Question about Brother Office Equipment & Supplies
Printing from RCA tablet.....I don't have a print option when I want to print anything.... I have the brother printer and the brother I print and scan app
SOURCE: brother mfc 8440 "printing" problems
Hi
I recently had this problem - tested fuser and all sensors.
The fix is to reset the memory.
To do this, enter the Maintenance mode. Menu, * 2864
(enter the number quickly)
then type 01 ( zero one ), this will reset all memory including the user settings.
Finally type 99 to exit Maintenance mode.
The printer will restart and the error will be gone. Test out with copy and printer reports
Hoping this fixes your problem
Regards
Lindsay
Posted on Nov 25, 2007
  • 103 Answers
SOURCE: Can I set default printing to black and white for color laser printer?
Yes. Any printer's default options can be set as desired. Open the printer's properties (Start/Control Panel/Printers/right click the printer and left click Properties), and change the setting as you wish, then click OK. Those settings should be used each time you use the print command, unless you change the settings for that particular print job.
Hope this helps, and please rate my advice, good OR bad.
Posted on Feb 05, 2008
  • 79 Answers
SOURCE: Brother MFC 210C Printing slow
You may have already tried but /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} From page 129 of the manual: http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Changing the printer driver setting may improve the print speed.
Highest resolution needs longer data processing, transfer and printing
time. Try the other settings of quality in the printer driver ‘Basic’ tab.
Also, click the ‘Settings’ tab, and make sure you uncheck the
True2Life®.
Borderless printing is slower than normal printing. If you want to print
more quickly, set the Borderless feature off.
Posted on Sep 02, 2008
SOURCE: My brother printer in printing blurry?
I have bro-420C. Same problem. I used the option Ink. There is "cleaning" option. It helped to make it much better.
Posted on Apr 18, 2009
  • 8068 Answers
SOURCE: Brother MFC-210C USB Printer is not printing Troubleshooting
You try to solve that problem by following the instruction the machine gave you. Here is the link to the manual.
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc210c_all&type2=5&flang=English&dlid=
Hope it helps.
Posted on Aug 30, 2009
Same problem only using a Brother 8890DW
Go to:
www.brother-usa.com/downloads/android-app-printing.aspx
Brother iPrint Scan application for Android
PLEASE HAVE LATEST AND UP TO DATE ANTIVIRUS ACTIVE ON YOUR GADGET BEFORE TAKING TO ANY URL
May 11, 2014 | Brother MFC Office Equipment & Supplies
It is printing backwards
Click File
Select Print
Choose Brother MFC 490cw
Select Properties
Click on the Advance Tab near the top center of window
You can choose reverse printing options
• Check Mirror Printing to reverse the data from left to right. • Check Reverse Printing to reverse the data up to down.You can choose reverse printing options (3).
Apr 10, 2014 | Brother MFC 490cw Color Inkjet...
Printer prints but stopped scanning
Delete the current Printer Drivers or Printer Software and reinstall the updated Software from your printer manufacturer. If the Printer works when printing a document; then the printer is getting the proper communications and it is recognized; thus the commands to scan are blocked and need to be renewed. If you have Photoshop, try their scan options and see if that works.
Dec 18, 2013 | Brother Mfc-j835dw All-in-one Wireless...
I bought the wrong printer for my needs and the cartridges for my HP Photosmart C309g-m run out when I don't even want color. Is there a way to set permanately, not with every printing secssion to use...
Hi
Yes you can set it to print permanently. You have to go to Printer proprieties and go to color option and choose Gray scale printing only and this will not use the other inks at all but black cartridge only for printing.
Jul 27, 2011 | Office Equipment & Supplies
How can I print in " Black ink only " NO COLOR ?
go to control panel
printers and faxes than right click on the driver for the printer and click on properties ...
and you will find the option to print in gray scale
Dec 23, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Nov 20, 2008 | Brother HL 5250DN Laser Printer
"Scanning in progress" reported even when I'm not scanning anything
You need to install the print driver and Sharpdesk before you connect the USB cable.
Dec 10, 2007 | Sharp AL-1642CS Copier
Why can't I scan when an ink tank is empty?
look into the options for your printer. you should be able to assign file extensions, i.e. .BMP, .JPG, .TIF, GIF etc to your scanned documents without printing them. No ink effects print functions or copy functions.
Sep 11, 2007 | Brother DCP-110C All-In-One InkJet Printer
26 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
