Question about Maytag MGR5875QD CleanDesign Gas Kitchen Range
OVEN will not lite immediately
Turn on oven does not lite right away , then there is loud whoosh door comes open and sometimes oven lites it is model AGR5735QDQ
  • 45 Answers
Re: OVEN will not lite immediately - Maytag MGR5875QD CleanDesign Gas Kitchen Range Kitchen Ranges
Need to replace the oven ignitor
Posted on May 16, 2008
0 characters
3 Points
I was using my oven when all of a sudden there was a loud whoosh sound. Since I use propane I immediately turned off the oven.
Hi, it sounds like you may have a gas leak some where else on your oven probably from the supply pipe . It looks like it is building up then its been ignited so you get a whoosh. Best get it checked out.
Jan 30, 2016 | Kitchen Ranges
Oven lite won't go off and when turn on self cleaning it says door
The door switch has gone bad. This will keep the oven light on and the self clean won't work because it thinks the door is open.
Dec 12, 2011 | KitchenAid KESC307 Electric Kitchen Range
Gas burner does not light clicking on other burner when knob is turned on
they should all click when you turn any one of them need to send the model number off of the machine,under the oven door there should be a draw,open the draw and look at the frame on the left or right side and you should see a tag with the numbers,can you lite it with a match,if not all you might have to is get a paper clip and clean out the holes that the gas comes through,also when you lite it does the ignitor or electrode spark?if not you can switch the heads to see if it's a problem with the electrode,if not you could have a bad spark module or a bad switch that's behind the knob but i need the model number to see what parts are on your stove.
Nov 27, 2011 | Jenn-Air...
Upper oven makes loud whooshing noise sometimes , like the gas ( propane )is blasting full tilt model mgr6775 ,mgr6875
The gas is not the problem... the ignitor is...
The gas is building up in there before it ignites because the ignitor is not working properly...
Replace the igniotr and the problem will go away..
Check out this tip...
Mar 11, 2010 | Maytag MGR6775 Stainless Steel Kitchen...
Roper Gas Range Oven Makes Sound
check you have ventilation. i.e. try with the window open
Feb 14, 2010 | Roper FGP305 Gas Kitchen Range
Kenmore gas stove control panel not working
It appears your ERC/CLOCK has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 01, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Gas leaks into oven when i turn on the broiler
You have what we called delay ignition. may be the broiler ignitor too far away from broiler, partially clogged broiler orifice or bad ignitor, I"ll check the Amperage on the ignitor, it should draw above 3 AMPs, if not, then I'll change the ignitor first then check the orifice. Have fun.
Dec 04, 2008 | Dynasty DGRSC 36-4CB Gas Kitchen Range
Igniter is on, gas is released, a small explosion occurs in oven
no the little boom before it lites is normal mine does it all the time
Dec 04, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven & broiler not working
you ignitor is going out you will need to replace it the ignitor needs to draw a min of 3.2 amps in order to open the gas valve coil if short of this it will not open at thimes it may just have enough to open
Jun 28, 2008 | Hotpoint RGB528 Gas Kitchen Range
Maytag MGR5875QD CleanDesign Gas Kitchen Range Logo
128 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
