Question about Whirlpool Refrigerators
I have a whirlpool gold series refrigerator and it leaks water intermittently, what could be wrong?
  • 409 Answers
SOURCE: whirlpool gold refrigerator icemaker leaking water
hi there,
sounds like the ice or water actuator or paddle is broken. purchase a new paddle and replace it.
the reason you have leak is because you have warm air entering through the broken part into the freezer.
can you provide me with the model # and i will send you a part breakdown.
Posted on Sep 16, 2008
  • 1462 Answers
SOURCE: Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Posted on Nov 26, 2008
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Posted on Aug 21, 2009
arikrom
  • 528 Answers
SOURCE: Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Posted on Jan 02, 2010
  • 1531 Answers
SOURCE: I have Whirlpool refrigerator without
The most common problem is the defrost drain hole is plugged or frozen over.And the defrosted water from the evap coil is leaking in the fridge compartment,You may have to remove the back panel in the freezer compartment and defrost the evap coil and drain area.
Posted on Jan 07, 2011
Water leaking and freezing in bottom of freezer and leaking on the floor it is a whirlpool gold series model #GI6SARXXF04
sounds like your defrost drain is clogged up. it can be cleaned by taking off the metal or plastic panel and cleaning out the defrost drain hole. a steamer works best.
Dec 20, 2016 | Whirlpool Refrigerators
Fridge leaking water
The drain line may be misdirecting the defrost water so that it misses the pan or the pan may be damaged or mispositioned.
Dec 03, 2013 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
Leaking rear white valve at lower back of whirlpool fridge.
Hello is the valve leaking where the water line comes to the top of the valve?
Sep 27, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold GB2SHTXTS00, I bought it in 2007, but 3 days ago, the cooling suddenly is not working, but freezer and lights are fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 06, 2011 | Whirlpool Gold Series GB2SHTXTS (219 cu...
The water lines from the filter housing leak at the solenoid and are dripping at the filter. It is a Whirlpool gold series side by side
you should be able to push in the ring around the tube at the same time pull the tube out
cut about 1/4 in off and push it back into the hose clip
unless your line is craked this should work for most drip leaks
Oct 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Aug 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold refrigerator icemaker leaking water
hi there,
Sep 09, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
43 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
