I have a uaka-018jaz outside Central air unit. The other day the unit is still running but nothing is blowing out of the vent inside house in floor. The condenser or coils in the vent frosted
  • Heating & Co... Master
  • 1,193 Answers
First you have to make sure the blower motor is running. That is the fan motor on the indoor unit. If the fan inside is running and the filter is clean you are likely low on refrigerant. If the indoor fan is not running this would be the reason for the frost. If the unit is iced up turn the system to off and the fan to on on the tstat. This will help defrost the coil. Good Luck.
Posted on May 06, 2017
jumptrout51
  • 3361 Answers
SOURCE: central air conditioner doesn't cool
The capacitor is located inside the control panel on the outside unit. It is round or oval and silver in color.It runs the outdoor fan and the compressor both.
The terminals are marked= C, /F or fan/, H or herm. C-F-H.
The microfarad rating is printed on the capacitor. Make a color code wire diagram before removeing wires.
Disconnect power to the unit. Use a insulated screwdriver to short out the terminals on the capacitor before removing it.
Posted on Apr 27, 2009
herodog909
  • 98 Answers
SOURCE: CENTRAL AIR UNIT IS NOT BLOWING INSIDE BUT THE
There may be a leak. You might try shutting it down and taking a look inside. On the other end, there may be something wrong with your components inside. The compressor outside is to provide coolant. Inside, the fans actually cool the air. Make sure all doors are on the blower downstairs, and if all else fails, call a technician. Good luck!
Posted on Jun 19, 2009
farfield
  • 462 Answers
SOURCE: ruud UAKB-018JAZ outside condensing unit will not run
Trace the wires (small cable) going to the out door unit. This is your 24v control circuit. when it enters the outdoor unit it ties to wires routing through the inside of the unit trace these down. For AC units 1 usually goes directly to the "contactor" (the item you push in and the unit runs?) the other wire can also go to the other side of this same item. But I suspect it goes through other tings before it finally gets there.
Some items are the high and low pressure switches and a delay timer.
A red button sticking out where you can reset it is the high pressure switch and if it clicks and lets it come on you may have a dirty outdoor coil or a fan motor outdoor that is not operating all time.
A low pressure switch has no reset normally on AC or HP.
A delay timer will have 2 3 or 4 wires depending on the type of timer. 1 of these wires goes to the contactor (usually) and one of them feed this wire. remove the wire going to the contactor. now 1 at a time take the other timer wires and touch them to the wire just removed. if the times is bad the contactor will click when you touch one of them with the removed wire.
If its a heat pump you will have to make the contactor try to come on around the board. and this you will need some knowledge on which and what feeds your contactor. Here Id suggest a technician. If I had a way to see your setup and wiring I could talk you through this but its too hard to type and would take way too long.
Posted on Jun 27, 2009
luker711
  • 91 Answers
SOURCE: Central air running all day and not cooling very well
Condensation by the compressor is okay, but if you see it icing up thats reason for concern. The indoor coils can freeze up if there is not enough air flow. Make sure most if not all the registers are open. Take tempature readings at the return and at a supply vent. There should be a 20-28 degree difference. If the difference is only in the teens you have a functional problem. Be sure to shade direct sunlight. And if it gets below 65 degrees at night be aware that if the A\C runs through the night it may block up with ice in the evaporative area. If outside temp reaches 100 degrees unit will run all day. Good luck
Posted on Jul 13, 2009
SOURCE: My outside a/c condensing unit's fan runs, but
Start the unit and go outside to see if the insulated pipe is sweating or cold, hot air should be discharging from top of outside unit. Since the breaker is not tripping, my best guess is the compressor is not operating. You might have to replace the capacitor.
If you can hear the compressor operating, then most
likely needs refrigerant
Posted on Jun 17, 2010
Testimonial: "Thanks for providing some additional clues and methods to pin down what needs replaced. Now I need to determine whether the run capacitor or the other part, for which I can't find the name, is at fault, unless the compressor is bad."
Unit not cooling inside below 72 degrees lines sweating
how hot is it outside??? 20 degree split is usually the norm ,,,,,outside 95 then inside will be 75,,,,,where is the line sweating ,,, it should sweat near outdoor unit
Jun 02, 2014 | Ruud Central System Air Conditioner
Ruud UAKA-030JAZ fan spins, not blowing cold air
there are 3 things to be considered,first,if the compressor motor `s connectors are having loose,it gives a hi ampere to your RELAY that can cause to its contacts being fried,second,the compressor motor itself is gaining a hi ampere already i.e. having unusual sound that can cause heavy friction inside the turning mechanism and third the last but not the least,maybe this time,the tubes or the compressor itself having very small holes that causes to the refrigerant to escape and it doesn`t gives off cold air.
Apr 17, 2014 | Ruud Heating & Cooling
If you are using this inside your home with central air running do you have to vent it to an outside window?
Yes, it must be vented to the outside, even if you're using central AC, too. The reason being is if you don't vent it to the outside, the hot air and humidity that normally goes thru the duct and out the window, will stay in the house and your Central AC will have to run longer and harder to overcome this rise in heat and humidity. In addition, the room that the portable AC is in, will get extremely hot & humid.
Hope this helped you. Please let me know. Thanks.
Jun 15, 2011 | Haier CPN12XH9 Portable Air Conditioner
Central Air- Breaker flips when AC is turned on
IT SOUNDS LIKE YOU HAVE A BAD COMPRESSOR OR A DEAD SHORT SOME WHERE IN THE UNIT
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
No air blowing inside the house thru vents;starts fine than stops
You are likely low on charge and the unit is freezing up. You need some with gauges to check. You should not try to run this unit until then or it will burn out the compressor.
Jul 18, 2009 | Ruud Central System Air Conditioner
Jul 13, 2009 | Heating & Cooling
Central air/heat pump not putting out cold air
I have some things for you to check. If you look at the outside unit the lines going into the house. Are they frozen? Have you had any yard work done, the reason I ask is they could have accidentally cut or pulled out the thermostat wires to the ac unit. Also, inside check for the same thing, frozen lines. Also, you may want to check the drain coming from the inside unit, it may be clogged.
Jun 22, 2009 | Heating & Cooling
CENTRAL AIR UNIT IS NOT BLOWING INSIDE BUT THE COMPRESSOR OUTSIDE IS RUNNING. WHEN I GO DOWN TO THE BASEMENT TO CHECK THE FILTER-THE BOTTOM OF THE UNIT AND THE FILTER IS WATER LOGGED. ORIGINALLY IT WAS...
Jun 19, 2009 | Ecoquest Flair Air Purifier
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
