step two.
    • If multiple or all TV's are affected, continue to step five.
  2. Ensure that your HDTV is on the same source/input as your MTS Ultimate TV service.
    1. Press the TV button on your MTS Ultimate TV remote control.
    2. Press the TV/Video button.
    3. Wait 10 seconds.
    4. Repeat steps b and c continually to cycle through all the available source/inputs on your TV until the correct source/input is selected. (ie. HDMI 1, HDMI 2, Component 1, Component 2, etc.) On standard TV's (non HDTV), you may have only 2 choices, TV or Video.
  3. If the source is correct from step two:
    1. Unplug the HDMI cable from your MTS Ultimate TV Set-top Box.
    2. Wait 30 seconds.
    3. Plug the HDMI cable back in.
    4. Wait for the signal to initialize.
    5. Make sure all cables connected on the set-top box and your TV are secure.
  4. If the problem persists:
    1. Unplug the power cable from the back of the MTS set-top box.
    2. Wait 60 seconds.
    3. Plug the MTS set-top box back in.
  5. If you are still experiencing a problem:
    1. Make sure ALL Ethernet and/or Coax cables are securely in place.
    2. Unplug the power from the MTS box labeled 2Wire or Pace as well as the affected set-top boxes.
    3. Wait 60 seconds.
    4. Plug the power back into the MTS box labeled 2Wire or Pace.
    5. Wait for the broadband light to turn a solid green colour.
    6. Plug the power back into the affected set-top boxes.
    7. Wait for the signal to initialize.
Good Luck
Feb 24, 2015 | Televison & Video
HTC increase Desire battery life.
<span>Preparing...<br />With the phone in the on position.<br /><br />Fully charge the battery with the phone on... (until the led turns green.)<br /><br />Once the led turns green, unplug the charger until the led goes off. <br /><br />After the led goes off, plug the charger back in. When the led turns green , power off the phone.<br /><br />now.... with the phone fully powered off...<br /><br />1. Unplug the charger. <br /><br />2. Wait until led goes off. <br /><br />3. Plug charger back in until the led turns green. When it turns green, unplug the charger again and go to step 1.<br /><br />4. repeat steps 1 and 3, 10 times. This may take anywhere from 30 seconds to 30 mins per cycle. Typically only about 1 minute. though.<br /><br /><br />DO NOT DRAIN THE BATTERY. The goal is not to empty the battery and recharge like ni-cads (those have memory, these don't). These are lithiums, so we need to do the opposite...</span>
on Jul 11, 2011 | Cell Phones
Green static lines accross tv when switching on then after a while disappears
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 15, 2014 | Televison & Video
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Will not turn on after charging
Sounds like it's time for new batteries.
Jul 18, 2009 | Jet 3 Ultra Power Chair
Problem with HL-R6167W green vertical lines
You need to do an aggressive reset on the TV. This solved problem completely for me. You must unplug the TV when it is on. Repeat this several times until the TV is jolted back into the factory default settings. The issue is actually with the programming I believe. The clue was that the display worked 100% perfect in HDMI mode, and the problem only existed in the cable setting, no matter if wires were attached or not.
Again, do an aggressive reset to the TV by unplugging it several times while it is on. It may not register the reset at first because after all, the actual problem is a programming issue and it's having trouble recognizing commands in the first place.
Good luck!!
May 29, 2009 | Samsung HL-R6167W 61" HDTV
Grey static then flashing button
Could be your flyback transformer or these caps 2200 mf16v 22035v 33035v. Check the caps for bulging.
Jul 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Help me willtab guru man...Please.
What is the make and model of your television.. green tint and vertical lines indicat a problem with the light engine..although the clear menu says not sure what type tv you have. lcd plasma change the light im guessing you mean bulb .. this indicates to me you have a dlp. but green tint to me indicates a tube projection type tv... so im just guessing hear. vertical lines also indicate a bad buffer board on a plasma or lcd. so let me know what you have
Jun 16, 2008 | Televison & Video
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
