Question about Refrigerators
I cannot change the temperature on the front panel of my refrigerator to 0 - 47. Instead it goes to SY and EF. What does that mean?
SOURCE: Does anyone know what sy
http://www.retrevo.com/support/Frigidaire-FPHS2387KF-Refrigerators-manual/id/23613ag220/t/2/
Above is a link for your user manual. to download. copy past to browser.
manuals.frigidaire.com/prodinfo_pdf/Anderson/240389644.pdf
Above is the latest service sheet to do with your machine.
That SY ER is the SYtem EvapoRator Fault. This usually means there is NOT enough air flow over the sensor, this can mean a faulty sensor, or fan.. you need to check.
In my professional opinion you should get a service tech to call, contact your head or local Frigidaire offic, and ask them for a referral to an authorized service agent. When there then ask for a "Quote" as to the repair, this way you can make an informed decision.
usually though a repair such as this shouldn't be too costly, however it may just be the tip of an underlying condition, which is why i suggested the professional.
Posted on Dec 17, 2010
SOURCE: CODES ON THE FRONT OF
First thing to do is unplug your unit for one hour and then plug it back in to see if the control board will reset itself. If you are still getting the SY EF error codes then you will need to replace the controller board
Posted on Jan 05, 2011
ZJLimited
  • 17970 Answers
SOURCE: What does "Sy EF" mean on dispenser led?
Error Code SY EF is the System Evaporator Fault.
Above is the latest service sheet to do with your machine, you need to check this.
Hope this helps (remember to rate and commnent this)..
Posted on Jun 03, 2011
imufo2
  • 3773 Answers
SOURCE: My Frigidaire Gallery display says
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Aug 04, 2011
  • 42945 Answers
SOURCE: My Frigidare Gallery is displaying a SY EF error code. I cannot get the temperatures to reset, any ideas?
better call the repair man needing serviced probably freon low
Posted on Jan 31, 2015
Kenmore refrigerator 253.7031 touch panel reads freezer temperature 5Y refrigerator temperature EF. What does it mean. refrigerator is getting very warm 71 Fahrenheit
The EF SY code indicates the evaporator fan circuit has failed or the sensor isn't registering cold air flow. Since the fridge is warm, the fan isn't running. You'll need to check the fan motor and the control board wiring. Unplug the refrigerator before checking the wiring. (You'll need a multimeter to check for continuity/voltages/resistance in those wires. You can use a 9V battery to check if the fan works. It's a DC motor; connect the red and yellow wires to the positive terminal of the battery. Connect the brown wire (on some models) to the negative terminal. Check the wiring harness for corrosion as well. The fan is at the back of the refrigerator. The control board is on the bottom, behind the toe kick plate.
If the fan motor is good, then the control board is bad. The fan motor is part 60 here: http://www.searspartsdirect.com/kenmore-refrigerator-parts/model-25370312211/0582/0161000/R1209145/00005.html . The control board is part 50 on the same page. It may be better to replace both parts at once.
You should also check if the fan has been freezing up. If the refrigerant system is leaking, ice build up on the fan can stop it from spinning. This will cause the fan motor to fail but the replacement part will fail again if the ice build up problem isn't solved first.
I hope this helps.
Jul 16, 2015 | Kenmore Refrigerators
What does the error code SY EF mean on an Electrolux French door refrigerator?
Hello Suzanne, thank you for your post!
I understand that your Electrolux refrigerator is displaying an error code of "SY EF". An "SY EF" code stands for an evaporator fan circuit failure. This could also be a miscommunication with your refrigerator and I would advise performing a reset on your refrigerator. You can reset it by disconnecting the power plug from the outlet for roughly ten minutes. If that does not help correct your issue you may need to replace your main control board or a wiring harness. For proper disassembly and repair of your refrigerator I would recommend having a professional technician for proper diagnosis and repair. I hope this information is helpful. -Matt
Mar 23, 2015 | Electrolux Refrigerators
What does EI28BS36IS3 blinking lights mean
Are all of the lights flashing or is it flashing a code like Sy EF or Sy CE? If so the ef would indicate the evaporator fan circuit has a problem, and if it is SY CE it would indicate a communication error.
Feb 19, 2015 | Electrolux Refrigerators
What does the error code 5y EF mean on my Frigidaire refrigerator
Good Morning Friend,
I understand you are receiving an "SY EF" code on your Frigidaire refrigerator, model# FRS3R5EMB. The "SY EF" code stands for system error with the evaporator fan. This possibly means that there is something going on with your evaporator fan or it could possibly be a false error code. . I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire FRS3R5EMB Side by Side...
What does error code sy ef mean ?
Good Afternoon Friend,
I understand you are receiving an SY EF code on your Frigidaire refrigerator, model# FGUN2642LF. This code states there is a system error code that deals with the evaporator fan. This could also be a possible false error code. I suggest you reset your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Once power is restored, you will need to press the "Mute Sounds" button to stop the power failure alert. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire FGUN2642 Stainless Steel Bottom...
SY EF electrolux
Hi daneilb101 - Typically error code SY EF indicates that the refrigerator has detected an evaporator fan circuit failure. Contact a professional to move forward accurately. The wiring between the main control board and evaporator fan will need to be check and diagnose. Depending on the diagnoses the main control board may need replacing.
Feb 22, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Jun 03, 2011 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
