Sort on multiple keys in QP
Need to sort on two columns in QP, for ex. Alphabet, and then by company so that I finish with a spreadsheet sorted alpha by company
  • 450 Answers
SOURCE: Contact sort
Sorry, no can do. The only thing you can do is sync it with Outlook and use the sort options there.
Posted on Sep 12, 2005
i have problem refference youtube port 80 ican,t watch youtube
Posted on Mar 04, 2009
  • 152 Answers
SOURCE: I have done something in
It sounds like the file is "read only". Open the file and save under a new name, or right click the file name and select properties. Then make sure the "Read only" box is cleared. The file could also be protected. Go to the review tab and sele "Ptotect Sheet" in the changes group. If the is no password, the sheet will be unprocted when you click the icon.
Posted on Mar 21, 2009
SOURCE: Autofilter ceases to work on large Excel 2003 spreadsheet
Sounds like there is a gap between the filter heading and the column data. That's the only time I've seen suggested data missing from the drop-down.
Posted on Jun 18, 2009
SOURCE: sorting a single column with both first name and last name
are you using mssql then it must be something like this
Select firstname + ' ' + 'lastname' as 'name' from tablename order by lastname
Posted on Sep 27, 2009
What is a good numbering system for a customer job number
There are many ways of doing this and the complexity depends largely on whether you want the number to be generated sequentially and how you are going to record and interrogate the information. CRM software will usually have these functions built-in. (See Sugar CRM as one option)
For something much simpler you can manage in a spreadsheet, I like a system that can immediately identify the customer visually. For example "smith141008" identifies smith as having become a customer on that date (numbers entered in reverse for easier sorting). Or you can do it the other way around "141008smith) that make a sort easier by number. If there are multiple "smith" entries, try "141008smith-1 OR you can issue a unique customer code and record that.
If you have more than one product category, in Excel you can add a "key" column to indicate purchase history.
Oct 02, 2014 | Computers & Internet
I have a column containing a value of a single letter. I need the spreadsheet to sort add rows by letter.
Move the column to A. Mark entire sheet and sort ascending. There are more raffined ways to do this, but this is an easy quick fix...
Sep 07, 2014 | Microsoft Excel for PC
When using excel how to get dates to automaticly update in order
Sort the data to represent descending order for a chronological data set. If your information is listed in a table format in multiple columns, make sure you select all of the data and sort on the date field.
Feb 16, 2014 | Microsoft Excel Computers & Internet
Delete emails from certain contact
Generally you sort them in the order you want (to bring all the ones to be deleted together)
Select them all (left click the top one, Shift key + left click the bottom one)
Delete them
You may have to make more columns of data visible to get the right column to sort by
Nov 13, 2009 | AT&T Computers & Internet
When I try to merge my excel document with 250
Hi deloisr
It looks like you have chosen the wrong data file. Probably an earlier version of your data still present in some folder.
Check these
Do you have column headings for every column?
Make sure which folder contain the file? What exactly is the name?
When you are in the Microsoft word, make sure you select the correct data file for your mail merge. If you have selected the correct data file, when you attempt to insert the merge fields, there is no way, it give wrong field names.
The only reason you get the erong field names is because you have the wrong excel file for your data. Fix this problem first, then the rest will sort themselves out.
Have a good day.
Nov 09, 2009 | Microsoft Computers & Internet
Sorting a single column with both first name and last name
Sep 26, 2009 | Computers & Internet
Jun 16, 2009 | Microsoft Computers & Internet
Excel 2007 question
Ok, I realized that I wasn't paying attention when I created my test spreadsheet. My first cell wasn't sorting properly because it started with a ";" instead of a letter, so it always stayed at the top. I removed the extra character and repalced it with another letter, tried it again and it worked. If there's only 1 column, it doesn't ask to expand the selection. If there are nearby data cells, it asks you what you want to do. I was able to get it to work every time by selecting "Continue with existing selection" instead of "Expand selection".
May 14, 2009 | Microsoft Office Excel 2007
About formula
One way of finding (and removing) duplicate entries is to sort the column and put a simple formulate in a temporary column next to that column; for example - if column A has duplicates, insert a column (B) and starting in B2 put if(A2=A1,"DUP",""). Select B2 and scroll down to the bottom of your spreadsheet. Press <ctrl>-D to extend the formula in B2. Wherever there is a duplicate you'll see "DUP" in column B. If you want to remove the duplicates copy column B and Edit / Paste Special... with "values" selected (to wipe out the formula). You can then sort the spreadsheet on column B and remove rows with DUP in column B.
If you can't delete the duplicate rows and the order is important first include a column that captures the order - same trick except put row() in that column, copy / paste special the values and then you can re-sort after doing the above to have both the DUPs marked and the original order.
Hope that helps.
Aug 08, 2008 | Microsoft Computers & Internet
Sort data and create graphs for each quarter
you could have all the data in the same worksheet, but sort it using filters, eg click on the little arrow at the top of each column, then click on the item listed. this will then show only those rows associated with that item.
Jan 13, 2008 | Microsoft Excel for PC
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
