Question about Coffee Makers & Espresso Machines
I have a commercial Simonelli Microbar with water tank I have cleaned brew group and reassembled Started machine pump runs but does not seem to draw water. Cycles from overheating boiler but no water.
SOURCE: Machine Does not draw water into the boiler
I have had this same problem - it is due to an airlock in the boiler/tubes. Simple solution is to use a syringe or similar and gently force some water up the intake hose from the tank, then try the pump again.
Posted on Oct 10, 2007
KenMacBoston
  • 11 Answers
SOURCE: Jura S9 coffee machine not drawing water - says FILL SYSTEM
Try using the "shipping" unit button to shut everything off. Turn off the unit and then tryo to run it again.
Posted on Sep 20, 2009
  • 1089 Answers
SOURCE: Starbucks Barista (Saeco) Espresso machine Quit pumping
Hi
If it makes a noise when you turn the brew switch on you may have a blockage in the out let line. If it doesn't make a noise but every so often you may have a bad pump.
Posted on Mar 07, 2010
  • 4 Answers
SOURCE: Water leaking jura s9
The connectors on capresso machines are very tricky.
take it a part again, and make sure all the rings and pressing clamps are in the right place. Also take a good look and "IN" on your hot water tank, and the pressure relief valve in back of machine
Posted on Mar 27, 2010
hmerchant110
  • 7191 Answers
SOURCE: Instruction manual for nuova simonelli microbar expresso machine?
You can download the user manual in PDF format from the manufacturer's support website by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Posted on May 13, 2010
Nuova simonelli vip over pressure problem
Could be lack of water in the boiler, could be a faulty pressure stat or vent valve. Check the level probe first, then the vent valve and then the pressure stat. You can also use the manual fill to make sure water is getting to the boiler.
Jun 27, 2010 | Nuova Simonelli Microbar Espresso Machine
Steam comes from wand when set to dispense water.
Check the connection to the boiler from the pump, there is no water going to the boiler. Try this test, remove the brew unit you will see a white plastic valve behind it, carefully lift the small lever on the valve(HOT WATER), if water sprays, then the problen is at the brew unit, if no water then the boiler inlet or outlet is clogged.
Jul 01, 2009 | Saeco Magic De Luxe Espresso Machine
Wet grounds
What you see is condensed stem comming out and no water. The pump is not sucking from the tank as ther is an air bubble in suction line. Still want coffe and don't want to clean your machine??? Flick up the lever with no group in place. Steam comes first then nothing. Pump is running and - voila - water comes as air bubble is gone. (Specially the first cup , never the following ones.) Now put back the group and brew your espresso. The machine is full of scale and neds total clean - by hand./// Olev
Jun 13, 2008 | ECM Giotto Espresso Machine
Saeco Magic De Luxe - hot water / steam but no coffe through the brew group
our taking about the plastic piece with 2 seal on it if it that its very easy to change that thing is screwed in the boiler try to unscrew the piece if you cant you gonna have to remove the boiler i know does machine good let me know thanks for using fixya pierre
Feb 13, 2008 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
