Question about Water Dispensing & Filtration
How do i check the water heater in my water dispenser?
I have had this "PRIMO "water dispenser (hot and cold)model#601130- for about a year worked great ! the hot stopped getting hot ,yet it still dispenses water,what do i check?
SOURCE: Sunbeam Model YLR2-5-90HZ3 hot/cold water dispenser w fridge
HOW CAN I REPLACE THE PART MINE IS DRIPPING WATER CONSTANTLY.
Posted on Nov 15, 2008
  • 33 Answers
SOURCE: in door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Posted on Nov 30, 2008
SOURCE: Frigidaire model FRS6LE4FW0 water dispenser does not work.
I DONT GET WATER OR CUBES
Posted on Jan 11, 2009
SOURCE: Instant hot water dispenser does not heat water.
I had the exact same problem. I even replaced the first unit with a second unit...because I was sure I hooked everything up correctly. Then I called their support line and and felt very stupid. They asked one question "are you plugging in the Quick&Hot into the same electrical outlet as the garbage disposal"?. I said yes..and the garbage disposal works fine (thinking that this indicates a good electrical outlet). She then said "That outlet works off of a switch so no electricity is getting to the Quick&Hot until the disposal is turned on). Gosh darn it...that made total sense. I then tested this out by plugging an extension cord into a different outlet and it worked fine. Boy...do I feel stupid. Hope this helps.
Posted on Mar 19, 2010
SOURCE: I have a PUR 200 water filter/hot and cold dispenser and the cold
I have the same problem as both stated earlier. The cold water is not working and the night light does not work.
Posted on Mar 21, 2010
Owners manual for Primo water dispenser 601130
Try Googling (primo)(601130)(manual) without parens.
Aug 06, 2017 | Water Dispensing & Filtration
Tip
Wow this is awesome. I was getting so frustrated, but this completely fixed it....
We started getting a blinking light... indicating the jug needed replacement... after installing a full jug. The unit would cycle, then the red blinking light would come back on. Upon careful inspection of the feed tube and lines, it was realized that the plastic line on the intake of the pump body had been inadvertently pulled out just slightly (presumably from jostling the jug around during replacement). I believe that this breaks the seal the unit requires for suction, and caused the fault. I simply pushed the (white) plastic line back into pump body and heard an audible 'click'. Unit works fine now. I hope this helps, as these units are not exactly cheap.
on Apr 25, 2017 | Primo Grills And Smokers Primo Bottom Load...
Tip
PRIMO BOTTOM LOAD WATER DISPENSER, BLINKING LIGHT
on Oct 30, 2013 | Primo Grills And Smokers Primo Bottom Load...
I have a primo bottom load water cooler model # 900130 the pump is not working. How do I fix it
I have missing or damaged parts. + - Select parts are available for your dispenser. Please complete the Contact Us form and provide the dispenser model number, serial number, and note the replacement part needed in the comments field. A Care Specialist will follow up with your request. A replacement fee will apply to out of warranty part requests.
900130 Primo Water Store
Dec 26, 2015 | Unknown Primo Deluxe Stainless Steel...
Primo water cooler red light blinking
What do I do with my Primo water dispenser whenever the red light keeps flashing I have a full bottle of water in there but it just keeps flashing I can turn it off and turn it back on or I can push the button in the door and it'll go off within the next 20 minutes it will come back on and the water's cold and then the water goes to lukewarm
Nov 25, 2013 | Unknown Primo Deluxe Stainless Steel...
Sunbeam hot/cold water dispenser is leaking from looks like copper tubing that goes to tank. Model # ylr-5-87h3 what could my problem be
Broken solder connection.
Continual expansion and contraction of metal due to hot and cold extremes will cause metal fatigue. The most vulnerable place is at the join. Other places can fail, but usually the solder join will fail first.
Buy another one and support economy.
Make sure next unit is connected to cold water line, and not hot water line. If hot water dispenser is connected to Hot line, then it will cause water heater to run each time water is drawn through dispenser because cold water immediately enters tank.
http://waterheatertimer.org/Water-heater-dip-tube.html
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html#h-c
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#pot
You might also consider installing small tank under counter. Tanks are less glamorous than hot water dispensers but tanks are more reliable long term than instantaneous water heaters.
May 28, 2013 | Water Heaters
Where is the reset switch on a Primo water cooler model YL1136S
My Primo Model:YL1136S Hot Water Quit Working How Do I Repair It
Aug 24, 2012 | Baby Gear
Hamilton Beach 87330 water dispenser: no auto shut off
Glen,
We purchaced this water dispencer about 2 years ago, everything was working normal, water heater works fine and the cooler would come on and go off normally,until you dispenced cold water and then the coller would cool down and shut of like it's supposed to.
Afetr a couple of years , one day it started cooling continuously and wouldn't stop, I've just shut the cooler switch off on the back of the unit until i can figure the problem out,unit #(87330).
I believe the problem is in the circuit control board, but with out further testing i can't be sure .
Sep 01, 2008 | Refrigerators
Water Dispensing & Filtration Logo
1,836 people viewed this question
Top Water Dispensing & Filtration Experts
ray gallant
Tom Chichester
Dwain Schmidt
Dwain Schmidt
Level 1 Expert
Are you a Water Dispensing and Filtration Expert? Answer questions, earn points and help others
