Question about Maytag Dryers
Have a maytag heavy duty model lde512 07 series and it wont dry clothes completely what could be wrong
3 Suggested Answers
  • 205 Answers
SOURCE: Maytag Dependable Care Plus/Heavy Duty
HI- Usually when the clothes take a long time to dry it is an issue with the vent. Look in the back of the dryer and make sure the vent is not crushed, crimped or blocked. As well, go outside when the unit is running and feel how much air is coming out of the exit vent. It should be blowing pretty good. If not replace and clean the vent, if the vent goes through the wall and makes a bunch of turn over a long distance you will need to have a vent cleaning service out to brush and vacuum the vent. You can test this by detaching the vent where it goes into the wall and putting pantyhose over the end and see if it dries better. You could also have a thermostat issue but I look at the venting first. Hope this helps.
Posted on Sep 24, 2010
  • 51518 Answers
SOURCE: have a maytag heavy duty dryer model lde512 07 series and it is not getting clothes all the way dry what could be wrong
Problem might be with your washer not spinning them dry enough..or your vent is plugged up with lint
Posted on May 06, 2017
Electric clothes dryer wont turn on but I hear a faint buzzing sound
Hello:
the noise could be coming from the timer which will be going through the motions if the door switch is not working right( door open -no drying)
Jul 08, 2017 | Dryers
Have a maytag heavy duty dryer model lde512 07 series and it is not getting clothes all the way dry what could be wrong
May 06, 2017 | Maytag Dryers
Admiral designer series heavy duty giant capacity 20 lb dryer
two possible problems
the air blower is not running properly
too many clothes being dried restricting air flow
Nov 24, 2016 | Admiral Dryers
I have a Maytag Heavy Duty Quiet Series 200 Dryer, and when I turn the dryer on is makes a horrible screeching sound. Like metal grinding against metal. What do I do?
That's easy, first of all you must have the Dryer on flat floor I mean verticly right. And try not to put too many clothes to get dried.
Sep 12, 2010 | Maytag Dryers
My whirlpool duet dryer is only 4 years old and it does not dry the clothes completely, even when it is on Heavy Duty. Only way it dries the clothes is if I run it through 2 cycles.
Check to see that the lint filter and exhaust duct are clear all the way to the outlet. If the moist hot air is not being exhausted the clothes will not dry. If the vent path is clear and you are using auto-dry the sensor may be at fault.
Aug 13, 2009 | Dryers
My simpson 1200s heavy duty clothes dryer is just not drying the clothes. It isn't heating up much and the clothes are still damp. Can you advise please
check venting fo cloggs or kinks make sure you can see through the filter dryer sheets put a film on them and need to be washed once in a while
Jun 28, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
My frigidare heavy duty crown series not heating
sounds like you have a cloged vent i normally get a few calls in the winter timer for this problem because the vent is clogged outside due to the snow remove your vent try the dryer to see if it dries if yes check your vent
Mar 15, 2009 | Dryers
Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Jan 02, 2008 | Maytag MDG2706A Gas Dryer
Dryers Logo
37 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
