Question about Sewing Machines
I have a baby lock bl4 736d serger it runs real good for a bit then it heats up and slows down and gets real tight and stops. can you tell me why and how can I fix it?
  • 3 Answers
Do you regularly clean and oil it, and use quality sewing machine oil? It sounds as though you might have sticky oil that needs cleaning out. If you know a friendly sewing machine repair person, see if they can clean it for you.
Try not to use it until this is resolved because you could be causing damage. Good luck!
Posted on May 05, 2017
I have a baby lock serger that starts then slows and stops. The motorstarts humming
Sounds like the machine may be seizing. AVOID trying to run the machine while the motor is straining--it could damage the motor.
Jul 18, 2017 | Baby Lock Sewing Machines
Baby lock bl4 736d serger slows down and stops
Your serger needs service. (clean, oil, adjust, etc.) It may be that the motor is not lubed well enough and as it is being run it heats up and expands which causes it to bog down and stop. I would take it in for service and "mention" this issue while you are there.
Sep 11, 2012 | Baby Lock Sewing Machines
Baby lock serger motor slows down after sewing 20 minutes. Why?
Call your local service shop. Baby Locks in closets for years usually have this problem The manual recommends annual maintenance by a pro, and they will oil the internal lobes of the feed dog apparatus. It cannot be oiled from the outside, nor with covers off, but must be taken apart. If those lobes lose the oil and heat up you will feel "surging" then slowing repeatedly -- fast then slow then fast etc -- until the lobes over heat and sort of weld themselves to that small barrel looking case. So a Baby Lock can sew, then temporarily be sluggish then later slow till sluggish; and at worst, seem to be doing everything right BUT not advancing the cloth -- that's when the worst damage is done and professional repair is needed. In PA might cost $150 to fix. $70 in parts; $80 in labor (2012 prices)
Been there, done that.
Jul 22, 2012 | Baby Lock Eclipse Serger
What is a special edition eclipse serger?
Go on the Babylock web site, they have good explanations of all serger types and the differences.
Jul 11, 2012 | Baby Lock Eclipse Serger
Related Tags: slow sewing stops lock not sewing Print Email Flag Problem with Baby Lock Eclipse Serger I have a Baby Lock Serger BL-90. When it has been on for a while and I'm sewing, it starts t
Perhaps was same as my problem.
Call your local service shop. Baby Locks in closets for years often have this problem The manual recommends annual maintenance by a pro, and they will oil the internal lobes of the feed dog apparatus. It cannot be oiled from the outside, nor with covers off, but must be taken apart. If those lobes lose the oil and heat up you will feel "surging" then slowing repeatedly -- fast then slow then fast etc -- until the lobes over heat and sort of weld themselves to that small barrel looking case. So a Baby Lock can sew, then temporarily be sluggish then later slow till sluggish; and at worst, seem to be doing everything right BUT not advancing the cloth -- that's when the worst damage is done and professional repair is needed. In PA might cost $150 to fix. $70 in parts; $80 in labor (2012 prices)
Jul 02, 2012 | Baby Lock Eclipse Serger
Serger runs very slowly
it could be the serger it's self or the power cord or even the foot pedal
it would be a good idea to have the machine serviced
Jan 29, 2012 | Baby Lock Sewing Machines
Babylock Serger loosing power
Your problem is probably the stitch length adjustment cam (located on the left side of the machine) To fix this problem you will need to remove the small plastic cap (with red arrow) covering the screw securing the cam. It is usually also necessary to remove the connecting rod/sleeve that the cam rides in. Once both of these parts have been removed, you will need to carefully separate them and resurface the inside of the sleeve. This can be done with a very fine (500grit or higher) emery paper. Once the cam fits inside the sleeve without binding, reassemble using sewing machine oil or lithium grease and adjust feed dog timing.
Jul 13, 2009 | Baby Lock Eclipse Serger
Baby Lock Eclipse threader looper
The part number is B8200-01a and you can get it from any authorized babylock dealer.
Give them this number and they can order it.
Dec 19, 2007 | Baby Lock Eclipse Serger
Baby Lock Serger Instruction Manual
Baby Lock offers free downloadable instruction manuals for their products. Go to http://www.babylock.com. Find your model's product page; for example, mine was the Baby Lock Evolve Model BLE8W. Once on the product page for your particular model, you will find a link towards the bottom that says "Manuals & Guides." Click on this link and there will be links to download the manual and anything else, like a Quick Reference guide.
Oct 28, 2007 | Baby Lock Evolve
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
