Question about Dewalt Drills
My chuck on my dewalt 18 volt comes undone in reverse its fine going forward what would be the problem
    Top Expert:
  • Dewalt Master
  • 47,657 Answers
Open the jaws right up and down in the bottom of the chuck should be a screw ( left hand thread )
for the chuck to come off in reverse means that that screw is missing
Posted on May 05, 2017
    Top Expert:
  • Dewalt Master
  • 77,499 Answers
You need to replace the chuck.
    Novelist:
  • 170 Answers
If you look at the end of the shaft on the drill after it unscrews, there will be a hole with threads inside--if not the screw may have broken off---your missing screw that holds the chuck on--it's a left handed threaded screw---it's head may be slotted--philips---torx---or allen---this is available at your Dewalt dealer or tool repair---all that needed is the size/model number of unit---screw the chuck back on tightly then open chuck jaws all the way then put the holding screw in---tighten it down---REMEMBER IT'S LEFT HANDED----GL
  • 313 Answers
SOURCE: Keyless chuck question
this 2 chuck are 3/8 jaw opening,double sleeve u can hold the chuck will opening it at the sametime.the sinlge sleeve u have to runs the drill while running slow rev/for to remove the bit etc.
i prefer metal sleeve.
Posted on Aug 19, 2008
  • 10865 Answers
SOURCE: dewalt 18 volt cordless drill
Use a pipe wrench on it to give yourself a little more leverage. It is simply jammed all the way open and it will release when you apply enough force.
Posted on Apr 30, 2009
rowdy45176
  • 2176 Answers
SOURCE: dewalt xrp 18 volt hammerdrill. Need gear schematics.
Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number and it will take you to a page where the schematics are.
Posted on May 24, 2009
  • 27 Answers
SOURCE: the chuck is stuck on 18 volt dewalt drill
It is not the chuck that is stuck, it is probably the armature. Probably a problem with the brushes. Since it is so easy I would try first unscrewing the caps and pulling the brushes out to see if things spin then. If the brush will not come out then it is probably jambed and you would have to take the drill apart. If you take the brushes out and still have a problem, at least one reasonable but simply checked problem is eliminated.
Posted on Nov 03, 2009
SOURCE: problem with the chuck
Had the same problem on mine. Remove the chuck, then remove the snap ring on the back of the chuck( carefull, the housing will fall out once the ring is removed), on the side of the chuck you'll find a cam and small odd shaped spring held in by two cylender pins, on mine the spring had a gap in it and I just spread the gap to about twice the size in was and put everything back together and it has worked fine ever sence. Hope it works for you.
Posted on Dec 16, 2009
Dewalt dcd970 repair instructions chuckproblem?
Your cluck is worn and needs to be replaced, below is a link to a video of how to remove the chuck.
Link:
Mar 07, 2012 | Dewalt 18 Volt Compact Drill Kit
My 18 volt dewalt cordless runs well except when I try to remove something with it. Reversing the drill makes my nutdriver bit fall out as it opens the chuck, so all removals have to be done by hand.
I would make sure that the bit is firmly installed in the chuck, you should hear clicking when the bit is tightening, this is the chuck locking itself on the but. and when going in reverse make sure you dont have your hand or have the chuck pressed against an object. If nether of these are the problem then there may be a problem with the chuck itself and should be replaced.
Apr 02, 2011 | Dewalt 18 Volt Compact Drill Kit
How do I change the drill bits and then tighten so the bits stay in the drill?
The chuck will not turn. So to loosen just turn the black plastic counter clockwise. The chuck will loosen. Or you can hold the black part on the chuck tight and put the drill in reverse and slowly squeeze the trigger and the chuck will loosen also. Do the opposite to put a new bit in. Put the drill in forward and hold the black part of the chuck and squeeze the trigger with the bit in place and it will tighten down on the bit.
Dec 16, 2010 | Dewalt 18 Volt Compact Drill Kit
The chuck on my Dewalt 18v hammer drill will not stay tight. it loosens whether I am in forward or reverse
the chuck on my dewalt 18 volts hammer drill will not stay tight it loosenss whether i am in forward or reverse
Oct 14, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I also have a problem w/a DC925 type 1 chuck releasing in reverse. messenger77 seems to have the 'fix', but how does the chuck come off? There is not a screw in the center.
you can go to the tip section and there are detailed instructions on how to remove. Secondly if the chuck itself is unthreading in reverse it is because the screw is missing or possibly the head is broken off. Let me know and I will try and give you some more help
Feb 23, 2010 | Dewalt 18 Volt Compact Drill Kit
The chuck is slipping. It will not spin the chuck anymore, motor works fine.
the transmission uses a planetary gear system. the motor is a johnson gearmotor. change the transmissioon. go to the dewalt service center for parts.
Oct 15, 2009 | Dewalt 18 Volt Compact Drill Kit
How do you relase a drill bit from the chuck on a Dewalt cordless drill
opposite of the way you put it in. Grip the chuck and put the drill in reverse and turn the chuck. or hold on tight and pull the trigger.
Jun 07, 2009 | Dewalt 18 Volt Compact Drill Kit
Drill bit came out, won't go back in. Dewalt 12v XRP
grasp the chuck and put drill in reverse position and pull trigger gently this will open chuck and re-insert bit do same in forward to tighten bit into chuck
Jan 10, 2009 | Dewalt 18 Volt Compact Drill Kit
Problem with the chuck
Sep 03, 2008 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
