Question about Hoover Dryers
I have a Hoover Apollo deluxe Dryer. I took off the front vent to remove lint. I now have a spring front grill white cloth backing and two plastic legs to hold onto the drum. How doers it go together
jsrock516
  • 5911 Answers
SOURCE: dryer takes more than one cycle to dry clothes
Did you clean the entire length of the vent ducting? Or, did you only clean the lint trap on the dryer and the exhaust vent outside? If you didn't clean the ducting as well, you may still have a clog somewhere causing your dryer to be "starved" for air. A dryer needs proper air flow to dry properly. One way to check is to turn the dryer on and go outside to the exhaust vent opening. Feel to see if you have sufficient air flow. If the air flow is weak, you have a clog. If not, you may have a high limit thermostat cutting off prematurely, not allowing the heating element to heat long enough. Check your ducting first and let me know if this helps.
Posted on Jul 28, 2007
aborcass
  • 2651 Answers
SOURCE: Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Posted on Nov 16, 2008
JR JR
  • 116 Answers
SOURCE: check lint screen light on and dryer not turning on
check belt might be broken,,,,
Posted on Nov 30, 2008
SOURCE: Hanging Hoover Apollo Deluxe dryer unit from the wall
you will need to get a wall mount bracket. I found a couple on ebay for about $30.
Posted on Dec 15, 2009
woodchuck789
  • 4070 Answers
SOURCE: Clothing getting caught on lint
Probably has extra space between drum because the front felt guides on the drum have worn. This can be accessed by removing the front panel.
Posted on Oct 05, 2010
Hoover apollo deluxe dryer
Can you give a model number?
Jan 30, 2014 | Dryers
Dryer not drying
Not a major appliance expert--but if the situation is as described with hot air out vent but not in the drum where the clothing is it seems to me you have a blockage between the drum and lint filter to where it reaches the vent tube---they do make long flexible brushes for this-----a suggestion: if you have a compressor try forcing air down from the lint filter with the vent tube removed to see if the blockage is there and will clear or not.
A blockage can be a fire hazard so if you do not find it have a tech out.
Dec 04, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I've a hoover apollo delux dryer still working well 5kg, 19 years old. Would like to know energy rating as giving it away to a friend.
The energy rating for this dryer is 1.5 stars. Of course it depends on the condition of the dryer and how well it has been maintained.
Does the hot air coming out of the front vent smell scorched or burnt? If so, you need to get the back off, clean out all the lint inside there. Then remove the drum, then remove the heater element carrier off the back of the drum. Its the only way you can clean all the lint out from around the heater element. After 19 years, its going to be needing it.
Please don't pass the dryer to your friend without having it properly cleaned out as described. Don't give your friend a fire hazard. Dryers cause house fires, don't risk it please.
Aug 18, 2010 | Dryers
Sep 30, 2009 | Hoover Dryers
Hoover Apollo Delux not drying properly and takes ages. Outlet air is hot but my wife says it's not drying as well as it used to. The front filter is clean but is there an inlet filter that I'm overlooking...
T^o much lint in duct work, causing moisture and not allowing cloths to dry. Vacuum out duct work in dryer and from dryer to outside of home.
Jul 17, 2009 | Dryers
Lint Trap in dryer
Friend,
ngfam1 At your service!
You said, lint is collecting by vent located outdoors. And you feel, the lint trip isn't working.
and you feel very concerned that this is a fire hazard.
We do clean the lint trip off before every dryer run.
The fact that lint is clogging your outside vent does not mean the dryer is not working properly!
The dryers with the top mount lint screens have blow by lint to the outside.
My next dryer will be a Speed Queen dryer which has the lint screen inside the dryer by the door and works better , without the mess on top of the dryer every time I remove it to clean before each load!
That top filter is an old style design!
The outside screen is to keep small animals out!
I find the new plastic outer vents have a plastic mesh screen which caused the same issue as you spoke of and caused my dryer to stop getting hot even though it was only half blocked outside !
I REMOVED the screen and left it off!
And recommend this to all other folks too!
The dryer is too hot for animals to want to enter! They sense it! AND THEY WON'T go in it!!
There are a few types.
1.The old ones are a aluminum vent with a aluminum flap like door that has a spring to keep it closed when the dryer is not on and forcing it open to allow for the exhaust to escape.
2. The newer ones can have a plastic flap that works the same way ,but usually designed without the spring mechanism.
3. the newest one are the ones with the plastic mesh screen that I spoke of above!
Remove the pop off plastic screen and leave it off!
Or if you have the flap door kind.
Change the vent to the open one that comes with the plastic pop on mesh and do not put the screen on!!
It's been years that mine is off and it's all is fine.
You will be fine
Bless You ,
huuum
Please give me the best rating for this solved solution!
Thank You!
Sep 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My candy civ60 dryer dose not heat
hi i too had that problem,when an engineer looked at it the thermostat,element were ok,he suggested that there was a blockage in the air flow,i took the whole thing apart ( i had nothing to lose ) cleaned it with a hoover very carefully then with a clean dry paintbrush,there is vents underneath the dryer if these get blocked the dryer blows cold air, its a saftey measure so that the fluff dosent catch fire ! i hope this helps,mine has run ok for 3 months now.
Dec 28, 2006 | Candy CIV60 Electric Dryer
Dryers Logo
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
