Question about Filter Heating & Cooling
How do I change a filter on an Integra portable Swamp cooler?
Ed Phillips
  • 11 Answers
SOURCE: Do not know how to work/maintain swamp cooler
Make sure you have water to the unit, the water pump is on and the fan is working. No water=no cooling.
Posted on May 31, 2009
  • 340 Answers
SOURCE: swamp cooler is not blowing cold air. Water is
is the pump youll have to take off a panel make sure the pump has water. what is the relative humidity if it is high swampers don't work very well .Tom
Posted on Jun 26, 2009
mrjfisher
  • 141 Answers
SOURCE: Got an Adobe Air Swamp Cooler Model # P228101A. Lo...
Indoor Comfort Evap Cooler & AC Parts, Phoenix AZ 85021 2001 W Cheryl Dr, Phoenix, AZ 85021
www.merchantcircle.com › ... › AZPhoenix85021
They say they have parts for your unit.
Posted on May 19, 2010
SOURCE: I inherited an Integra portable cooler 62000003 -
I have one of these, although I haven't used it in years. You just put water in. I never had a problem with leaking. You do have to make sure it's in front of an open window or door and you also have to make sure the filter is clean.
Posted on Jun 28, 2010
  • 10865 Answers
SOURCE: I have a Westwind Convair
hi.
here is the company contact info. http://www.cylex-usa.com/company/convair-cooler-corporation-5048927.html
call them to order.
Posted on Sep 02, 2010
How to remove a motor from a plastic fan wheel on a portable evaporative cooler
There should e a set screw on it that you can loosen. Then the wheel can be removed.
May 31, 2014 | AdobeAir Mobile Swamp Evaporative Air...
Swamp coolers
Does it come back on automatically and how long does it take?
May 16, 2014 | Mastercool 67680 Evaporative Cooler Air...
Need parts, pump for a ED630J adobe swamp cooler in las vegas, nevada
A swamp cooler PUMP is not really model specific. They are basically small submersible pumps. Contact ANY swamp cooler dealer in LV, tell them you have a 4500 CFM unit and need a pump.
The pump part number for this size cooler is: PN 110436 (there are several alternates)
Contact these folks and tell them what you need:
National Cooler ' Swamp Cooler
3046 Vegas Dr.Suite 1
Las Vegas, NV 89106
(702) 638-8800
If they can not help you... just look under cooling and air-conditioning in the yellow pages and find a dealer near you. This pump is common to nearly every brand in LV. You can most likely buy one at the local home depot, menards, or lowes.
There is also a Little Giant CK-5 "UTILITY"pump that is used for swamp coolers.
Thanks for choosing FixYa,
Kelly
Jun 15, 2011 | AdobeAir Mobile Swamp Evaporative Air...
How do you calculate the cfm in a swamp cooler
You will need to figure the cubic feet of space you want to cool, and then divide that number by two. The quotient will give you the CFM rating for the proper-sized swamp cooler.
Jun 14, 2011 | Heating & Cooling
How could i clean the air cooler, i used have a bad smell when i switch on the cooler fan
What you do is remove the hog hair and replace it. Then clean out the pond. Then remove the blower and take it apart, oil the motor and wash the wheel.
May 04, 2010 | Cfm Kenstar Turbocool Major Portable Swamp...
Problem is i have a gravity fed system and yesterday connected a cold water line for an evaporative cooler to the cold water line coming of it. now there isnt any hot water
water will always find its own level and take the path of least resistance. if your hot water tank inlet is higher than the swamp cooler this may be your problem. you can try a line resrtiction at the cooler or a twelve volt rv pump with a battery and solar charger and an on off switch.know someone with this set up and it seems to work well.
Nov 28, 2009 | Water Heaters
How to turn it on? wisper cool
Try this : http://www.impco.com.mx/manuales/artic/Manual%20MMB8.pdf
Jul 08, 2009 | AdobeAir WisperCool MMB8 Portable Air...
My portable air conditioner has stopped pumping water to the tank
this would be a swamp cooler.if you have water in it and its not pumping.its going tobe the pump but i would see if the pump is getting voltage first before i bought a new pump.where doyou live that your worried about a cooler?
Jan 01, 2009 | Heating & Cooling
Heating & Cooling Logo
43 people viewed this question
Top Filter Heating & Cooling Experts
MightyMikeJr
Vernon Taylor
Are you a Filter Heating and Cooling Expert? Answer questions, earn points and help others
