Duo=therm A/C remote not communicating with receiver on wall.
Setting on remote change, but receiver does not beep. Cant turn off or adjust any settings.
  • 828 Answers
SOURCE: duo-therm quick cool
Your compressor is trying to restart after it shuts off which is causing a power draw down changing the sound of the fan speed change. Check voltage power supply and insure that the power supply cord is heavy enough to carry the necessary load.
Posted on Jun 28, 2008
SOURCE: duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Posted on Jul 19, 2008
  • 6674 Answers
SOURCE: duo therm air conditionning/furnace thermostat in RV
Checked all breakers & fuses in panel ?
Posted on Aug 14, 2008
  • 96 Answers
SOURCE: Blower Fan Not Working
Try taking the top cover off the unit and spin the fan with your hand
Posted on Feb 23, 2009
  • 116 Answers
SOURCE: A/C Thermostat display is blank
find the stat wire and jump red to green to see if fan comes on if so then stat bad if not check for 24v ac transformer or 5 amp fuse
Posted on May 09, 2009
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
Duo therm heat pump blowing hot air only
relay module or communication cable from t-stat issue.
Apr 02, 2014 | Dometic 459186 Duo-Therm Brisk Air...
Light comes on all by itself
You are probably picking up some kind of radio interference that is causing the receiver to think a remote has sent it a signal. A possible solution to this issue is to change the frequency that the remote uses to communicate to the receiver to turn the fan or light on.
I have had the same problem with the light coming on intermittently by itself. At first I also could not change the settings and have the remote work with the new settings. But I found out that when you change the dip switch of the receiver you must turn off the power using the wall switch or the circuit breaker and turn it back on before the receiver will use the new dip setting. I am still waiting to see if the light will come back on after changing the dip switches from 1-on, 2-on, 3-on, 4-off to 1-off, 2-on, 3-on, 4-on and the remote's jumpers from 1-jumpered, 2-jumpered, 3-jumpered, 4- no jumper to 1-no jumper, 2-jumpered, 3-jumpered, 4- jumpered.
These directions are for the Hunter 27157 model.
Aug 12, 2010 | Hunter 27185 Remote Control
Have a duo therm ac and the low ac and low fan not work -
Thermostat on wall, or manual controls at AC? Did it work for you on low before now? Reason I ask, is that normally they are only a 2 speed fan ( low and high) so if it's a wall thermostat and has been changed from original, perhaps it the way the thermostat is wired.
Jul 05, 2010 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Duo Therm Thermostat
Hi there
I think this is a setting on your air conditioner, the air conditioner will turn off when the room is at the correct temperature and when the room starts to warm up, the air conditioner will turn back on. (You need to find the settings and change them from auto-adjust to manual-adjust)
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 27, 2008 | Dometic Rooftop RV Air Conditioner
Televison & Video Logo
Top Televison & Video Experts
