Question about Electrical Supplies
Manual for DG 6000 GENERATOR
GENERATOR RUNS BUT NO PRODUCE POWER
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Make sure the main breaker on the top right is turned on then make sure the breaker for the outlet you were using on the generator is turned on. Also make sure you're not using it for something that draws more power than the generator can handle because the breaker will trip every time. If that doesn't do it And you're not familiar on how to test the actual generator with a voltmeter then you'll have to bring it in to be fixed. Also if I recall there is a switch that controls the voltage make sure the switch is in the correct voltage position according to what you're using it for
Posted on May 06, 2017
How to reset a breaker on 6000 dg generator
Explained here:
https://servicenet.dewalt.com/documents/English/Instruction%20Manual/0068660,DXGN.pdf#_ga=2.65557742.1315046841.1494211882-1118003391.1494211866
May 08, 2017 | Electrical Supplies
Generator was running fine and then the electrical output quit while the engine was running.
Sounds like you did overload the capacity of the generator. What has happened is that the generator was happily running away producing the electricity required for approximately an hour and then an appliance such as an air conditioner, furnace, refrigerator, water heater, or similar large amperage draw fixture decided it was time to kick on for its cycle, or perhaps two or three of them kicked on at the same time, thereby raising the amperage requirement beyond the capability of the generator. All heavy duty appliances run at a given amperage but when they kick on for a cycle they draw almost 50 percent or more amps. Generators rated at 6000 amps or less will not power an entire home or business. When using this size of generator, disable some of your electrical items in the home by unplugging or switching off, and only connect the most important items needed for emergency use. A 3500 watt generator will only run a few lights and a television, plus only one appliance. This means that you could plug in the refrigerator and run it until it has gotten cold enough, then unplug it & connect the furnace or air conditioner or water heater so that they can do there job. Eventually you will be able to rotate through each appliance in turn, and hope the power will return soon. Your generator will likely have blown a capacitor, resistor or some similar repairable item. Some good quality generators will have an overload breaker installed, that trips before doing any damage and all that is needed is to find it and reset it, in order to continue using the generator.
Dec 05, 2013 | Campbell Hausfeld GN5060 - 5000 Watt...
Where can I find a schematic for a dewalt dg6000 generator
Here is a 4.3 MB pdf manual for Dewalt generators: 2900 4300 6000 7000
http://waterheatertimer.org/pdf/Dewalt-2900-4300-6000-7000.pdf
Dewalt has service centers and parts sales, you'd think they'd be eager to post manuals on their webiste. Service centers are probably only place to get parts.
Oct 11, 2010 | Dewalt DG6000 Heavy Duty 6000 Watt Gas...
Need manual for DeWalt 6000 generator
here is the link for the manual to download hope this helps
HERE
Aug 26, 2010 | Dewalt DG6000 Heavy Duty 6000 Watt Gas...
How to adjust fuel consume in gasoline generator?
The fuel consumption of a DG or Gas Generator is proportional to the power generated and the frequency  maintenance.
The fuel/air ratio can be adjusted only at one power point or free run in service conditions.
Jun 02, 2010 | Electrical Supplies
Homelite generator model # LR 5500 not producing electricity
I have the same unit and same problem.
I have lost my owners manual. Did you figure out what needs to be done to correct the no output issue.
Mar 07, 2010 | Electrical Supplies
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
