Question about Sharp Office Equipment & Supplies
Error code F5 .02 SHARP AR-M 207 HELP TO FIND SOLUTION
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
007tech
  • 95 Answers
SOURCE: Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Posted on Apr 12, 2009
  • 990 Answers
SOURCE: sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Posted on Apr 28, 2009
  • 87 Answers
SOURCE: error code H5-01
HI.H5-01
it shows there is some problem in exit sensor .it is in fuser unit.may be its lever is broken .
sensor is dirty clean it
check lever home position and its movemment
check its cable
reset this code
press ,p,*,clear,*
screen will go dead press 14 ,start code will bi reset
never forget to rate the solution.MIAN AKHLAQ
Posted on May 09, 2009
  • 16 Answers
SOURCE: SHARP ARM 207 ERROR F2 04
Incorrect toner cartridge or has been refilled and gone past its life.
Replace toner
Posted on Jul 07, 2009
MY SHARP AR-M207 DISPLAY ERROR CODE L4-00 KINDLY GIVE ME A SOLUTION
Hi Alafin,
An error code of L4 suggests a motor error. It could be something as simple as a loose cable but it could be a bad motor. I would suggest you call on a local dealer to repair this as you will probably need new parts.
Jun 14, 2016 | Sharp Used AR-M207 Copier Printer Scanner
What does the error code CH stand for? Sharp AR 207
ONE OF THE DOORS SWITCH IS OPEN ,CLOSE THE RIGHT HANDS SIDE DOOR VERY WELL, AND CHECK THE FRONT DOOR ALSO
Sep 04, 2010 | Sharp AR-207 Copier
Code F2-04 solution
http://www.retrevo.com/support/Sharp-AR-M162-Multifunction-Printers-manual/id/600ag113/t/2/
Above is your user manual below is your service manual.
http://www.eserviceinfo.com/index.php?what=search2&searchstring=AR-162,+AR-163,+AR-201,+AR-206,+AR-207,+AR-F201
http://www.eserviceinfo.com/fulltext.php?search_ft=DPX-7010MD
You have a sensor error. I have included your user and service manuals so you can attend to the error.
F1-04 Bin limit position sensor error in sorter
Aug 12, 2010 | Sharp AR-M162 All-In-One Laser Printer
My Sharp AR-207 gets a U2 error code. Nothing happens now. What is wrong, and how do I correct?
When your copier toner cartridge sensor is blocked.then problem arise ut or bios battery is not configure program.
reset : # - interrupt - C -interrupt press 16 press start key.
Jan 28, 2010 | Sharp AR-207 Copier
Replace toner
Jun 30, 2009 | Sharp AR-207 Copier
I have a sharp ar 207 copier. It is giving an error code of U 2. When you press "copy" it gives a code of 40. I cannot locate the service manual. Can someone help?
you have a problem with the chip on the toner cartridge
you have to reset this via simulation 16!
if it's a refilled one have the recycler do it and replace the chip
if it's an oem ask sharp
Jan 25, 2009 | Sharp AR-207 Copier
Error Code E 7
press"clear","interupt","0","interupt",enter14 press start.should take care your problem.
Dec 15, 2008 | Sharp AR-207 Copier
Sharp ar 206
problem in memory try to clear it by entering the simulation code 16
Jun 20, 2008 | Sharp AR-207 Copier
Sharp error code U2
you can get rid of this u2 by pressing buttons as follows: # , interrupt, C, interrupt sequentially. then enter the no. 16 and press the start button. good luck
May 15, 2008 | Sharp AR-207 Copier
Problem with copier SHARP AR-206 display
what is the problem with the display ? is it out ? or showing an error ?
Apr 05, 2008 | Sharp AR-207 Copier
42 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
