Article in teleph. o marine rescue 30/4/17 p - Computers & Internet
200 Marines who were stranded after desert storm. Did Donald Trump send a plane in to rescue them.
No, he had nothing to do with getting them home. I have found an article that goes into more detail if you would like to take a look.
Oct 15, 2016 | Cars & Trucks
How do I diagram this sentence-The boy yelled "help" and saw a brave dog quickly run to the rescue.
The is article/adjective modifying subject boy. Yelled and saw are verbs in the predicate of this compound sentence; and is the conjunction. "Help" is the direct object of yelled. A brave dog quickly run to the rescue is a gerund. Subject of gerund is dog with a and brave as modifiers. Run is verb of gerund with quickly the adverb modifying. To the rescue is a prepositional phrase. To is the preposition, rescue the object of to and the a modifier. And here I though my 8th grade talents were no longer needed. Why is this listed in the chainsaw catagory?
Oct 08, 2014 | Garden
Easyhome computer locked
Do a search for 'Trinity Rescue Kit CPR for your computer' this will help you unlock the computer.
Then read this article and get yourself a backup solution so next time you can do a straight rebuild.
Oct 12, 2013 | Computers & Internet
Change rear brake light on a 2010 mercury mariner
Well, here is an article which may about how do I replace rear brake pads, I hope it might have help to you.
Aug 01, 2012 | 2010 Mercury Mariner
Ihave an old icom icm- 55 marine radio what ariel do i need and do i need to swr the ariel will a cb ariel work basically what do i need to do to get it working
All marine VHF radios must be licensed. A marine radio station must also have a call-sign allocated to the vessel it is installed in. Shore based stations can also be licensed but only where they are involved in marine based activities e.g Yacht Clubs, Marinas, Harbour Masters, Rescue Services etc.
In the UK ships radio licences can be obtained from Ofcom. They are free for non-commercial users.
The user must also have a Marine VHF Radio operators certificate. This requires taking an exam. In the UK contact the Royal Yachting Association for a copy of the syllabus and local examiners.
More information about the licensing rules, courses and exams can be found here.
The ICOM ICM55 is a good radio set and can still be used in an existing (marine) installation but it does not meet the standards for new installations as it does not have DSC (digital selective calling) capabilities - which all new fixed sets must now have. It is therefore very unlikely that you will be able to get a licence to install one.
To get it working you will need a proper marine band VHF aerial which operates in the frequency range 156-MHz. They usually come with cable attached but if a longer cable is needed, or the aerial is not cabled in the first place, use flexible 75 ohm co-axial cable with a copper core and braid/foil screen. Use proper aerial connectors (type F or BC are most commonly used and can be obtained from most good electronic component suppliers more cheaply than from a boat chandlers. Do not use push-fit TV aerial plugs)
Citizens Band radio works on the much lower frequency MHz band and therefore a CB aerial will not work with a marine VHF radio set. Please see this Wikipedia article for more information
Jan 28, 2011 | ICOM Informatique IC-F420-55 UHF...
How to install rescue sled on jet ski
copy and paste this link in your address bar for more info:
Sep 22, 2009 | Sport & Outdoor - Others
Save your life?
Absolutely. All sailing and sea-going craft should carry rafts - inflatable vessels which can maintain the lives of stricken mariners until rescue is available.
Dec 01, 2008 | RTO Aviva Crazy Twister Noodle Water Pool...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
