Question about Sewing Machines
My answering machine has low volume. A button once worked to raise and lower volume. Now it does not.
    Sergeant:
  • 197 Answers
Id say your button has malfunctioned - perhaps there is another way?? through settings menu?? otherwise you will probably need a new answering machine... they certainly dont make things like they used too :( alas...
Good Luck!
Posted on May 06, 2017
  • Sewing Machines Master
  • 12,273 Answers
And this is posted in the sewing machine category because...
How do I lower the feed dogs on this machine
Joyce, Some machines do not have adjustable feed dogs. Do a Google search your make and model# manual or how to lower feed dogs. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How do raise or lower the feed dogs Brother
Tutorial Adjusting Feed Dog Height and Position ABC Sewing Machine
What Are Sewing Machine Feed Dogs and How Do they Work
Aug 23, 2016 | Sewing Machines
Janome 3050 feed dogs wont come back up
Dropping the Feed Dog
The feed dog can be lowered with the drop-feed lever for sewing on buttons etc.
  • Shift the drop-feed lever to the right to lower the feed dog.
  • Shift the lever to the left to raise the feed dog, it will return to the up position when the machine is started.
NOTE:The feed dog should be in the up position for regular sewing. Turn the handwheel toward you to check if the feed dog comes up after setting the lever in the up position
JANOME DC 3050 User Manual Page 9
May 24, 2015 | Janome Sewing Machines
How do I lower the feed dog on m Bernnia 180
Push in the square button on the right side of machine until it clicks. Then push in again until it u clicks. The feed dogs will raise once the machine starts to sew again
Feb 18, 2015 | Bernina Artista 180
How do I get the feed dog up on model 6235
The feed dog for that machine is NOT designed to be raised or lowered; instead a cover is put over the needle plate. You might want to remove the needle plate--it's designed to be removed to access the bobbin case--and see if you can pop it up again. On models that DO have the ability to raise and lower their feed dogs, once it has been lowered, if you press the dial or lever to raise it, it won't raise until the hand wheel is turned one or two times.
Sep 29, 2014 | Singer Sewing Machines
How do I lower the feed dogs on my Husqvarna 2000 sewing machine please?
It's been a while since I have owned a series 2000 Husqvarna, but from memory there is a little white (?) button on the lower right-hand side - near the knob for stitch width - it has a notch on the underside. Push the button in, push it in a downward motion and the notch should catch on the edge of the hole and stay there (in other words the notch "disappears" inside the hole). The feed dogs will be lowered. To raise them, push in the button again and let it lift up and then outwards (you see the notch again). Turn the handwheel once and the feed dogs pop up.
Nov 09, 2010 | Husqvarna Designer I
How do I raise the feed dob--I cleaning out the machine and put it back together--now the feed dog will not come up
By any chance, is this a machine that has a lever or buttons to raise and lower the feed dogs? You do not mention the make and model of your machine, therefore, not as easy to be more specific with an answer.
Oct 31, 2010 | Kenmore Sewing Machines
Can I drop the feed dogs or where can I buy a darning plate?
Most Singer machine have a raised plkate these days, if you do not have one you will need a Singer store to get one.
Mar 05, 2010 | Singer 7436 - INGENUITY
How do I raise and lower the feed dog
If you look at the back of the machine you should see the button that will let you lower the feed dog. It looks like you slide the button one way to lower and then the other way to raise the feed dog.
To make it a bit easier just go to the following web site and move down to the pictures as there is one showing the back of the machine. The button would be on your right:
http://www.ebay.com/itm/JANOME-MEMORY-CRAFT-5700-SEWING-EMBROIDERY-MACHINE-QUILTING-TOO-ADDED-EXTRAS-/301088834718
Dec 10, 2007 | Janome Memory Craft 5700
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
