Question about Green Cameras
I have flashing green light on the docking station? Why.
  • Terry Weaver
    Terry Weaver May 06, 2017
    Maybe you could tell us what product you're talking about
jackboy
  • 2985 Answers
SOURCE: Camera Dock is not charging camera
Camera or battery dead.
Posted on Jul 31, 2007
SOURCE: red flashing light on battery indicator on the loading dock.
My Z760 does the same thing. When that happens I run the battery completely down by taking pictures until it shuts down. Then when I put it on the dock it charges properly. Don't leave your camera on the dock all the time and don't try to always keep the battery fully charged--instead it will develop memory and think it needs to be fully charged to run and will give you a low battery signal earlier than it should. Wait until you actually get a low battery signal before charging and it should help, but mine will still give me the red light sometimes. Then I run the battery out like I said before. I hope this information helps. :-)
Posted on May 27, 2009
fredtmccoyjr
  • 380 Answers
SOURCE: dell latatude D630 is docked/battery flashing 4 red 1 green
4 orange and 1 green can mean a battery malfunction, or it could be an indication that the battery is about to reach the end of its life cycle. When a battery is built, it has a planned expectancy. a date code is stamped in the electronics of the battery pack. as that date code is reached, the indicator lights on the computer let you know the battery (even if its working fine) is considered obsolete and needs to be replaced soon.
Posted on Nov 05, 2009
  • 1768 Answers
SOURCE: my dell 2005fpw screen has gone blank and power
A flashing green is usually a power supply failure on the main board of the LCD and a protective shut down circuit kicks in when the voltages are not correct at the check sum.
This also depending on the circuit configuration that the monitor is in standby mode. Your user manual can give you this information.
This also may be the video card itself or a loose cable.
Check the monitor cable to see if it is secured.
Also check you resolution settings on the PC. This procedure will require you to connect another monitor to the pc to see if it will bring a signal.
If a signal is visible then the video card is ok.
If not then you will have to check the video driver for the video graphic display card and or replace the card.
Posted on Apr 17, 2010
Testimonial: "Good diagnostician"
  • 3 Answers
SOURCE: docking station
I had the same problem. I did need to take the clear plastic insert off but then I had to put a rubber band around the dock and camera (more on the left of the camera and dock) to hold it evenly on there since the camera was leaning on the right and wasn't charging for me. Now it charges as soon as I put it on there with the rubber band with no blinking red light anymore! Hope this helps!
Posted on Jul 31, 2010
My kodak eastyshare z760 flashes red when on the battery charger but yet, the battery never shows fully charged.
I had the same problem. I needed to take the clear plastic insert off but then I had to put a rubber band around the dock and camera (more on the left of the camera and dock) to hold it evenly on there since the camera was leaning on the right and wasn't charging for me. Now it charges as soon as I put it on there with the rubber band with no blinking red light anymore! Hope this helps!
Jun 10, 2010 | Kodak EasyShare Z760 Digital Camera
Hi, i have an apple i pod docking station Model A1121. It doe'snt want to play whenever an ipod is attached to it. The lights are all on and flash when pushing the volume button, buut no noise.
my mail id : ravi85_india@hotmail.com
May 20, 2010 | JBL On Time Docking Station for Apple iPod...
The ethernet cable port on my docking station is broken.
It is hardly possible that anyone will even try to repair it. And believe it or not, it is cheaper to buy a new one then to repair the old one
Nov 17, 2009 | HP (EQ773AA ) Docking Station for nc2400...
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Kodak V530 won't upload pictures from docking station to comuter.
If your camera have a sd/mmc card just buy a sd card reader and plug it in your pc. it will transfer all your pictures to your computer.
user guide for your camera
http://support.en.kodak.com/app/answers/detail/a_id/18624/~/kodak-easyshare-v530-zoom-digital-camera%C2%A0%E2%80%94%C2%A0users-guide/selected/true
Jun 10, 2017 | Kodak EasyShare V530 Digital Camera
Camera won't charge
Hi!
It's a problem with the battery. It already reached it's life cycle. I had the same problem with my 15 month old casio camera a year ago - flashing red light on docking station. I even tried borrowing a docking station/charger to see if something else is wrong with it.
The only solution for this is to have the battery replace.
I hope that helps.
Good luck and have a nice day!
Nov 26, 2008 | Casio EXILIM Card EX-S770 Digital Camera
CHARGING LIGHT DOESN'T COME ON WHEN THE DEVICE IS ON THE DOCKING STATION
The adapter that comes with the Archos 605 must be firmly fixed to the docking station by pressing very firmly with a loud click. It feels delicate so if you only click it lightly it wont connect properly. This is poor design but at least it is OK now.
Aug 27, 2008 | Archos 605 WiFi Digital Media Player
Charging Camera
I would test the docking station first. Do you have a way of charging the camera without using the docking station?
Thought I'd ask because some can and some can't.
Jun 21, 2008 | Casio Exilim Card EX-S600 Digital Camera
Cameras Logo
42 people viewed this question
Top Green Cameras Experts
NOEL
NOEL
Are you a Green Camera Expert? Answer questions, earn points and help others
