We disconnected the dvd player and now there is no sound on tv
I have a magnaxox dvd/vcr player that is hooked up to a high def TV. It got disconnected Now when we connect it we only get the sound and no picture. How do we fix this?
Reconnect the player to the rear of the TV noting correct color codes, usually red for right channel audio, white for left channel audio, and yellow for video.
Mar 23, 2018 | Televison & Video
I cant get my dvd player to power off so that my tv can come back on. I keep hearing the dvd player make a sound but off is constantly displaying on it. I cant get my tv back on and i keep hit the power...
Remove the power and manually turn the loading mechanism to eject the DVD whichis struck up inside the player. Now if the DVD circuit seems to hang up again you can disconnect the connector to the main board to switch on the TV.
Jul 21, 2011 | Sony Televison & Video
When I turn on the TV, the DVD player has always made a sound as though it was being activated. It would cycle for a few moments (like it was looking for the DVD) and then the sound would stop. But...
You kneed to replace the DVD Deck. Very easy, just a couple of screws on the side and pull the deck out. When you pull the deck out, if there is a cable connected to it, you will need to take the back off and disconnect the cable. Some models have it and some don't.
Jul 20, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
Screen lights up sound OK, but large horz bars-with no video information. I disconnected the DVD player and TV is OK. I re-connected the player and TV is OK again...I don't know for how long, any ideas? ...
Mainboard (AKA tuner board) is the issue. It was lost with the DVD input plugged into the mainboard. IF this happens again, I would recommend unplugging the internal DVD and go with an external option. These combo tvs are confused because of the extra processing power needed for an internal combo player.
Thank you!
Apr 19, 2011 | RCA L26WD26D 26 in. LCD TV
When I hook my dvd player up using the Component Video Input I get sound, but no video. Its not the dvd player because i hooked it up to my other tv and it worked fine. Thanks for any assistance
This might be the other TV's Video Input Cable Plug. Could be disconnected somewhere within, it may be disconnected. If your TV has two slots for Audio/Video Input, try using the other Slots maybe. :)
Apr 02, 2010 | Mitsubishi VS-60607 TV
TV after removal of picturetube for playing music from DVDplayer
Why use the TV in hearing the sound from DVD
player. You can use some small speaker and connect it at the back of the DVD player.
Jan 07, 2010 | Televison & Video
RCA Projection TV Model P60925BL. Has sound but lamps don't turn. Chassis model PTK195LC
i went into setup option and the dvd player disconnected and I can't figure out how to get it working on the tv again. dvd is connected to video 1 on the dvd player and channel 3 on the tv ????
Dec 11, 2009 | RCA P60921 60" Rear Projection Television
How to connect the back connections to TV.
yellow is video
red is right sound
white is left sound
Jun 01, 2009 | Sony DVP-NC600 Multi-disc DVD Player
Suddenly no sound from playiny tv through the dvd
check SCART lead hasn't come out....even a slight amount will disconnect the audio pins
Check the function / to others / setup / connection / AV1 & AV2 settings
Feb 15, 2009 | Panasonic DMRES20D DVD Recorder
Picture but no sound only loud hum
You have to double check the inputs of the video in as well as the audio in on the TV set. they come from the video and audio output on the DVD player. Good Luck
Jun 28, 2007 | Samsung DVD-V9650 DVD/VCR Player
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
