Question about Mitsubishi Televison & Video
Mitsubishi wd65737 my picture is getting narrow, black space at top and bottom,
  • 1694 Answers
SOURCE: Mitsubishi CS-27205 shrunken picture
Good set...worth repairing vertical circuit.....in shop...
about 100.00........................T.
Posted on Dec 27, 2007
  • 116 Answers
SOURCE: My Mitsubishi WS-65313 65 inch, Convergence Problem???
This is a common problem on projection tvs. There are two convergence chips that need to be changed. STK394-250 or original Mitsubishi # 267P173010 (recommended)
Posted on Mar 05, 2008
  • 2336 Answers
SOURCE: On my Sharp LCD TV a black empty box appears
You will need to find the close caption feature in the menu adjustments and turn it OFF. You should do it for all the individual channels that have it activated.
Posted on Aug 20, 2008
jojack2k5
  • 34 Answers
SOURCE: curved in at top and bottom and rainbow colors on bottom
REPLACE ALL STK?????? CONVERGENCE AMP IC'S & CHECK RESISTORS FOR THAT CIRCIUT
Posted on Apr 12, 2009
Sphynkter
  • 221 Answers
SOURCE: my screen is stretched with a 1 and ahalf inch black space on the top and bottom
Most LCD monitors have a couple of control buttons at the top or on the side. Inside the menu, there should be an option called "Auto Adjust" which senses the input signal and resolution, and then shifts the monitor to match it. Have you tried to auto-adjust the screen? There may even be a button called "Auto" on the monitor.
Posted on May 13, 2009
Black bar on dlp tv.how do I fix this?
Sounds like a connection problem between board and DLP chip. The BGA connection which connects the DLP chip to the board, or the flex connector may be bad, causing the row and column section to not activate the micro-mirrors on the DLP chip. Not an easy fix. Regards.
Nov 23, 2015 | Mitsubishi WD65737 65" DLP TV
Why is picture 1/3 down from top and 3" in on right side is a little darker?
Did you move or bump the TV? That can cause misalignment. Did anyone fool with the setup? Get the manual and run through that again. Did you change input source (IE new DVD player, etc)? There is a setup (usually in menu) for slight adjustments to picture in most TVs, like on computer screens adjustments if you ever have done that. RTFM
Oct 23, 2015 | Mitsubishi WD65737 65" DLP TV
Replace chip for white dots now have two black bar top and bottom model wd65735
Probably ok. Check the picture ratio or format settings to see if the bars go away when aspect ratio is right setting.
Feb 06, 2015 | Mitsubishi WD65737 65" DLP TV
My picture is brighter on the bottom
if the band is the bottom half etc it could be a issue with the optical light engine, this is not unheard of in these sets and rather expensive.
Aug 27, 2012 | Mitsubishi WD65737 65" DLP TV
I have a Mitsubishi CS 3515R 35" Tube TV. The screen has narrowed at the top and the bottom so only about 2/3 of the horizontal screen has picture. There are black areas at the top and bottom....
There are two issues, the first is a vertical deflection problem, "needs a few parts+an ic" the second problem is intermittent color, "crystal and color processor ic" If the set is close to 10 years old then your money is better spent on a new tv.
Mar 20, 2011 | Mitsubishi CS-35503 TV
I am getting white and black spots in the picture. More are appearing as time goes by.
Could be many things: mirror hinge fatigue, dust mircromirror device (MDM). You need a service tech.
Nov 21, 2010 | Mitsubishi WD65737 65" DLP TV
Problems with mitsubishi WD 65737 tv is locked. what do we do?
problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture then the tv turns off the light on the front is now steady red. resetting the sytem worked yesterday but not today.
Oct 20, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Mar 05, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Open Questions:
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
